Align two charts perfectly?
How can I make the y-axes of the two charts perfectly align vertically, so that both x-axes' markings are aligned perfectly?
The y-axes positions (meaning: the vertical lines at the leftmost x value which is identical for both charts) should be at the same x-position regardless of the numbers that are displayed to the left of the y-axes.
Try sending a message like so:
msg.ui_update = {
  grid: {
    left: 80,    // Force a fixed pixel width for the left margin
    right: 20,   // Do the same for the right to align the end-points
    containLabel: false // Optional: manual control is often more precise
return msg
to both charts.
(untested)
Thanks for caring & trying to help, @Steve-Mcl, much appreciated!
However, this did something very weird: The y-axes' scales are now wayyyyy off:
Granted, the y-axes are aligned now but why did the scale change so much? And why are there those peaks with values that never came from the data source? :face_with_monocle:
I'll try and study the docs!
UPDATE:
I think I know what happened! :man_facepalming:
I used an inject node in front of a function node to trigger this message. The inject node transported the default timestamp in msg.payload and this got transported to the chart somehow.
However, after I removed the timestamp from the inject node (so that msg.payload is empty I assume?) the sent msg.ui_update did nothing to the chart. :thinking:
Update on Steve's suggestion: send this for the first chart only
msg.ui_update = {chartOptions: grid: {left: '10%'} }
The 10% will require adjustment until the y Axis grid line lines up with chart 2. This will move the left hand side. The only downside is that the y axis label also moves.
or format the y axis label
msg.ui_update = {chartOptions: yAxis: {axisLabel: {formatter: ' {value} '}}}
again, adjust the number of spaces until the y axis line up
Okay, just a quick update.
Because I'm totally new with the Dashboard 2 module I had to learn first this msg.ui_update thing.
After a few wrong tries of sending msg.ui_update with these JSON object variants ...
   grid: { left: 200 }
   "grid": { "left": 200 }
   "options": {
and then studying the documentation thoroughly I finally learned (from here) that the correct version is:
   "chartOptions": {
Good. The 200 was just an example to see if I can reach to the chart at all.
Then I tried the "10%" option but needed to set it for both charts. There was no miraculous automagic adjustment of the 2nd chart's y-axis after I applied the "left": "10%" to the 1st chart only.
Having both at 10% left kinda works. But only on large enough screens.
When I look at the dashboard on my iPhone in portrait orientation the y axes are still/again not alinged properly. :face_with_monocle: To fix this I needed to got as high as "left": "22%" – but that looks really bad on the big screen again ... :unamused_face:
So, any further suggestions very welcome. :blush:
Thanks so far, folks!! :heart:
EDIT: I'm investigating two y-axes in one chart next so I can put both curves into the same, single chart.
Have you tried this? (Note spaces before & after {value})
Thank, @Buckskin, I tried it now. Took me a while to understand the concept (again: totally new to Dashboard 2) but thanks to the docs and some experimenting I was able to achieve a satisfying solution now! :blush:
This is the JSON I'm sending to the first chart only now:
    "chartOptions": {
        "yAxis": {
            "axisLabel": {
                "formatter": "           {value}"
(Those are 11 space characters in front of the {value}. :see_no_evil_monkey:)
Looks acceptable now on the big screen:
... and on the iPhone display, too – in portrait and in landscape! :+1:
So I'd say: case closed. (Although I'd love to have an option "align y-axes" I could simply set to true which does everything for me. :man_shrugging:)
