To close this out, what I got to work was a Nodered MQTT in node connected to topic reading a parsed JSON object:
[{"Temperature":57.4, "Humidity": 45.6},{"Location:" "RV"}]
It passed that msg payload to an Influxdb out node which received it as an array of 2 objects:
environmentTopic : msg.payload : array[2]
array[2]
0: object
Temperature: 60.7
Humidity: 40.6
1: object
My data in the database still looks basically the same, but if I show tags in the database I see:
show tag keys
tagKey
Location
> show tag keys
tagKey
Location
So I think I have it right??
I think this is my confirmation. The output from the select shows before Location was tag and after:
select * from environment group by Location limit 3
tags: Location=
time Humidity Location Temperature
1610056066283658222 46.6 RV 57.7
1610056126445212027 46.6 RV 57.7
1610056186564122372 46.7 RV 57.7
tags: Location=RV
1610113254370362806 45.6 57.4
1610113314536607421 44.9 57.7
1610113374705172706 44.3 58.1
Colin
8 January 2021 14:52
23
Yep, that looks good.
If you use Grafana for drawing charts note that there is a mechanism in there for defining a chart and providing a list of rooms, it will then auto-generate a set of charts, one for each room.
