Help why NR isn't starting
Yeah, I'm pushing the friendship with things recently.
I was going through updating NR on some machines.
Alas one is being annoying - as usual.
I'm getting this error when it starts:
TypeError: Cannot read property '_originalWires' of undefined
    at Subflow.start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/flows/Subflow.js:289:35)
    at Flow.start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/flows/Flow.js:207:41)
    at start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/flows/index.js:329:33)
    at tryCatchReject (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:845:30)
    at runContinuation1 (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:804:4)
    at Fulfilled.when (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:592:4)
    at Pending.run (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:483:13)
    at Scheduler._drain (/usr/lib/node_modules/node-red/node_modules/when/lib/Scheduler.js:62:19)
    at Scheduler.drain (/usr/lib/node_modules/node-red/node_modules/when/lib/Scheduler.js:27:9)
    at process._tickCallback (internal/process/next_tick.js:61:11)
Sorry, but what's happened?
I can't resolve a node that is causing the problem.
All I did was update a few nodes and import a working flow.
WHat did you actually do ?
Show us the NR startup logs so we can see versions etc
What platform and OS version is this running on ?
Craig
Hi @Trying_to_learn
you have hit an error in the internals of Node-RED. I cannot tell you what exactly it is or how it has been caused until I have time to step through the code and figure out what could cause this particular error.
Please let me know exactly what version of Node-RED you are running here.
(Though I see Nick is replying)
OS: Raspbian.
RasPiZW
I had NR installed and working.
I went through and updated some of the nodes which were old and very newer versions exist.
I also imported a small flow (generic) flow which I have on other machines.
This did mean I had to also install a couple of nodes which I didn't have installed - silly me.
(I try to have the same nodes on all machines to avoid this problem)
I deployed it and it just sat there.......
I SSH'ed into it and stopped NR.
I then restarted it and got that error.
Way above my skill set so I'll stop there and ask for help.
NR 1.0.3
(Extra to meet the 9 char minimum)
Need the logs from NR to show versions etc
@Trying_to_learn can you send me your full flow file as a private message? (Click on my photo, then click Message).
I can see what will cause this error, but it should not be possible for a flow to get into this state. If I can examine your flow file it will help me understand it.
Here is the start log from the CLI:
pi@EyeSpyPi:~ $ cd .node-red
pi@EyeSpyPi:~/.node-red $ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.0.89:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use   node-red-stop                          to stop Node-RED
Use   node-red-start                         to start Node-RED again
Use   node-red-log                           to view the recent log output
Use   sudo systemctl enable nodered.service  to autostart Node-RED at every boot
Use   sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
10 Mar 19:41:18 - [info]
Welcome to Node-RED
10 Mar 19:41:18 - [info] Node-RED version: v1.0.3
10 Mar 19:41:18 - [info] Node.js  version: v10.17.0
10 Mar 19:41:18 - [info] Linux 4.19.66+ arm LE
10 Mar 19:41:26 - [info] Loading palette nodes
10 Mar 19:41:55 - [info] Dashboard version 2.11.0 started at /ui
10 Mar 19:41:55 - [warn] ------------------------------------------------------
10 Mar 19:41:55 - [warn] [node-red-node-serialport/serialport] Error: The module '/home/pi/.node-red/node_modules/serialport/build/Release/serialport.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 57. This version of Node.js requires
NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
10 Mar 19:41:55 - [info] Settings file  : /home/pi/.node-red/settings.js
10 Mar 19:41:55 - [info] HTTP Static    : /home/pi/.node-red/public
10 Mar 19:41:55 - [info] Context store  : 'default' [module=memory]
10 Mar 19:41:56 - [info] User directory : /home/pi/.node-red
10 Mar 19:41:56 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
10 Mar 19:41:56 - [info] Flows file     : /home/pi/.node-red/flows_EyeSpyPi.json
10 Mar 19:41:56 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
10 Mar 19:41:57 - [info] Starting flows
10 Mar 19:42:00 - [info] Started flows
10 Mar 19:42:00 - [info] [mqtt-broker:8a5ef823.065db] Connected to broker: mqtt://192.168.0.99:1883
10 Mar 19:42:00 - [info] [mqtt-broker:2aaf8a6b.d7e346] Connected to broker: mqtt://192.168.0.99:1883
10 Mar 19:42:00 - [info] [mqtt-broker:d028257b.41f338] Connected to broker: mqtt://192.168.0.99:1883
10 Mar 19:42:00 - [info] [mqtt-broker:ebc78e73.3c2d3] Connected to broker: mqtt://192.168.0.99:1883
10 Mar 19:42:00 - [info] [mqtt-broker:1f271f30.f42d11] Connected to broker: mqtt://192.168.0.99:1883
10 Mar 19:42:00 - [info] [mqtt-broker:db5ef6f3.10c5d] Connected to broker: mqtt://192.168.0.99:1883
(Sorry not wanting to flood with multiple posts.)
Nick, here's a kicker (rub?):
The flow(s) were too big to send as one.
I tried to .zip them, but that isn't accepted.
I then was going to send you each (only 2) flow one at a time.
Node-Red had to be started in SAFE mode.
Alas while doing that I accidentaly added an unwanted node onto the screen.
Out of habit, I deleted the node and pressed the deploy button.
Now it works.
(There is another very underlying problem) of which I don't want to abuse the offer of help.)
I really REALLY appreciate you offered.
But now it is working.
Do you still want me to post the flow/s?
(ARGH! Got another problem on another machine.
Need to go off line and get that machine looked at with a real screen, etc.)
If it is now working then your flows won't help me understand what probably you were hitting.
But if its working then we can all move on.
