An improvement to working with git projects
I recently switched to using the projects feature but felt it didn't give me a real benefit as far as version control goes because everything is squashed together in a single .json file.
I couldn't see any good solutions for this problem out there, so I built a flow to help with that. It runs in the background and splits all flows into separate, well readable .yml files every time a deployment is made.
These files can then be separately committed any time changes are made to a specific flow. This allows a better overview of the changes at the project level where you can see which flows have been changed, removed or added. Also function nodes are multiline, so changes in a function can be easier identified line by line in a diff.
The goal was mostly better organization of git repositories but it also offers the ability to revert a single .yml file to any point in time and to then merge it back into the main flows.json file.
Node Project Flow Splitter - Export flows to separate YAML files
That might make a great Node-RED plugin or custom node! :slight_smile:
That's very interesting.
Reminds me of this: node-red-contrib-flow-manager (node) - Node-RED (nodered.org) .
This one is also related: node-red-flow2src (node) - Node-RED (nodered.org)
I've never tried to use those, especially the first one looked too complex for me :slight_smile:
But with your solution it is much easier to see what's happening, and I don't need to install new nodes.
Some small things:
  • The 'Get flows' http request node has a URL field filled in, but the input message also contains msg.url. That override will trigger a warning in Node-RED 4 beta 1.
  • Personally I like to limit the number of rules in a change node, you could use a JSONata expression to simplify some things. For example to build the last API string: apiHost & '/flow/' & payload.id.
BTW, I encountered two practical issues using when trying out this flow.
  • when I use the roll back action, the affected tab moves to the end of the tab row
  • you have to remember to edit the name of the tab to roll back, and deploy, before pulling/editing a specific yml file
Yeah I looked at node-red-contrib-flow-manager too. It can handle subflows, which mine doesn't do yet but also seems to be geared towards a more advance use case than just prettying up your git repo.
Thanks, it's fixed now. I'm already getting these messages on 3.1.7 but that one must have slipped through when I was finishing up.
I suppose that's a consequence of going through the admin API instead of working with the json file directly.
Your're right. I wasn't sure what you meant by this and then promptly made that exact mistake. If I go to edit the injection node with the name of the file I want to restore it will of course overwrite that file again. A solution for this would be a mechanism that prevents the file watch node from triggering when the flow is first deployed but the only way I can think of would be using a "inject once" node and those don't trigger when you're only deploying only modified flows, so that would only work when you're doing a full deploy every time.
