Activate an overlay in woldmap by a node
After starting up Node-Red I want to setup worldmap by an inject node and also set the right overlay (ship nav) so I can switchoff the layer menu. The reason is that sometimes its hard to avoid touching unwanted items on the screen (tablet). Everything works (more than) fine except the activation of the ship nav overlay by an inject node.
So I tried (almost?) everything, but I can't get it fixed; only by the layer menu I can select the ship nav overlay. Is someone familiar with worldmap and can give me the "golden" tip?
Thanks in advantage.
Kind regards,
Ino
you just need a msg.payload like
    "command": {
        "showlayer": "ship nav"
[{"id":"15cea42f.0fdfec","type":"inject","z":"e9b4dddd.70115","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"command\":{\"showlayer\":\"ship nav\"}}","payloadType":"json","x":170,"y":240,"wires":[["3010bc77.940f94"]]},{"id":"3010bc77.940f94","type":"worldmap","z":"e9b4dddd.70115","name":"","lat":"","lon":"","zoom":"","layer":"","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"false","panlock":"false","zoomlock":"false","hiderightclick":"false","coords":"none","showgrid":"false","path":"/worldmap","x":390,"y":240,"wires":[]}]
Thanks a lot; it works fine now!
I completely missed the command in the documentation. Sometimes its better to stop and have a break..........
