All my subflows in the Palette have changed to the same colour after 4.1.6
I've just updated to 4.1.6. After Node Red restarted, my subflows have all changed to the same colour in the Palette (different colour on each instance).
Each of my Node Red instances has the same issue once upgraded. When I drag and drop the subflow node , it reverts back to the colour I defined for it , just not in the Palette.
I've tried editing the subflow template , edit properties, then colour , deploy , which seems to work, then reverts after editing a few subflow templates (seems random how many and which ones).
Obviously, I can restore, but wondered if someone has come across this or if this is something new in 4.1.6?
From which version?
Probably Allow palette.theme to be set via theme plugin and include icons by knolleary · Pull Request #5500 · node-red/node-red · GitHub
I've raised Subflow custom colours not applying since 4.1.6 · Issue #5512 · node-red/node-red · GitHub for this. Certainly not an intentional change in behaviour.
Hi GogoVega, I upgraded from 4.1.5
Thank you. Do I need to add any details?
Just looked at Theme Plugins : Node-RED don't think i did that, just upgraded.
Hi, I think knolleary has created a Fix (not done this B4 so not sure) how do I apply it?
@usherwdp I'll be publishing 4.1.7 tomorrow with the fix in
Thank you!!
Hello ! Possible to have a look at the multer CVE also for 4.1.7 ? Thanks !
just saw it was updated on master, thanks !
