Thank you
Yes the pi 4 is noticeably faster but im still suprised how usable a pi 3b is.
There is one caveat right now when using docker. I just found a bug that when you try to restart the wait-wake node it will hang and leave orphaned processes behind that can only be killed from htop.
So PSA:
Dont use wait wake with docker installs right now but if you do be aware that you cant properly stop the process and this also is true for restarting the flows or stopping nodered, it will work but you will have to kill it manually from htop if you redeploy, restart, stop nodered.
If possible just use the deb package as this has none of those problems
