I have just started using Node RED. I am creating an application where the user can send commands to the Raspberry PI and am using the RED Runtime Api. I am getting an error when using RED.nodes.addFlow()
\server\node_modules\node-red\red\runtime\nodes\flows\index.js:497
if (activeFlowConfig.allNodes[node.id]) {
TypeError: Cannot read property 'allNodes' of null
My server setup :
const express = require('express') const bodyParser = require('body-parser') const cors = require('cors') const morgan = require('morgan') var http = require('http') var RED = require("node-red") var app = express() var server = http.createServer(app) var settings = { httpAdminRoot:"/red", httpNodeRoot: "/api", userDir:"/home/nol/.nodered/", functionGlobalContext: { } // enables global context }; var nrFlow = { label: "Flow Label", nodes: [ { "id": "node-red/inject", "type": "inject", "name": "", "topic": "", "payload": "", "payloadType": "date", "repeat": "15", "crontab": "", "once": false, "onceDelay": 0.1, "wires": [ ] }, ] }; RED.init(server,settings); RED.nodes.addFlow(nrFlow) // Serve the editor UI from /red app.use(settings.httpAdminRoot,RED.httpAdmin); // Serve the http nodes UI from /api app.use(settings.httpNodeRoot,RED.httpNode); server.listen(8000); RED.start() app.use(morgan('combined')) app.use(bodyParser.json()) app.use(cors()) app.get('/posts', (req, res) => { res.send( [{ title: "Hello World!", description: "Hi there! How are you?", items : RED.nodes.getNodeConfigs() }] ) }) app.listen(process.env.PORT || 8081)
Any chance anyone could help me find the issue ? Thanks!
