I have set up my python code to read the temperature signal on raspberry pi after I have used Digital to Analog converter but I don't know how to read the temperature signal on the pi in node red. Please help
There is a node for node red that makes it easy to use a b20 sensor. Used it it for a while but that's been a while ago so I can't come up with the name right now. Have you searched for a node?
Maybe these nodes???
There are other DS18B20 nodes listed in the Node-RED Library.
This was posted on the Forum some time ago - might be worth having a look at it?
