I can easily and conveniently add an npm module to a function node.
Is it possible to use a github version of a module?
David
David
Not directly.
I haven't done it before but you could try installing the module from github using the the NPM CLI then try importing it.
e.g..
cd ~/.node-red
npm install https://github.x.y.z
Please let us know if you try and if it works ![]()
Doesn't appear to work unfortunately. Doesn't seem to use the GitHub prefix in the way that npm itself does.
Would be a good feature request I think.
Steve's suggestion worked though 'I think' it's quite intricate to be sure -![]()
My situation was as follows -:
Created two repos -: Module1-Node-red and Module2. Module1-Node-red depended on Module2. (Module2 existed on NPM but I had modified)
Then added Module2 to a function.
When I restarted node-red Module2 was overwritten to become the npm version.
I think using Steves approach of add module2 from my github on its own worked
