[ANNOUNCE] node-red-contrib-postgres v2.0.0 — Full TypeScript PostgreSQL toolkit for Node-RED
After a complete TypeScript rewrite, I'm publishing v2.0.0 of my PostgreSQL node set for Node-RED.
This started as a fork of node-red-contrib-postgrestor by doing-things-with-node-red. It has since grown into a production-grade toolkit: three nodes covering everything from simple queries to LISTEN/NOTIFY streaming and bulk COPY operations.
What's in the box
Three nodes, one config:
  • PostgresDBNode — Connection config with pool health badge (active / idle / waiting / total visible on the node)
  • PostgresNode — Execute SQL with Mustache templates, parameterized queries, transactions, cursor streaming, and COPY
  • PostgresListenerNode — Push real-time NOTIFY events into your flow with automatic reconnection
Features worth mentioning
  • Parameterized queries via msg.params → $1, $2, ... (no SQL injection)
  • Named parameters — {id: 42, name: "Alice"} auto-bound in insertion order
  • Mustache templates — SELECT * FROM {{msg.table}} for dynamic table/column names
  • Multi-step transactions — Pass an array of {query, params, output} and get BEGIN → COMMIT or ROLLBACK
  • Cursor streaming — DECLARE / FETCH large result sets in configurable batches, no memory blowup
  • COPY import/export — High-speed CSV via PostgreSQL COPY protocol
  • Self-healing retry — Deadlocks (40P01), serialization failures, and connection drops retry with jittered backoff
  • Full SSL — sslmode, CA cert, client cert/key — RDS, Azure, Supabase ready
  • Structured errors — msg.error.code, .detail, .constraint, .table
  • Query timeout — Per-node SET statement_timeout with guaranteed reset
  • Type mapping — NUMERIC→number, TIMESTAMPTZ→ISO, JSONB→object
  • Prepared statements — Auto-named via MD5 hash, zero configuration
  • 7 example flows included in the package
The original node-red-contrib-postgrestor was solid but had accumulated bitrot — outdated dependencies, no TypeScript, no tests, and several correctness issues around connection handling and listener reconnection. Rather than patching individual bugs forever, I rewrote the entire thing in TypeScript with 137 Jest tests and a clean architecture. Every feature has test coverage. The listener node no longer silently drops connections.
Quick example
[Inject] → [PostgresDBNode] → [PostgresNode] → [Debug]
PostgresNode SQL:
  INSERT INTO users (name, email) VALUES ($1, $2)
  RETURNING id, name, created_at
Inject payload:
  {"params": ["Jane Doe", "jane@example.com"]}
For transactions, just flip the "Transaction Mode" toggle and send an array:
{"payload": [
  {"query": "INSERT INTO users VALUES($1, $2)", "params": {"id": 1, "name": "Ada"}, "output": true},
  {"query": "INSERT INTO logs VALUES($1)", "params": {"action": "user_created"}}
Requirements
  • Node.js >= 18
  • Node-RED >= 3.0.0
  • PostgreSQL — any recent version
Install
npm install @topcs/node-red-contrib-postgres
Or use the Palette Manager → search @topcs/node-red-contrib-postgres.
