Apexchart not working
i'm beginner on nodered and really not a sw engineer, i need a little help to use apexchart on my dash board, i'm working for the moment with a simple example.
Here the flow i'm using.
        "id": "884a673ddd60e8ec",
        "type": "ui_template",
        "z": "fb440a5f200684bb",
        "group": "46cbac0e09c696e8",
        "order": 0,
        "width": "24",
        "height": "10",
        "format": "<html>\n  \n<head>\n  <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n  <!-- <link rel=\"stylesheet\" href=\"https://maxcdn.bootstrapcdn.com/bootstrap/3.4.0/css/bootstrap.min.css\"> -->\n  <!-- <script src=\"https://ajax.googleapis.com/ajax/libs/jquery/3.4.0/jquery.min.js\"></script> -->\n  <!-- <script src=\"https://maxcdn.bootstrapcdn.com/bootstrap/3.4.0/js/bootstrap.min.js\"></script> -->\n  <script src=\"https://cdn.jsdelivr.net/npm/apexcharts\"></script>\n</head>\n\n<body>\n  <div id=\"chart\" style=\"width:900px\"></div>\n  <script>     \n        var options = {\n          series: [{\n            name: \"Desktops\",\n            data: [10, 41, 35, 51, 49, 62, 69, 91, 148]\n        }],\n        chart: {\n          type: 'line',\n          height: 350,\n          zoom: {\n            type: 'x',\n            enabled: true,\n            autoScaleYaxis: true\n          },\n          toolbar: {\n            autoSelected: 'zoom'\n          }\n        },\n        dataLabels: {\n          enabled: false\n        },\n        stroke: {\n          curve: 'smooth'\n        },\n        markers: {\n          size: 0,\n        },\n        title: {\n          text: 'Tank temperature',\n          align: 'left'\n        },\n        grid: {\n          row: {\n            colors: ['#f3f3f3', 'transparent'], // takes an array which will be repeated on columns\n            opacity: 0.5\n          },\n        },\n        xaxis: {\n          categories: ['Jan', 'Feb', 'Mar', 'Apr', 'May', 'Jun', 'Jul', 'Aug', 'Sep'],\n        }\n        };\n  setTimeout(()=> {\n\n    var chart = new ApexCharts(document.querySelector(\"#chart\"), options);\n    chart.render();\n  },1000) \n  </script>\n</body>\n\n</html>",
        "storeOutMessages": false,
        "fwdInMessages": true,
        "resendOnRefresh": false,
        "templateScope": "local",
        "className": "",
        "x": 480,
        "y": 120,
        "id": "4f1f5d23f0bda5db",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": "1",
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 220,
        "y": 120,
                "884a673ddd60e8ec"
        "id": "46cbac0e09c696e8",
        "type": "ui_group",
        "name": "Apexchart",
        "tab": "27c6cdce.0f2ff2",
        "order": 1,
        "disp": true,
        "width": "30",
        "collapse": false
        "id": "27c6cdce.0f2ff2",
        "type": "ui_tab",
        "name": "DA",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
But the toolbar are icons blue, also graph is are blue instead simple line, any idea where i'm wrong ?
thank in advance for any help / suggestion.
Some css clash with the dashboard's styles
Try "Use Anglular theme in ui_template"
Great,
thank a lot, now is working.
r.
