[ANNOUNCE] node-red-contrib-jsontohtml
Hi folks,
I was re-installing one of my Raspberry devices, and I found some custom nodes on it that were about 95% finished. I have such nodes lying around all over the place. It it is a very bad habbit. I should reserve some time to finalize the last 5% instead of starting with something new ...
Anyway I have quickly published one of those nodes on NPM ( :champagne: :clinking_glasses:):
This node-red-contrib-jsontohtml node allows you transform a Javascript object to HTML, based on a specified transformation.
On the readme page you can find an example, where I inject an object (containing the statusses of various sensors):
Which is then transformed to HTML.
This allows me to show a popup dialog in my Node-RED dashboard very easily:
Have fun with it!!
Bart
Errr why wouldn't I just use a template node ?
That sounds not like a motivational contribution speech...
Do you mean to write the html manually in a template node? Or is there perhaps a standard way to convert json to html, which I'm not aware of?
Yes - that is exactly what the template node has been doing for the last 6 years...
[{"id":"21d27fe8.709f9","type":"inject","z":"ab9333b5.f44f6","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"name\":\"Front door\",\"status\":\"OPEN\"},{\"name\":\"Kitchen door\",\"status\":\"CLOSED\"},{\"name\":\"Bathroom window\",\"status\":\"CLOSED\"}]","payloadType":"json","x":100,"y":2080,"wires":[["2a4f2827.5def58"]]},{"id":"2a4f2827.5def58","type":"template","z":"ab9333b5.f44f6","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Notifications: \n{{#payload}}\n<li>{{name}} - <b>{{status}}</b></li>\n{{/payload}}","output":"str","x":260,"y":2080,"wires":[["97a3b8b1.c7c538","8dcd2d7f.40e3e"]]},{"id":"97a3b8b1.c7c538","type":"debug","z":"ab9333b5.f44f6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":450,"y":2120,"wires":[]},{"id":"8dcd2d7f.40e3e","type":"ui_toast","z":"ab9333b5.f44f6","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"","raw":true,"topic":"","name":"","x":450,"y":2080,"wires":[[]]}]
OMG...
Never seen this kind of functionality before ...
I will put your example on my readme page, and explain that is the standard way to go...
Thanks for the example!
:slight_smile: .... w do warn folk to discuss things here before diving in and writing loads of code... ah well as long as you enjoyed yourself.
This must be one of my first custom nodes. Have used it since I started with Node-RED, and never have seen something similar passing by in the discussions that I follow. So it hasn't come up my mind that there was anything to discuss about it ...
Anyway I have updated the readme:
And added your example:
It now looks more like a advertising brochure for the Template node :wink:
:-). Stick to SVG goodness.
