Another PID Question!
Hi!
I'm facing a problem with node-red-contrib-pid and hope someone could help.
Trying to set prop_band, t_integral and t_derivative dynamically with sliders, but it always return NaN.
Already tried to use function using parseFloat(), parseInt() and Number(), but nothing seems to work.
Tried to change topics respectively and nothing. Changing setpoint this way works flawlessly, like github's instructions. (https://github.com/colinl/node-red-contrib-pid)
Am I missing something?
Here goes my flow:
        "id": "3f34ddb2.94b5d2",
        "type": "PID",
        "z": "e333e368.cd6728",
        "setpoint": "{{msg.setpoint}}",
        "pb": "20",
        "ti": "18",
        "td": "5",
        "integral_default": "0",
        "smooth_factor": "0",
        "max_interval": 600,
        "enable": "1",
        "disabled_op": "0",
        "x": 870,
        "y": 520,
                "65d53a91.d558d4",
                "d02b8ccf.486458"
        "id": "9e63b7e.becbd48",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "op",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1240,
        "y": 740,
                "44cba9ee.7d461"
        "id": "b3f10dab.14a9a8",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "pv",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1340,
        "y": 280,
                "3fd987a3.1ebde",
                "d899a640.cbaaf"
        "id": "65d53a91.d558d4",
        "type": "range",
        "minin": "0",
        "maxin": "1",
        "minout": "0",
        "maxout": "100",
        "action": "clamp",
        "round": false,
        "property": "payload",
        "name": "Scale power",
        "x": 1065.5,
        "y": 740,
                "9e63b7e.becbd48"
        "id": "ed31425b.8d2ae",
        "type": "inject",
        "name": "Clear chart on deploy",
        "topic": "",
        "payload": "{\"data\":[]}",
        "payloadType": "json",
        "repeat": "",
        "crontab": "",
        "once": true,
        "x": 1080,
        "y": 520,
                "10c04cdd.5e9aa3"
        "id": "10c04cdd.5e9aa3",
        "type": "change",
        "rules": [
                "t": "move",
                "p": "payload.data",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1330,
        "y": 520,
                "3fd987a3.1ebde",
                "410a9153.40665",
                "d899a640.cbaaf",
                "f73ad641.28df9"
        "id": "b2b4bc76.24d538",
        "type": "mqtt in",
        "topic": "FW_32778_Raspi",
        "qos": "0",
        "datatype": "utf8",
        "broker": "a033e667.fd62",
        "x": 600,
        "y": 280,
                "b3f10dab.14a9a8",
                "3f34ddb2.94b5d2"
        "id": "410a9153.40665",
        "type": "ui_chart",
        "group": "c85e2ebf.4c9d3",
        "order": 0,
        "width": "6",
        "height": "6",
        "label": "PWM",
        "chartType": "line",
        "legend": "false",
        "xformat": "HH:mm:ss",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "0",
        "ymax": "100",
        "removeOlder": "3",
        "removeOlderPoints": "",
        "removeOlderUnit": "60",
        "cutout": 0,
        "useOneColor": false,
        "colors": [
            "#1f77b4",
            "#cf0005",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "useOldStyle": false,
        "outputs": 1,
        "x": 1690,
        "y": 740,
        "id": "d899a640.cbaaf",
        "type": "ui_chart",
        "group": "61a0933f.100cc4",
        "order": 1,
        "width": "6",
        "height": "6",
        "label": "Temperatura",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "0",
        "ymax": "100",
        "removeOlder": "3",
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#cf0005",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 1610,
        "y": 400,
        "id": "3fd987a3.1ebde",
        "type": "ui_gauge",
        "order": 1,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "Temperatura",
        "label": "ºC",
        "format": "{{value}}",
        "min": 0,
        "max": "100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1890,
        "y": 400,
        "id": "f8cbb9ef.053458",
        "type": "rpi-gpio out",
        "pin": "40",
        "set": "",
        "level": "0",
        "freq": "{{msg.payload}}",
        "out": "pwm",
        "x": 1700,
        "y": 800,
        "id": "f73ad641.28df9",
        "type": "ui_gauge",
        "order": 1,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "Resistência",
        "label": "%",
        "min": 0,
        "max": "100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1710,
        "y": 680,
        "id": "44cba9ee.7d461",
        "type": "function",
        "func": "var valor=msg.payload;\nvar potencia=valor.toFixed(2);\nmsg.payload=potencia;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1420,
        "y": 740,
                "f73ad641.28df9",
                "410a9153.40665",
                "f8cbb9ef.053458"
        "id": "ae4c27f7.ef9968",
        "type": "ui_slider",
        "name": "temperatura",
        "label": "Temp. alvo",
        "tooltip": "",
        "group": "9d458ea9.7be468",
        "order": 1,
        "width": "4",
        "height": "1",
        "passthru": true,
        "outs": "end",
        "topic": "setpoint",
        "min": 0,
        "max": "100",
        "step": 1,
        "x": 170,
        "y": 680,
                "b2d06217.1bb6a8",
                "2d50b265.062dc6",
                "3f34ddb2.94b5d2",
                "2b995adf.2b3cc6",
                "c2b2fa1e.edc8c8"
        "id": "b2d06217.1bb6a8",
        "type": "ui_text",
        "order": 5,
        "width": "2",
        "height": "1",
        "label": "",
        "format": "{{msg.payload}}ºC",
        "layout": "row-spread",
        "x": 380,
        "y": 680,
        "id": "2d50b265.062dc6",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "setpoint",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 400,
        "y": 560,
        "id": "4daa4ae8.640eb4",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "t_derivative",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 340,
        "y": 1080,
                "3f34ddb2.94b5d2",
                "2b995adf.2b3cc6",
                "c2b2fa1e.edc8c8"
        "id": "91d060cd.f01cc",
        "name": "ki",
        "label": "Ki",
        "tooltip": "",
        "order": 3,
        "width": "0",
        "height": "0",
        "passthru": true,
        "outs": "end",
        "topic": "",
        "min": 0,
        "max": "100",
        "step": "1",
        "x": 150,
        "y": 960,
                "6feb38f2.73ed28"
        "id": "14bf9a99.61b215",
        "name": "kp",
        "label": "Kp",
        "tooltip": "",
        "order": 2,
        "width": "0",
        "height": "0",
        "passthru": true,
        "outs": "end",
        "topic": "prop_band",
        "min": 0,
        "max": "100",
        "step": "1",
        "x": 150,
        "y": 880,
                "3f34ddb2.94b5d2",
                "2b995adf.2b3cc6",
                "c2b2fa1e.edc8c8"
        "id": "1a23d6ff.5a9349",
        "name": "kd",
        "label": "Kd",
        "tooltip": "",
        "order": 4,
        "width": "0",
        "height": "0",
        "passthru": true,
        "outs": "end",
        "topic": "t_derivative",
        "min": 0,
        "max": "100",
        "step": "1",
        "x": 150,
        "y": 1080,
                "4daa4ae8.640eb4"
        "id": "d02b8ccf.486458",
        "type": "debug",
        "name": "Always NaN! WTF?",
        "active": true,
        "tosidebar": true,
        "console": true,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "x": 1100,
        "y": 620,
        "id": "6feb38f2.73ed28",
        "type": "function",
        "func": "var temperaturaLida=global.get(\"temperaturaLida\")\nvar valor=parseFloat(msg.payload);\n\nmsg.topic=\"t_integral\";\nmsg.payload=parseInt(temperaturaLida);\nmsg.t_integral=valor;\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 310,
        "y": 960,
                "3f34ddb2.94b5d2",
                "2b995adf.2b3cc6",
                "c2b2fa1e.edc8c8"
        "id": "2b995adf.2b3cc6",
        "type": "PID",
        "name": "Trying1",
        "pb": "{{msg.prop_band}}",
        "ti": "{{msg.t_integral}}",
        "td": "{{msg.t_derivative}}",
        "enable": "1",
        "disabled_op": "0",
        "x": 860,
        "y": 840,
                "f2440e5f.c854c8"
        "id": "c2b2fa1e.edc8c8",
        "type": "PID",
        "name": "Trying2",
        "pb": "{{msg.payload}}",
        "ti": "{{msg.payload}}",
        "td": "{{msg.payload}}",
        "enable": "1",
        "disabled_op": "0",
        "x": 860,
        "y": 940,
                "d04c1a8d.13b808"
        "id": "f2440e5f.c854c8",
        "type": "debug",
        "name": "Still NaN!",
        "active": true,
        "tosidebar": true,
        "console": true,
        "tostatus": false,
        "complete": "true",
        "x": 1030,
        "y": 840,
        "id": "d04c1a8d.13b808",
        "type": "debug",
        "name": "Still NaN 2!",
        "active": true,
        "tosidebar": true,
        "console": true,
        "tostatus": false,
        "complete": "true",
        "x": 1040,
        "y": 940,
        "id": "a2d1f55d.778e",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "temperaturaLida",
                "tot": "global"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 920,
        "y": 1080,
        "id": "bc19fd08.656a",
        "type": "mqtt in",
        "qos": "0",
        "datatype": "utf8",
        "x": 700,
        "y": 1080,
                "a2d1f55d.778e"
        "id": "a033e667.fd62",
        "type": "mqtt-broker",
        "z": "",
        "name": "Raspberry pi",
        "broker": "localhost",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "compatmode": true,
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "willTopic": "",
        "willQos": "0",
        "willPayload": ""
        "id": "c85e2ebf.4c9d3",
        "type": "ui_group",
        "z": "",
        "name": "Resistência (PWM)",
        "tab": "403987b2.90d07",
        "order": 2,
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "61a0933f.100cc4",
        "type": "ui_group",
        "z": "",
        "name": "Temperatura",
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "9d458ea9.7be468",
        "type": "ui_group",
        "z": "",
        "name": "PID / Temp. alvo",
        "order": 3,
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "403987b2.90d07",
        "type": "ui_tab",
        "z": "",
        "name": "PID",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
This has been cross posted as an issue on the node, please ignore the question here.
