[ANNOUNCE] node-red-contrib-ui-reef
Hi Community,
I wanted to share a project I've been working on now that it's public!
This project is designed with the focused intent of creating a Node-RED aquarium controller, but might also be applicable to hydroponics. Visual and functional design has been minimized to make configuration as easy as possible for DIY aquarium hobbyists.
*Image is my reef tank running these nodes
It needs to be stated the output and input nodes are a highly modified fork of node-red-contrib-ui-multistate-switch. Although visually similar, these nodes are functionally quite different and are not meant to be a replacement. If flexibility and customization are important to you, node-red-contrib-ui-multistate-switch should be used instead.
Hopefully these nodes are useful for other members of the Node-RED community!
Hi, thank you for more nodes supporting the dashboard.
I don‘t own a fish tank any more but tree ponds. But even for other projekts the nodes could be useful.
I like the trail value display and your mixed input and actual status nodes. Think the nodes could get a broader audience if not target specific to fish tanks.
Will definitely take a look.
Chris
