If you have encrypted node credentials in the file and are worried about possibly losing them, the message tells you what to do about it - edit settings.js.
Do you have access via ssh to edit this file on the CerboGX device?
That's the $64k ?. I don't understand how or if I shouldn't be accessing the cerbo. Should I continue down this path and figure out how to change this file or is there a diff direction I should take?
/** By default, credentials are encrypted in storage using a generated key. To
* specify your own secret, set the following property.
* If you want to disable encryption of credentials, set this property to false.
* Note: once you set this property, do not change it - doing so will prevent
* node-red from being able to decrypt your existing credentials and they will be
* lost.
//credentialSecret: "a-secret-key",
I never bother to change it, I just ignore the message on Node-red startup. After all it's not an error.
But I presume that if you simply uncommented the credentialSecret line it would somehow use "a-secret-key" and the credentials file would become magically obscure.
Note that if you just ignore it, and your flows_cred.json file is encrypted and stops working somehow, the worst that can happen is that you are forced to delete it and re-enter all the credentials. I am sure you have them all noted down somewhere.
