is it possible to add an object value from two arrays without changing the other objects in the array? The two arrays should become one array.
Try using concat
I created a flow that should help you understand.
Import this flow:
[{"id":"3bda0a600cf55ec4","type":"function","z":"d2add6885c98847b","name":"Create array of arrays of objects","func":"msg.payload = [\n [\n {\n a:01,\n b:02,\n c:03,\n d:04,\n e:05,\n f:06,\n g:07,\n h:08,\n i:09,\n j:10\n },\n {\n A:101,\n B:102,\n C:103,\n D:104,\n E:105,\n F:106,\n G:107,\n H:108,\n I:109,\n J:110\n }\n ]\n ,\n [\n {\n aaa:201,\n bbb:202,\n ccc:203,\n ddd:204,\n eee:205,\n fff:206,\n ggg:207,\n hhh:208,\n iii:209,\n jjj:210\n },\n {\n AAA:301,\n BBB:302,\n CCC:303,\n DDD:304,\n EEE:305,\n FFF:306,\n GGG:307,\n HHH:308,\n III:309,\n JJJ:310\n }\n ]\n\n\n\n]\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":180,"wires":[["0d375a61e1a57692","29a7ea2c0d75f106"]]},{"id":"016770477dcad19c","type":"inject","z":"d2add6885c98847b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":200,"wires":[["3bda0a600cf55ec4"]]},{"id":"ad7b5624ee7dab01","type":"debug","z":"d2add6885c98847b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":220,"wires":[]},{"id":"0d375a61e1a57692","type":"function","z":"d2add6885c98847b","name":"concat arrays","func":"const originalPayload = msg.payload;\nconst newPayload = [].concat(...originalPayload);\nmsg.payload = newPayload;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":420,"y":220,"wires":[["ad7b5624ee7dab01"]]},{"id":"29a7ea2c0d75f106","type":"debug","z":"d2add6885c98847b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":180,"wires":[]}]
It helps if you copy the payload and paste it for us to use. Then we can test it with your values ...FYI
This saves us from having to recreate your payload IE: Create array of arrays of objects
The concat() method is used to merge two or more arrays.
I know that I can merge two arrays with it. But what I want is something else. I want to add the "purple" values and return the whole thing as one array. I am not interested in the rest of the second array.
Here is the payload:
[[{"Datum/Uhrzeit":"00:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"00:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"00:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"00:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"01:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"01:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"01:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"01:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"02:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"02:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"02:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"02:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"03:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"03:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"03:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"03:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"04:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"04:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"04:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"04:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"05:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"05:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"05:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"05:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"06:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"06:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"06:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"06:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"07:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"07:15","Verbrauchswert":"1,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,001"},{"Datum/Uhrzeit":"07:30","Verbrauchswert":"3,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,002"},{"Datum/Uhrzeit":"07:45","Verbrauchswert":"9,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,005"},{"Datum/Uhrzeit":"08:00","Verbrauchswert":"15,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,008"},{"Datum/Uhrzeit":"08:15","Verbrauchswert":"16,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,009"},{"Datum/Uhrzeit":"08:30","Verbrauchswert":"21,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,012"},{"Datum/Uhrzeit":"08:45","Verbrauchswert":"30,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,017"},{"Datum/Uhrzeit":"09:00","Verbrauchswert":"33,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,018"},{"Datum/Uhrzeit":"09:15","Verbrauchswert":"40,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,022"},{"Datum/Uhrzeit":"09:30","Verbrauchswert":"44,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,024"},{"Datum/Uhrzeit":"09:45","Verbrauchswert":"48,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,026"},{"Datum/Uhrzeit":"10:00","Verbrauchswert":"52,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,029"},{"Datum/Uhrzeit":"10:15","Verbrauchswert":"55,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,030"},{"Datum/Uhrzeit":"10:30","Verbrauchswert":"57,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,031"},{"Datum/Uhrzeit":"10:45","Verbrauchswert":"57,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,031"},{"Datum/Uhrzeit":"11:00","Verbrauchswert":"59,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,032"},{"Datum/Uhrzeit":"11:15","Verbrauchswert":"63,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,035"},{"Datum/Uhrzeit":"11:30","Verbrauchswert":"59,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,032"},{"Datum/Uhrzeit":"11:45","Verbrauchswert":"57,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,031"},{"Datum/Uhrzeit":"12:00","Verbrauchswert":"43,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,024"},{"Datum/Uhrzeit":"12:15","Verbrauchswert":"46,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,025"},{"Datum/Uhrzeit":"12:30","Verbrauchswert":"51,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,028"},{"Datum/Uhrzeit":"12:45","Verbrauchswert":"52,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,029"},{"Datum/Uhrzeit":"13:00","Verbrauchswert":"67,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,037"},{"Datum/Uhrzeit":"13:15","Verbrauchswert":"36,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,020"},{"Datum/Uhrzeit":"13:30","Verbrauchswert":"50,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,028"},{"Datum/Uhrzeit":"13:45","Verbrauchswert":"66,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,036"},{"Datum/Uhrzeit":"14:00","Verbrauchswert":"62,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,034"},{"Datum/Uhrzeit":"14:15","Verbrauchswert":"61,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,034"},{"Datum/Uhrzeit":"14:30","Verbrauchswert":"57,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,031"},{"Datum/Uhrzeit":"14:45","Verbrauchswert":"55,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,030"},{"Datum/Uhrzeit":"15:00","Verbrauchswert":"53,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,029"},{"Datum/Uhrzeit":"15:15","Verbrauchswert":"48,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,026"},{"Datum/Uhrzeit":"15:30","Verbrauchswert":"41,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,023"},{"Datum/Uhrzeit":"15:45","Verbrauchswert":"34,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,019"},{"Datum/Uhrzeit":"16:00","Verbrauchswert":"29,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,016"},{"Datum/Uhrzeit":"16:15","Verbrauchswert":"18,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,010"},{"Datum/Uhrzeit":"16:30","Verbrauchswert":"8,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,004"},{"Datum/Uhrzeit":"16:45","Verbrauchswert":"6,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,003"},{"Datum/Uhrzeit":"17:00","Verbrauchswert":"5,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,003"},{"Datum/Uhrzeit":"17:15","Verbrauchswert":"3,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,002"},{"Datum/Uhrzeit":"17:30","Verbrauchswert":"1,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,001"},{"Datum/Uhrzeit":"17:45","Verbrauchswert":"1,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,001"},{"Datum/Uhrzeit":"18:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"18:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"18:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"18:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"19:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"19:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"19:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"19:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"20:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"20:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"20:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"20:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"21:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"21:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"21:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"21:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"22:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"22:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"22:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"22:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"23:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"23:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"23:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"23:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"}],[{"Datum/Uhrzeit":"00:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"00:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"00:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"00:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"01:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"01:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"01:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"01:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"02:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"02:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"02:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"02:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"03:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"03:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"03:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"03:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"04:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"04:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"04:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"04:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"05:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"05:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"05:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"05:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"06:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"06:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"06:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"06:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"07:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"07:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"07:30","Verbrauchswert":"1,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,001"},{"Datum/Uhrzeit":"07:45","Verbrauchswert":"3,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,002"},{"Datum/Uhrzeit":"08:00","Verbrauchswert":"3,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,002"},{"Datum/Uhrzeit":"08:15","Verbrauchswert":"6,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,003"},{"Datum/Uhrzeit":"08:30","Verbrauchswert":"8,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,004"},{"Datum/Uhrzeit":"08:45","Verbrauchswert":"7,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,004"},{"Datum/Uhrzeit":"09:00","Verbrauchswert":"10,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,006"},{"Datum/Uhrzeit":"09:15","Verbrauchswert":"10,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,006"},{"Datum/Uhrzeit":"09:30","Verbrauchswert":"9,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,005"},{"Datum/Uhrzeit":"09:45","Verbrauchswert":"9,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,005"},{"Datum/Uhrzeit":"10:00","Verbrauchswert":"12,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,007"},{"Datum/Uhrzeit":"10:15","Verbrauchswert":"13,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,007"},{"Datum/Uhrzeit":"10:30","Verbrauchswert":"12,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,007"},{"Datum/Uhrzeit":"10:45","Verbrauchswert":"13,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,007"},{"Datum/Uhrzeit":"11:00","Verbrauchswert":"11,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,006"},{"Datum/Uhrzeit":"11:15","Verbrauchswert":"13,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,007"},{"Datum/Uhrzeit":"11:30","Verbrauchswert":"14,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,008"},{"Datum/Uhrzeit":"11:45","Verbrauchswert":"11,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,006"},{"Datum/Uhrzeit":"12:00","Verbrauchswert":"11,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,006"},{"Datum/Uhrzeit":"12:15","Verbrauchswert":"13,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,007"},{"Datum/Uhrzeit":"12:30","Verbrauchswert":"18,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,010"},{"Datum/Uhrzeit":"12:45","Verbrauchswert":"17,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,009"},{"Datum/Uhrzeit":"13:00","Verbrauchswert":"14,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,008"},{"Datum/Uhrzeit":"13:15","Verbrauchswert":"18,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,010"},{"Datum/Uhrzeit":"13:30","Verbrauchswert":"17,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,009"},{"Datum/Uhrzeit":"13:45","Verbrauchswert":"16,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,009"},{"Datum/Uhrzeit":"14:00","Verbrauchswert":"12,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,007"},{"Datum/Uhrzeit":"14:15","Verbrauchswert":"15,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,008"},{"Datum/Uhrzeit":"14:30","Verbrauchswert":"13,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,007"},{"Datum/Uhrzeit":"14:45","Verbrauchswert":"15,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,008"},{"Datum/Uhrzeit":"15:00","Verbrauchswert":"48,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,026"},{"Datum/Uhrzeit":"15:15","Verbrauchswert":"48,000","Einheit":"kg CO2","Verbrauch in Euro":"0,02","CO2-Ausstoss":"0,026"},{"Datum/Uhrzeit":"15:30","Verbrauchswert":"44,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,024"},{"Datum/Uhrzeit":"15:45","Verbrauchswert":"38,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,021"},{"Datum/Uhrzeit":"16:00","Verbrauchswert":"35,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,019"},{"Datum/Uhrzeit":"16:15","Verbrauchswert":"29,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,016"},{"Datum/Uhrzeit":"16:30","Verbrauchswert":"23,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,013"},{"Datum/Uhrzeit":"16:45","Verbrauchswert":"19,000","Einheit":"kg CO2","Verbrauch in Euro":"0,01","CO2-Ausstoss":"0,010"},{"Datum/Uhrzeit":"17:00","Verbrauchswert":"8,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,004"},{"Datum/Uhrzeit":"17:15","Verbrauchswert":"2,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,001"},{"Datum/Uhrzeit":"17:30","Verbrauchswert":"2,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,001"},{"Datum/Uhrzeit":"17:45","Verbrauchswert":"1,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,001"},{"Datum/Uhrzeit":"18:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"18:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"18:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"18:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"19:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"19:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"19:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"19:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"20:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"20:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"20:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"20:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"21:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"21:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"21:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"21:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"22:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"22:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"22:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"22:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"23:00","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"23:15","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"23:30","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"},{"Datum/Uhrzeit":"23:45","Verbrauchswert":"0,000","Einheit":"kg CO2","Verbrauch in Euro":"0,00","CO2-Ausstoss":"0,000"}]]
Thanks for helping me.
Possible, but it does not help that your values are strings and contain commas. Something like this should do it.
[{"id":"016770477dcad19c","type":"inject","z":"bf9e1e33.030598","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[[{\"Datum/Uhrzeit\":\"00:00\",\"Verbrauchswert\":\"0,100\",\"Einheit\":\"kg CO2\",\"Verbrauch in Euro\":\"0,00\",\"CO2-Ausstoss\":\"0,000\"},{\"Datum/Uhrzeit\":\"00:15\",\"Verbrauchswert\":\"0,200\",\"Einheit\":\"kg CO2\",\"Verbrauch in Euro\":\"0,00\",\"CO2-Ausstoss\":\"0,000\"},{\"Datum/Uhrzeit\":\"00:30\",\"Verbrauchswert\":\"0,300\",\"Einheit\":\"kg CO2\",\"Verbrauch in Euro\":\"0,00\",\"CO2-Ausstoss\":\"0,000\"}],[{\"Datum/Uhrzeit\":\"00:00\",\"Verbrauchswert\":\"0,100\",\"Einheit\":\"kg CO2\",\"Verbrauch in Euro\":\"0,00\",\"CO2-Ausstoss\":\"0,000\"},{\"Datum/Uhrzeit\":\"00:15\",\"Verbrauchswert\":\"0,200\",\"Einheit\":\"kg CO2\",\"Verbrauch in Euro\":\"0,00\",\"CO2-Ausstoss\":\"0,000\"},{\"Datum/Uhrzeit\":\"00:30\",\"Verbrauchswert\":\"0,300\",\"Einheit\":\"kg CO2\",\"Verbrauch in Euro\":\"0,00\",\"CO2-Ausstoss\":\"0,000\"}]]","payloadType":"json","x":110,"y":2020,"wires":[["317bc371.8b0cd4"]]},{"id":"317bc371.8b0cd4","type":"function","z":"bf9e1e33.030598","name":"","func":"let output = msg.payload[0];\nfor(let j = 0; j < msg.payload[0].length; j++){\n output[j].Verbrauchswert = parseFloat(output[j].Verbrauchswert.replace(\",\", \".\")) \n for(let i = 1; i < msg.payload.length; i++){\n output[j].Verbrauchswert += \n parseFloat(msg.payload[i][j].Verbrauchswert.replace(\",\", \".\"));\n }\n output[j].Verbrauchswert = output[j].Verbrauchswert.toFixed(3).replace(\".\", \",\");\n}\nmsg.payload = output\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":360,"y":2020,"wires":[["29a7ea2c0d75f106"]]},{"id":"29a7ea2c0d75f106","type":"debug","z":"bf9e1e33.030598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":640,"y":2000,"wires":[]}]
I totally overlooked the fact that the value is a string. Now the summation of the values works. Small things can be crucial
Thanks for the help!
