Node-red dashboard ui template : How to update the value of ui template html label
Hello. Recently I tried to use ui template in addition to my usual dashboard feature, then I came across
this material
(many thanks to @E1cid !!!)
I tried to send a payload from the html back to node-red but it seems I don't know how to updates the value itself. The sent payload still send me "text1" which is the initial payload I sent to the html, even tho I have changed it to other string. Could someone tell me how to update those value? Many thanks!
        "id": "9c0950b1.c61b1",
        "type": "inject",
        "z": "54a8ecc484312545",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "chart1",
        "payload": "[\"text1\"]",
        "payloadType": "json",
        "x": 180,
        "y": 620,
                "4bc18ffc.98da38"
        "id": "4bc18ffc.98da38",
        "type": "function",
        "func": "var sendButton = \" <script> var value = document.getElementById(\\\"w0\\\").value; this.scope.action = function() { return value; } </script> <md-button ng-click= \\\"send({ payload: action() })\\\"> Click here to send the data </md-button>\"\n\n\n\nvar html = \"\";\nfor (var i in msg.payload){\n    html = html + '<label for=\"w' + i + '\">A title ' + i + '</label><textarea id=\"w' + i + '\" name=\"w' + i + '\" rows=\"4\" cols=\"50\">' + msg.payload[i] + '</textarea>';\n}\n\n\nmsg.template = html + sendButton ;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 450,
        "y": 680,
                "2b69d2df.753636",
                "2442314b13d75244"
        "id": "2b69d2df.753636",
        "type": "ui_template",
        "group": "165e1e1a.e752fa",
        "order": 2,
        "width": 0,
        "height": 0,
        "format": "",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 630,
        "y": 680,
                "ea3caac460682f1b"
        "id": "2442314b13d75244",
        "type": "debug",
        "name": "debug 5",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "template",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 620,
        "y": 620,
        "id": "ea3caac460682f1b",
        "type": "debug",
        "name": "debug 4",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 820,
        "y": 680,
        "id": "165e1e1a.e752fa",
        "type": "ui_group",
        "name": "Default",
        "tab": "f9b58883.fa613",
        "order": 1,
        "disp": true,
        "width": "12",
        "collapse": false
        "id": "f9b58883.fa613",
        "type": "ui_tab",
        "name": "Home",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
Had a quick look, not got a lot of time this morning, but i will take a look this evening.
Thank you! Im kinda confused on how this function work out lol
Made some slight changes in the button and deselected two opitions in the template config.
This is sending for me
[{"id":"9c0950b1.c61b1","type":"inject","z":"eb90474bf03634f2","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"chart1","payload":"[\"text1\"]","payloadType":"json","x":120,"y":120,"wires":[["4bc18ffc.98da38"]]},{"id":"4bc18ffc.98da38","type":"function","z":"eb90474bf03634f2","name":"","func":"var sendButton = '<script>  this.scope.action = function() {var value = document.getElementById(\"w0\").value; return value; } </script> <md-button ng-click=\"send({ payload: action() })\"> Click here to send the data </md-button>'\n\n\n\nvar html = \"\";\nfor (var i in msg.payload){\n    html +=  '<label for=\"w' + i + '\">A title ' + i + '</label><textarea id=\"w' + i + '\" name=\"w' + i + '\" rows=\"4\" cols=\"50\">' + msg.payload[i] + '</textarea>';\n}\n\n\nmsg.template = html + sendButton ;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":180,"wires":[["2b69d2df.753636","2442314b13d75244"]]},{"id":"2b69d2df.753636","type":"ui_template","z":"eb90474bf03634f2","group":"165e1e1a.e752fa","name":"","order":2,"width":0,"height":0,"format":"","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","className":"","x":570,"y":180,"wires":[["ea3caac460682f1b"]]},{"id":"2442314b13d75244","type":"debug","z":"eb90474bf03634f2","name":"debug 5","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"template","targetType":"msg","statusVal":"","statusType":"auto","x":560,"y":120,"wires":[]},{"id":"ea3caac460682f1b","type":"debug","z":"eb90474bf03634f2","name":"debug 4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":760,"y":180,"wires":[]},{"id":"165e1e1a.e752fa","type":"ui_group","name":"Default","tab":"f9b58883.fa613","order":1,"disp":true,"width":"12","collapse":false},{"id":"f9b58883.fa613","type":"ui_tab","name":"Home","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
[edit] Miss read question.
your issue is the getElementById() is not inside the callback function. Edited example above.
Thanks! That solve everything! I'm sorry but, could you also tell me how to include two tab contents in the payload ? I tried to use document.querySelectorAll() to include both w0 and w1 for example but the payload give me unidentified payload. I might be missing something.
the flow i've tried :
[ { "id": "2b69d2df.753636", "type": "ui_template", "z": "58de72f1d81d5e3d", "group": "165e1e1a.e752fa", "name": "", "order": 1, "width": 0, "height": 0, "format": "", "storeOutMessages": false, "fwdInMessages": false, "resendOnRefresh": true, "templateScope": "local", "className": "", "x": 920, "y": 260, "wires": [ [ "ea3caac460682f1b" ] ] }, { "id": "ea3caac460682f1b", "type": "debug", "z": "58de72f1d81d5e3d", "name": "debug 4", "active": true, "tosidebar": true, "console": false, "tostatus": false, "complete": "false", "statusVal": "", "statusType": "auto", "x": 1120, "y": 140, "wires": [] }, { "id": "4b876e71e6de9cde", "type": "inject", "z": "58de72f1d81d5e3d", "name": "", "props": [ { "p": "payload" }, { "p": "topic", "vt": "str" } ], "repeat": "", "crontab": "", "once": false, "onceDelay": 0.1, "topic": "chart1", "payload": "[\"text1\", \"text2\"]", "payloadType": "json", "x": 380, "y": 260, "wires": [ [ "d9ade26944d4ae16" ] ] }, { "id": "d9ade26944d4ae16", "type": "function", "z": "58de72f1d81d5e3d", "name": "", "func": "var sendButton = '<script> this.scope.action = function() {var value = document.querySelector(\"#w1\").value; return value; } </script> <md-button ng-click=\"send({ payload: action() })\"> Click here to send the data </md-button>'\n\n\n\nvar html = \"\";\nfor (var i in msg.payload){\n html += '<label for=\"w' + i + '\">Kolom ' + i + '</label><textarea id=\"w' + i + '\" name=\"w' + i + '\" rows=\"4\" cols=\"50\">' + msg.payload[i] + '</textarea>';\n}\n\n\nmsg.template = html + sendButton ;\nreturn msg;", "outputs": 1, "noerr": 0, "initialize": "", "finalize": "", "libs": [], "x": 600, "y": 260, "wires": [ [ "2b69d2df.753636" ] ] }, { "id": "fa1ebd61fb906691", "type": "function", "z": "58de72f1d81d5e3d", "name": "", "func": "var sendButton = '<script> this.scope.action = function() {var value = document.querySelector(\"#w0\").value; return value; } </script> <md-button ng-click=\"send({ payload: action() })\"> Click here to send the data </md-button>'\n\n\n\nvar html = \"\";\nfor (var i in msg.payload){\n html += '<label for=\"w' + i + '\">Kolom ' + i + '</label><textarea id=\"w' + i + '\" name=\"w' + i + '\" rows=\"4\" cols=\"50\">' + msg.payload[i] + '</textarea>';\n}\n\n\nmsg.template = html + sendButton ;\nreturn msg;", "outputs": 1, "noerr": 0, "initialize": "", "finalize": "", "libs": [], "x": 600, "y": 200, "wires": [ [] ] }, { "id": "f010527b6888f444", "type": "function", "z": "58de72f1d81d5e3d", "name": "", "func": "var sendButton = '<script> this.scope.action = function() {var value = document.querySelectorAll(\"#w0, w1\").value; return value; } </script> <md-button ng-click=\"send({ payload: action() })\"> Click here to send the data </md-button>'\n\n\n\nvar html = \"\";\nfor (var i in msg.payload){\n html += '<label for=\"w' + i + '\">Kolom ' + i + '</label><textarea id=\"w' + i + '\" name=\"w' + i + '\" rows=\"4\" cols=\"50\">' + msg.payload[i] + '</textarea>';\n}\n\n\nmsg.template = html + sendButton ;\nreturn msg;", "outputs": 1, "noerr": 0, "initialize": "", "finalize": "", "libs": [], "x": 600, "y": 320, "wires": [ [] ] }, { "id": "165e1e1a.e752fa", "type": "ui_group", "name": "Default", "tab": "f9b58883.fa613", "order": 1, "disp": false, "width": 12, "collapse": false, "className": "" }, { "id": "f9b58883.fa613", "type": "ui_tab", "name": "Home", "icon": "dashboard", "order": 1, "disabled": false, "hidden": false } ]
The first fuction return w0, (using document.querySelector("#w0").value)
The 2nd function return w1, (using document.querySelector("#w1").value)
The 3rd function should be returning both w0 and w1, but it doesn't work as intended. ( using document.querySelectorAll("#w0, w1").value)
[edit]
Inserting the node code and output description
Try
var sendButton = `<script>
  var value = document.querySelectorAll("#w0,#w1");
  value = Object.values(value).map(element => element.value)
  return value; }
</script>
<md-button ng-click="send({ payload: action() })"> Click here to send the data </md-button>`
A perfect artwork. Thank you very much. I hope you have a good day!
