Add mathjs to node red
Hi
Is it posible til add mathjs to node-red?
I installed mathjs with npm and tried to add/enabled it in the settings.js fil
Blockquote
Error loading settings file: /home/pi/.node-red/settings.js
ReferenceError: mathjs is not defined
at Object. (/home/pi/.node-red/settings.js:175:15)
at Module._compile (internal/modules/cjs/loader.js:778:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
at Module.load (internal/modules/cjs/loader.js:653:32)
at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
at Function.Module._load (internal/modules/cjs/loader.js:585:3)
at Module.require (internal/modules/cjs/loader.js:692:17)
at require (internal/modules/cjs/helpers.js:25:18)
at Object. (/usr/lib/node_modules/node-red/red.js:119:20)
Hi @sondre
how did you install mathjs? What command did you run and what directory were you in when you ran it?
What have you then added to your settings.js file to load it?
Installed in the folder for node-red
Blockquote
pi@raspberrypi:~/.node-red $ npm install mathjs
Added this line to the settings file
Blockquote
functionGlobalContext: {
mathjs:require(mathjs),
You have missed some quotes:
     mathjs:require("mathjs"),
Thank you for pointing out that error. It's working now :slight_smile:
