Add quotes to Json Value
Hi I'm totally new to node-red and need some help
I'm getting values of a flow sensor via MQTT
{"FlowRate":0.19,"TotalVolume":11354.25,"KValues":[{"Item1":19.0,"Item2":24.0},{"Item1":38.0,"Item2":61.0},{"Item1":57.0,"Item2":93.0},{"Item1":76.0,"Item2":128.0},{"Item1":95.0,"Item2":163.0},{"Item1":114.0,"Item2":196.0}],"created_at":"2021-08-24T06:38:01.7884747Z","ModuleType":"FLO","value":"11354.2","Address":104,"Name":"Pump_flow"}
I
i need quotes on the value of the FlowRate 0,19
I have a switch function to get the value so I can send it to Domoticz via MQTT
switch (msg.topic) {
    case "Pool/RTD/add102/Pool_temp":
    msg.payload = {"command":"udevice","idx":1414,"nvalue":0,"svalue":msg.payload.value};
    var Pool_temp = msg.payload.value
    break;
    case "Pool/RTD/add103/Roof_temp":
    msg.payload = {"command":"udevice","idx":1413,"nvalue":0,"svalue":msg.payload.value};
    break;
    case "Pool/pH/add99/Pool_pH":
    msg.payload = {"command":"udevice","idx":1416,"nvalue":0,"svalue":msg.payload.value};
    break;
    case "Pool/ORP/add98/Pool_orp":
    msg.payload = {"command":"udevice","idx":1415,"nvalue":0,"svalue":msg.payload.value};
    break;
case "Pool/FLO/add104/Pump_flow":
    msg.payload = {"command":"udevice","idx":1436,"nvalue":0,"svalue":msg.payload.FlowRate};
    break;
Can someone put me please on the right track?
Kind regards
Koen
Since it is a number, you can use .toString()
msg.payload = {"command":"udevice","idx":1436,"nvalue":0,"svalue":String(msg.payload.FlowRate.toString())}
Or, you can append ""
msg.payload = {"command":"udevice","idx":1436,"nvalue":0,"svalue":String(msg.payload.FlowRate+"")}
Or use the String() function
msg.payload = {"command":"udevice","idx":1436,"nvalue":0,"svalue":String(msg.payload.FlowRate)}
Hi Steve,
Thx for the solution.
I have used the String(msg.payload.FlowRate). I had tied the tostring but didn't noticed the capilal S of string
