Any node that can send data to SD card?
Hi Everyone,
I looking to others node that can send data to SD card or thumb drive using node-red.
have any suggestion?
"send" you mean write ?
The pre-installed file nodes that can read/write data/files/directories from/to disks.
Note, if you are using node-red within docker, this may be more problematic to achieve.
This one?
Yes, those.
You will need/use the write file one.
Thanks for reply
