I see this when NR is starting - just asking/mentioning
Just noticed this as I am repeatedly stopping/starting NR.
TypeError: Cannot read property 'config' of null
    at addWidget (/home/pi/.node-red/node_modules/node-red-dashboard/index.js:73:39)
    at Object.addWidget (/home/pi/.node-red/node_modules/node-red-dashboard/index.js:137:48)
    at new LEDNodeConstructor (/home/pi/.node-red/node_modules/node-red-contrib-ui-led/dist/nodes/ui_led/ui_led.js:30:29)
    at Object.createNode (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/util.js:87:27)
    at Flow.start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/Flow.js:206:48)
    at start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/index.js:371:33)
LED node...
Just sharing.
It's listed as an issue in the config node's git repo - I am seeing this when NR is starting. · Issue #75 · Adorkable/node-red-contrib-ui-led · GitHub
The poster - Just-another-pleb seems familiar to me...
CRAFT disease is a b!tch.
Ah Ah, so it is you :mag_right:
