Hi There,
I have a use case whereby it would be useful to have the junction nodes as part of a search result. It's very obscure so no surprise that junction nodes aren't part of the search results.
To illustrate my use case:
Here I'm comparing two versions of my flow and the sidebar is showing a wire difference
Each wire is a node id so in this case node id 1fb88a2c8e3e0418 has been replaced by d75c060fc66713cd - turns out I replaced one junction node for another but that's not recognisable from the node id (which happens to be a junction node).
Because I didn't know it was a junction node, I did a search for the node id but I got zero results which is unusual since node ids are indexed by the search:
So this is a bit confusing until I realised that it's a junction node:
I know it's a minor and obscure use-case but perhaps there is a reason for not including junctions in search results (probably because of the number of potential junctions) or whether it's actually something that has been missed and never asked for.
Cheers!
