..and if so - with what Zigbee hub/controller thingy?
as I can't get mind to work with my Zigbee Echo Dot (it thinks its a light switch)
I don't have one of these but they are supported by zigbee2mqtt; SONOFF SNZB-01P control via MQTT | Zigbee2MQTT
If you ever get the matter stuff going you could make a virtual matter device using MQTT to set the values.
Alternatively, there is ZigBee matterbridge: GitHub - Luligu/matterbridge-zigbee2mqtt: Matterbridge zigbee2mqtt plugin that automatically converts all your ZigBee devices into matter devices.
I have the Zigbee 3.0 USB Dongle Plus–ZBDongle-E, connected with an Odroid-C2 and powered by Zigbee2MQTT
Do you use an SNZB-01P switch with it?
It is zigbee and that button is nothing exotic, it is supported by zigbee2mqtt
The dongles mentioned are coordinators, which are fairly standard. The sonoff dongle, specifically the P version works out of the box with z2m. The E version may need additional flashing. At the moment the SMLIGHT SLZB-06 may be the 'best' coordinator available on the market.
I found this. Don't know if it is relevant
In the plugin config add each switch device to the lightList or outletList if they don't show up like switch (Matterbridge uses a modified switch device type without client cluster that Alexa doesn't recognize).
I have used one of those for three years and have had absolutely no problems with it.
