Here is my code snippet for initializing my flow variable:
var a = new Array(65);
flow.set("myArray",a);
In a Function Node I want to add the msg.payload to the myArray flow variable until I fill up the array.
How do I write the correct syntax to add it to the Flow variable?
Something like flow.set.push("myArray",msg.payload); ?????
Firstly it is generally recommented to use var a = [35];
rather than using new Array. Which is easily misunderstood. For example new Array(35,60);
may not do what you expect. The simplest way to add a new element is probably
a = flow.get("myArray");
a.push(msg.payload);
flow.set("myArray", a);
If you really want to get it in one statement then flow.set("myArray", flow.get("myArray").push(msg.payload));
