I have a question.
Im using the OPCUA IIoT Server ASO node.
I would like to create a subflow and change the "Node-Id" and the "Reference Id" from outside of the subflow.
How can i do this?
Thanks Chris.
Hi @Kampfwurst
currently, the only way that would be possible is if that particular node allows you to set those properties by passing in messages with the appropriate properties set. You should read the node's own help text to see if that is the case.
In the future we'll provide a way to customise individual instances of a subflow, but that is a little way off at the moment.
