API call via NodeJS
An API provider is providing a connection example via NodeJS (I've been doing these through external python scripts). Is it simpler to do NodeJS ? Can it be run directly from template/function node?
/ Require taapi (using the NPM client: npm i taapi --save)
const taapi = require("taapi");
// Setup client with authentication
const client = taapi.client("MY_SECRET");
// Get the BTC/USDT RSI value on the 1 minute time frame from binance
client.getIndicator("rsi", "binance", "BTC/USDT", "1m").then(function(result) {
    console.log("Result: ", result);
// --- Or ---
// Require axios: npm i axios
var axios = require('axios');
axios.get('https://api.taapi.io/rsi', {
  params: {
    secret: "MY_SECRET",
    exchange: "binance",
    symbol: "BTC/USDT",
    interval: "1h",
.then(function (response) {
  console.log(response.data);
.catch(function (error) {
  console.log(error.response.data);
You don't need a function. This can be done in a graphical (low code) flow.
inject -> http request -> whatever
You will need to set the payload to JSON mode with the value set to the params your example has & set the http request node to use the payload as query parameters.
Hi, I am a bit confused. I have a running config that's: inject -> JSON parameters -> http request (but in the case, the API provider offered a JSON request option). This API provider is offering a javascript call. I am not sure where that goes in your example, and how can I manipulate it (i.e. change parameters) if it's not in a function? Do you mind giving me a flow example that allows me to input the stock variable (AAPL) via a msg. Thank you.
const finnhub = require('finnhub');
const api_key = finnhub.ApiClient.instance.authentications['api_key'];
api_key.apiKey = "ceahq1aad3i1o5buvh00ceahq1aad3i1o5buvh0g"
const finnhubClient = new finnhub.DefaultApi()
finnhubClient.supportResistance("AAPL", "D", (error, data, response) => {
  console.log(data)
Based on your first post, I can see from the axios code this is a http API. That's why I said "inject -> http request -> whatever"
The other code is(as you said don't a JavaScript call) but under the hood, all that is happening is a http request.
I will have a look in the morning (it is almost 1am here in the UK).
Thanks. This from the API provider. I added the api token to the http request node and it seems to be getting through but I don't know how to send proper request.
API Documentation
The API is organized around REST. Our API has predictable resource-oriented URLs, accepts form-encoded request bodies, returns JSON-encoded responses, and uses standard HTTP response codes, authentication, and verbs. This is 1 of the most comprehensive financial API available on the market.
Base URL: /api/v1
Swagger schema: Download
Authentication
All GET request require a token parameter token=apiKey in the URL or a header X-Finnhub-Token : apiKey. You can find your API Key under Dashboard. If you are logged in, your API key will be automatically used in the examples so you can copy and paste them as is.
And a bit the schema that's being referenced
  "swagger": "2.0",
  "info": {
    "version": "1.0.0",
    "title": "Finnhub API",
    "license": {
      "name": "Apache-2.0",
      "url": "https://www.apache.org/licenses/LICENSE-2.0.html"
  "host": "finnhub.io",
  "basePath": "/api/v1",
  "schemes": [
    "https"
  "securityDefinitions": {
    "api_key": {
      "type": "apiKey",
      "name": "token",
      "in": "query"
  "extraDocs": [
      "section": null,
      "subSection": [
          "navHeader": "Introduction",
          "urlId": "introduction",
          "summary": "API Documentation",
          "description": "<p class=\"lead\">The API is organized around REST. Our API has predictable resource-oriented URLs, accepts form-encoded request bodies, returns JSON-encoded responses, and uses standard HTTP response codes, authentication, and verbs. This is 1 of the most comprehensive financial API available on the market.</p> <p><strong>Base URL</strong>: <code>/api/v1</code></p><p><strong>Swagger schema</strong>: <a target=\"_blank\" href=\"/static/swagger.json\">Download</a></p>"
          "navHeader": "Authentication",
          "urlId": "authentication",
          "summary": "Authentication",
          "description": "<p>All GET request require a token parameter <code>token=apiKey</code> in the URL or a header <code>X-Finnhub-Token : apiKey</code>. You can find your API Key under <a target=\"_blank\" href=\"/dashboard\">Dashboard</a>. If you are logged in, your API key will be automatically used in the examples so you can copy and paste them as is.</p>"
          "navHeader": "Limits",
          "urlId": "rate-limit",
          "summary": "Rate Limits",
          "description": "<p>If your limit is exceeded, you will receive a response with status code <code>429</code>.</p><p>On top of all plan's limit, there is a 30 API calls/ second limit.</p>"
          "navHeader": "Webhook",
          "urlId": "webhook",
          "summary": "Webhook",
          "highUsage": "High Usage",
          "description": "Subscribe to webhook events. You can setup webhook and test it in <a target=\"_blank\" href=\"/dashboard\">Dashboard</a>. Each user can subscribe up to 50 events.",
          "method": [
            "GET,POST"
          "examples": [
              "url": "/",
              "text": "/webhook:action"
          "arguments": null,
          "responseAttributes": [
              "name": "event",
              "type": "string",
              "description": "Event type. We support real-time <code>earnings</code> events for US stocks at the moment."
              "name": "data",
              "type": "list",
              "description": "List of events."
          "sampleCode": {
            "autoGenerated": false,
            "javascript": "",
            "go": "",
            "python": "import requests\n\n# Register new webhook for earnings\nr = requests.post('https://finnhub.io/api/v1/webhook/add?token=<token>', json={'event': 'earnings', 'symbol': 'AAPL'})\nres = r.json()\nprint(res)\n\nwebhook_id = res['id']\n# List webhook\nr = requests.get('https://finnhub.io/api/v1/webhook/list?token=<token>')\nres = r.json()\nprint(res)\n\n#Delete webhook\nr = requests.post('https://finnhub.io/api/v1/webhook/delete?token=<token>', json={'id': webhook_id})\nres = r.json()\nprint(res)\n\n"
          "sampleResponse": ""
          "navHeader": "Excel & Google Spreadsheet",
          "urlId": "excel-plugin-google-spreadsheet",
          "newEndpoint": "New Endpoint",
          "summary": "FinSheet Excel & Google Sheets plugin",
          "description": "<p><a href=\"https://finsheet.io/\" target=\"_blank\">Finsheet</a> is the official spreadsheet's plugin partner using fundamental data and estimates data from Finnhub. If you are looking to complement the stock price data you already got directly from Excel and Google Sheets with some advanced data, <a href=\"https://finsheet.io/\" target=\"_blank\">Finsheet's Excel and Google Sheets plugin</a> offer an affordable way to access global fundamentals and estimates right in your spreadsheet.</p><span><img src=\"https://finsheet.io/static/img/candles.png\"></img></span>"
      "section": "Open Source",
      "subSection": [
          "navHeader": "Libraries",
          "urlId": "library",
          "summary": "Libraries",
          "description": "<p>We have been incredibly humbled by the support of the open-source community. Beside these incredible projects, here are our own official libraries: </p><table class=\"table table-hover\">\n  <thead>\n    <tr>\n      <th>Language</th>\n      <th>Homepage</th>\n    </tr>\n  </thead>\n  <tbody>\n    <tr>\n      <td class=\"text-blue\">Python</th>\n      <td><a href=\"https://github.com/Finnhub-Stock-API/finnhub-python\" target=\"_blank\" rel=\"noopener nofollow\">finnhub-python</a></td>\n    </tr>\n    <tr>\n      <td class=\"text-blue\">Go</th>\n      <td><a href=\"https://github.com/Finnhub-Stock-API/finnhub-go\" target=\"_blank\" rel=\"noopener nofollow\">finnhub-go</a></td>\n    </tr>\n    <tr>\n      <td class=\"text-blue\">Javascript</th>\n      <td><a href=\"https://www.npmjs.com/package/finnhub\" target=\"_blank\" rel=\"noopener nofollow\">Finnhub NPM</a></td>\n    </tr>\n    <tr>\n      <td class=\"text-blue\">Ruby</th>\n      <td><a href=\"https://github.com/Finnhub-Stock-API/finnhub-ruby\" target=\"_blank\" rel=\"noopener nofollow\">Finnhub Ruby</a></td>\n    </tr>\n    <tr>\n      <td class=\"text-blue\">Kotlin</th>\n      <td><a href=\"https://github.com/Finnhub-Stock-API/finnhub-kotlin\" target=\"_blank\" rel=\"noopener nofollow\">Finnhub Kotlin</a></td>\n    </tr>\n    <tr>\n      <td class=\"text-blue\">PHP</th>\n      <td><a href=\"https://packagist.org/packages/finnhub/client\" target=\"_blank\" rel=\"noopener nofollow\">Finnhub PHP</a></td>\n    </tr>\n  </tbody>\n</table>"
          "navHeader": "Open Data",
          "urlId": "open-data",
          "summary": "Open Data",
          "description": "<p>We understand the importance of data for students, researchers,and investors. That's why at Finnhub, we have decided to create multiple Open Datasets for the community which can be downloaded in bulk below:</p><table class=\"table table-hover\">\n  <thead>\n    <tr>\n      <th>Datasets</th>\n      <th>Download</th>\n    </tr>\n  </thead>\n  <tbody>\n    <tr>\n      <td class=\"text-blue\">SEC Financials As Reported</th>\n      <td><a href=\"https://www.kaggle.com/finnhub/reported-financials\" target=\"_blank\" rel=\"noopener\">Kaggle</a></td>\n    </tr>\n    <tr>\n      <td class=\"text-blue\">SEC Filings Metadata</th>\n      <td><a href=\"https://www.kaggle.com/finnhub/sec-filings\" target=\"_blank\" rel=\"noopener\">Kaggle</a></td>\n    </tr>\n    <tr>\n      <td class=\"text-blue\">S&P 500 futures tick data</th>\n      <td><a href=\"https://www.kaggle.com/finnhub/sp-500-futures-tick-data-sp\" target=\"_blank\" rel=\"noopener\">Kaggle</a></td>\n    </tr>\n  </tbody>\n</table>"
      "section": "Websocket",
      "subSection": [
          "navHeader": "Trades",
          "urlId": "websocket-trades",
          "summary": "Trades - Last Price Updates",
          "title": "Websocket - Realtime streaming for US Full SIP, LSE, Forex and Crypto",
          "description": "<p>Stream real-time trades for US stocks, forex and crypto. Trades might not be available for some forex and crypto exchanges. In that case, a price update will be sent with volume = 0. A message can contain multiple trades. 1 API key can only open 1 connection at a time. Real-time US market data is provided by IEX. Cross-connect and real-time data for international markets are available for Enterprise clients via our partners. <a href=\"mailto:support@finnhub.io\">Contact us</a> to learn more.</p> <p>The following FX brokers do not support streaming: FXCM, Forex.com. To get latest price for FX, please use the Forex Candles or All Rates endpoint.</p>",
          "method": [
            "Websocket"
          "examples": [
              "url": "wss://ws.finnhub.io?token=<token>",
              "text": "wss://ws.finnhub.io"
          "arguments": null,
              "name": "type",
              "type": "string",
              "description": "Message type."
              "name": "data",
              "type": "list",
              "description": "List of trades or price updates.",
              "item": {
                "type": "object",
                "definition": "Trade",
                "attributes": [
                    "name": "s",
                    "type": "string",
                    "description": "Symbol."
                    "name": "p",
                    "type": "float",
                    "description": "Last price."
                    "name": "t",
                    "type": "int",
                    "description": "UNIX milliseconds timestamp."
                    "name": "v",
                    "type": "float",
                    "description": "Volume."
                    "name": "c",
                    "type": "list",
                    "description": "List of trade conditions. A comprehensive list of trade conditions code can be found <a target=\"_blank\" href=\"https://docs.google.com/spreadsheets/d/1PUxiSWPHSODbaTaoL2Vef6DgU-yFtlRGZf19oBb9Hp0/edit?usp=sharing\">here</a>",
                    "item": {
                      "type": "string"
          "sampleCode": {
            "javascript": "const socket = new WebSocket('wss://ws.finnhub.io?token=<token>');\n\n// Connection opened -> Subscribe\nsocket.addEventListener('open', function (event) {\n    socket.send(JSON.stringify({'type':'subscribe', 'symbol': 'AAPL'}))\n    socket.send(JSON.stringify({'type':'subscribe', 'symbol': 'BINANCE:BTCUSDT'}))\n    socket.send(JSON.stringify({'type':'subscribe', 'symbol': 'IC MARKETS:1'}))\n});\n\n// Listen for messages\nsocket.addEventListener('message', function (event) {\n    console.log('Message from server ', event.data);\n});\n\n// Unsubscribe\n var unsubscribe = function(symbol) {\n    socket.send(JSON.stringify({'type':'unsubscribe','symbol': symbol}))\n}\n",
            "go": "package main\n\nimport (\n\t\"encoding/json\"\n\t\"fmt\"\n\t\"github.com/gorilla/websocket\"\n)\n\nfunc main() {\n\tw, _, err := websocket.DefaultDialer.Dial(\"wss://ws.finnhub.io?token=<token>\", nil)\n\tif err != nil {\n\t\tpanic(err)\n\t}\n\tdefer w.Close()\n\n\tsymbols := []string{\"AAPL\", \"AMZN\", \"BINANCE:BTCUSDT\", \"IC MARKETS:1\"}\n\tfor _, s := range symbols {\n\t\tmsg, _ := json.Marshal(map[string]interface{}{\"type\": \"subscribe\", \"symbol\": s})\n\t\tw.WriteMessage(websocket.TextMessage, msg)\n\t}\n\n\tvar msg interface{}\n\tfor {\n\t\terr := w.ReadJSON(&msg);\n\t\tif err != nil {\n\t\t\tpanic(err)\n\t\t}\n\t\tfmt.Println(\"Message from server \", msg)\n\t}\n}\n",
            "python": "#https://pypi.org/project/websocket_client/\nimport websocket\n\ndef on_message(ws, message):\n    print(message)\n\ndef on_error(ws, error):\n    print(error)\n\ndef on_close(ws):\n    print(\"### closed ###\")\n\ndef on_open(ws):\n    ws.send('{\"type\":\"subscribe\",\"symbol\":\"AAPL\"}')\n    ws.send('{\"type\":\"subscribe\",\"symbol\":\"AMZN\"}')\n    ws.send('{\"type\":\"subscribe\",\"symbol\":\"BINANCE:BTCUSDT\"}')\n    ws.send('{\"type\":\"subscribe\",\"symbol\":\"IC MARKETS:1\"}')\n\nif __name__ == \"__main__\":\n    websocket.enableTrace(True)\n    ws = websocket.WebSocketApp(\"wss://ws.finnhub.io?token=<token>\",\n                              on_message = on_message,\n                              on_error = on_error,\n                              on_close = on_close)\n    ws.on_open = on_open\n    ws.run_forever()"
          "sampleResponse": " {\"data\":[{\"p\":7296.89,\"s\":\"BINANCE:BTCUSDT\",\"t\":1575526691134,\"v\":0.011467}],\"type\":\"trade\"}\n\n"
          "navHeader": "News",
          "title": "Websocket - Realtime News Streaming",
          "urlId": "websocket-news",
          "summary": "News",
          "premium": "Premium Access Required",
          "description": "Stream real-time news for US and Canadian stocks.",
          "method": [
            "Websocket"
          "examples": [
          "arguments": null,
              "name": "type",
              "type": "string",
              "description": "Message type: <code>news</code>."
              "name": "data",
              "type": "list",
              "description": "List of news.",
              "item": {
                "type": "object",
                "definition": "News",
                "attributes": [
                    "name": "category",
                    "type": "string",
                    "description": "News category."
                    "name": "datetime",
                    "type": "timestamp",
                    "description": "Published time in UNIX timestamp."
                    "name": "headline",
                    "type": "string",
                    "description": "News headline."
                    "name": "urlId",
                    "type": "int",
                    "description": "News ID."
                    "name": "image",
                    "type": "string",
                    "description": "Thumbnail image URL."
                    "name": "related",
                    "type": "string",
                    "description": "Related stocks and companies mentioned in the article."
                    "name": "source",
                    "type": "string",
                    "description": "News source."
                    "name": "summary",
                    "type": "string",
                    "description": "News summary."
                    "name": "url",
                    "type": "string",
                    "description": "URL of the original article."
          "sampleCode": {
            "javascript": "const socket = new WebSocket('wss://ws.finnhub.io?token=<token>');\n\n// Connection opened -> Subscribe\nsocket.addEventListener('open', function (event) {\n    socket.send(JSON.stringify({'type':'subscribe-news', 'symbol': 'AAPL'}))\n    socket.send(JSON.stringify({'type':'subscribe-news', 'symbol': 'MSFT'}))\n    socket.send(JSON.stringify({'type':'subscribe-news', 'symbol': 'AMZN'}))\n});\n\n// Listen for messages\nsocket.addEventListener('message', function (event) {\n    console.log('Message from server ', event.data);\n});\n\n// Unsubscribe\n var unsubscribe = function(symbol) {\n    socket.send(JSON.stringify({'type':'unsubscribe-news','symbol': symbol}))\n}\n",
            "go": "package main\n\nimport (\n\t\"encoding/json\"\n\t\"fmt\"\n\t\"github.com/gorilla/websocket\"\n)\n\nfunc main() {\n\tw, _, err := websocket.DefaultDialer.Dial(\"wss://ws.finnhub.io?token=<token>\", nil)\n\tif err != nil {\n\t\tpanic(err)\n\t}\n\tdefer w.Close()\n\n\tsymbols := []string{\"AAPL\", \"AMZN\", \"MSFT\", \"BYND\"}\n\tfor _, s := range symbols {\n\t\tmsg, _ := json.Marshal(map[string]interface{}{\"type\": \"subscribe-news\", \"symbol\": s})\n\t\tw.WriteMessage(websocket.TextMessage, msg)\n\t}\n\n\tvar msg interface{}\n\tfor {\n\t\terr := w.ReadJSON(&msg);\n\t\tif err != nil {\n\t\t\tpanic(err)\n\t\t}\n\t\tfmt.Println(\"Message from server \", msg)\n\t}\n}\n",
            "python": "#https://pypi.org/project/websocket_client/\nimport websocket\n\ndef on_message(ws, message):\n    print(message)\n\ndef on_error(ws, error):\n    print(error)\n\ndef on_close(ws):\n    print(\"### closed ###\")\n\ndef on_open(ws):\n    ws.send('{\"type\":\"subscribe-news\",\"symbol\":\"AAPL\"}')\n    ws.send('{\"type\":\"subscribe-news\",\"symbol\":\"AMZN\"}')\n    ws.send('{\"type\":\"subscribe-news\",\"symbol\":\"MSFT\"}')\n    ws.send('{\"type\":\"subscribe-news\",\"symbol\":\"BYND\"}')\n\nif __name__ == \"__main__\":\n    websocket.enableTrace(True)\n    ws = websocket.WebSocketApp(\"wss://ws.finnhub.io?token=<token>\",\n                              on_message = on_message,\n                              on_error = on_error,\n                              on_close = on_close)\n    ws.on_open = on_open\n    ws.run_forever()"
  "orders": [
    "/search",
    "/stock/symbol",
    "/stock/profile",
    "/stock/profile2",
    "/stock/executive",
    "/news",
    "/company-news",
    "/press-releases",
    "/news-sentiment",
    "/stock/peers",
    "/stock/metric",
    "/stock/ownership",
    "/stock/fund-ownership",
    "/institutional/profile",
    "/institutional/portfolio",
    "/institutional/ownership",
    "/stock/insider-transactions",
    "/stock/insider-sentiment",
    "/stock/financials",
    "/stock/financials-reported",
    "/stock/revenue-breakdown",
    "/stock/filings",
    "/stock/international-filings",
    "/stock/filings-sentiment",
    "/stock/similarity-index",
    "/calendar/ipo",
    "/stock/dividend",
    "/sector/metrics",
    "/stock/price-metric",
    "/ca/symbol-change",
    "/ca/isin-change",
    "/stock/recommendation",
    "/stock/price-target",
    "/stock/upgrade-downgrade",
    "/stock/revenue-estimate",
    "/stock/eps-estimate",
    "/stock/ebitda-estimate",
    "/stock/ebit-estimate",
    "/stock/earnings",
    "/calendar/earnings",
    "/quote",
    "/stock/candle",
    "/stock/tick",
    "/stock/bbo",
    "/stock/bidask",
    "/stock/split",
    "/stock/dividend2",
    "/index/constituents",
    "/index/historical-constituents",
    "/etf/profile",
    "/etf/holdings",
    "/etf/sector",
    "/etf/country",
    "/mutual-fund/profile",
    "/mutual-fund/holdings",
    "/mutual-fund/sector",
    "/mutual-fund/country",
    "/mutual-fund/eet",
    "/mutual-fund/eet-pai",
    "/bond/profile",
    "/bond/price",
    "/bond/tick",
    "/bond/yield-curve",
    "/forex/exchange",
    "/forex/symbol",
    "/forex/candle",
    "/forex/rates",
    "/crypto/exchange",
    "/crypto/symbol",
    "/crypto/profile",
    "/crypto/candle",
    "/scan/pattern",
    "/scan/support-resistance",
    "/scan/technical-indicator",
    "/indicator",
    "/stock/transcripts/list",
    "/stock/transcripts",
    "/stock/social-sentiment",
    "/stock/investment-theme",
    "/stock/supply-chain",
    "/stock/esg",
    "/stock/earnings-quality-score",
    "/stock/uspto-patent",
    "/stock/visa-application",
    "/stock/lobbying",
    "/stock/usa-spending",
    "/covid19/us",
    "/fda-advisory-committee-calendar",
    "/country",
    "/calendar/economic",
    "/economic/code",
    "/economic"
  "sampleCodeTemplate": {
    "python": "import finnhub\nfinnhub_client = finnhub.Client(api_key=\"<token>\")\n\n<MY_CODE>\n",
    "javascript": "const finnhub = require('finnhub');\n\nconst api_key = finnhub.ApiClient.instance.authentications['api_key'];\napi_key.apiKey = \"<token>\"\nconst finnhubClient = new finnhub.DefaultApi()\n\n<MY_CODE>\n",
    "go": "package main\n\nimport (\n    \"context\"\n    \"fmt\"\n    finnhub \"github.com/Finnhub-Stock-API/finnhub-go/v2\"\n)\n\nfunc main() {\n    cfg := finnhub.NewConfiguration()\n    cfg.AddDefaultHeader(\"X-Finnhub-Token\", \"<token>\")\n    finnhubClient := finnhub.NewAPIClient(cfg).DefaultApi\n    \n    <MY_CODE>\n    fmt.Printf(\"%+v\\n\", res)\n}",
    "ruby": "require 'finnhub_ruby'\n\nFinnhubRuby.configure do |config|\n  config.api_key['api_key'] = '<token>'\nend\n\nfinnhub_client = FinnhubRuby::DefaultApi.new\n<MY_CODE>\n",
    "kotlin": "import io.finnhub.api.apis.DefaultApi\nimport io.finnhub.api.infrastructure.ApiClient\n\nApiClient.apiKey[\"token\"] = \"<token>\"\nval apiClient = DefaultApi()\n\n<MY_CODE>\n",
    "php": "<?php\n\nrequire_once(__DIR__ . '/vendor/autoload.php');\n\n$config = Finnhub\\Configuration::getDefaultConfiguration()->setApiKey('token', '<token>');\n$client = new Finnhub\\Api\\DefaultApi(\n    new GuzzleHttp\\Client(),\n    $config\n);\n\n<MY_CODE>\n\n?>"
  "paths": {
    "/search": {
      "get": {
        "summary": "Symbol Lookup",
        "description": "Search for best-matching symbols based on your query. You can input anything from symbol, security's name to ISIN and Cusip.",
        "operationId": "symbol-search",
        "navHeader": "Symbol Lookup",
        "urlId": "symbol-search",
        "title": "Global Stocks Search",
        "examples": [
            "url": "/search?q=apple&token=<token>",
            "text": "/search?q=apple"
            "url": "/search?q=US5949181045&token=<token>",
            "text": "/search?q=US5949181045"
        "widget": null,
        "freeTier": null,
        "premium": null,
        "newEndpoint": null,
        "highUsage": null,
        "tags": [
          "Default"
        "section": "Stock Fundamentals",
        "consumes": [
          "application/json"
        "produces": [
          "application/json"
        "parameters": [
            "in": "query",
            "name": "q",
            "description": "Query text can be symbol, name, isin, or cusip.",
            "required": true,
            "type": "string"
        "responses": {
          "200": {
            "description": "successful operation",
            "schema": {
              "type": "object",
              "$ref": "#/definitions/SymbolLookup"
        "sampleCode": {
          "curl": "autoGenerated",
          "python": "print(finnhub_client.symbol_lookup('apple'))",
          "go": "res, _, err := finnhubClient.SymbolSearch(context.Background()).Q(\"AAPL\").Execute()",
          "javascript": "finnhubClient.symbolSearch('AAPL', (error, data, response) => {\n  console.log(data)\n});",
          "ruby": "puts(finnhub_client.symbol_search('AAPL'))",
          "kotlin": "println(apiClient.symbolSearch(\"AAPL\"))",
          "php": "print_r($client->symbolSearch(\"AAPL\"));",
          "useTemplate": true
        "sampleResponse": "{\n  \"count\": 4,\n  \"result\": [\n    {\n      \"description\": \"APPLE INC\",\n      \"displaySymbol\": \"AAPL\",\n      \"symbol\": \"AAPL\",\n      \"type\": \"Common Stock\"\n    },\n    {\n      \"description\": \"APPLE INC\",\n      \"displaySymbol\": \"AAPL.SW\",\n      \"symbol\": \"AAPL.SW\",\n      \"type\": \"Common Stock\"\n    },\n    {\n      \"description\": \"APPLE INC\",\n      \"displaySymbol\": \"APC.BE\",\n      \"symbol\": \"APC.BE\",\n      \"type\": \"Common Stock\"\n    },\n    {\n      \"description\": \"APPLE INC\",\n      \"displaySymbol\": \"APC.DE\",\n      \"symbol\": \"APC.DE\",\n      \"type\": \"Common Stock\"\n    }\n  ]\n}",
        "security": [
            "api_key": []
    "/stock/symbol": {
      "get": {
        "summary": "Stock Symbol",
What happens if you run this?
[{"id":"d880a33a83f7a2e4","type":"inject","z":"1b5ed5b363954ae7","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":290,"y":940,"wires":[["91784997ffc6c250"]]},{"id":"91784997ffc6c250","type":"function","z":"1b5ed5b363954ae7","name":"function 4","func":"const api_key = finnhub.ApiClient.instance.authentications['api_key'];\napi_key.apiKey = \"ceahq1aad3i1o5buvh00ceahq1aad3i1o5buvh0g\"\nconst finnhubClient = new finnhub.DefaultApi()\n\nfinnhubClient.supportResistance(\"AAPL\", \"D\", (error, data, response) => {\n    msg.error = error\n    msg.payload = data\n    node.send(msg)\n});\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"finnhub","module":"finnhub"}],"x":440,"y":940,"wires":[["93163c1ef1ecc743"]]},{"id":"93163c1ef1ecc743","type":"debug","z":"1b5ed5b363954ae7","name":"Result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":590,"y":940,"wires":[]}]
NOTE: you will need to update the API key in the function
I get this (I did update the API key). How can this work without an HTTP request
I got the following to work. Thanks!
        "id": "53f0f59f669fb288",
        "type": "tab",
        "label": "Flow 3",
        "disabled": false,
        "info": "",
        "env": []
        "id": "e41925659d7e33d2",
        "type": "inject",
        "z": "53f0f59f669fb288",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "finnhubClient.supportResistance(\"AAPL\", \"D\", (error, data, response) => {   console.log(data) });",
        "payloadType": "str",
        "x": 1030,
        "y": 460,
                "978a44a3f998fa6f"
        "id": "3a04bdcd5c40c5a3",
        "type": "http request",
        "method": "GET",
        "ret": "obj",
        "paytoqs": "ignore",
        "url": "",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [
                "keyType": "other",
                "keyValue": "X-Finnhub-Token",
                "valueType": "other",
                "valueValue": "ceahq1aad3i1o5buvh00ceahq1aad3i1o5buvh0g"
        "x": 1020,
        "y": 340,
                "5e759530b2e21efe"
        "id": "5e759530b2e21efe",
        "type": "debug",
        "name": "debug 39",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1200,
        "y": 340,
        "id": "978a44a3f998fa6f",
        "type": "function",
        "name": "function 10",
        "func": "/*\navailable indicators:\n\nSMA\nEMA\nWMA\nDEMA\nTEMA\nTRIMA\nKAMA\nMAMA\nT3\nMACD\nMACDEXT\nSTOCH\nSTOCHF\nRSI\nSTOCHRSI\nWILLR\nADX\nADXR\nAPO\nPPO\nMOM\nBOP\nCCI\nCMO\nROC\nROCR\nAROON\nAROONOSC\nMFI\nTRIX\nULTOSC\nDX\nMINUSDI\nPLUSDI\nMINUSDM\nPLUSDM\nBBANDS\nMIDPOINT\nMIDPRICE\nSAR\nTRANGE\nATR\nNATR\nAD\nADOSC\nOBV\nHTTRENDLINE\nHTSINE\nHTTRENDMODE\nHTDCPERIOD\nHTDCPHASE\nHTPHASOR\n\nresolutions:\n1, 5, 15, 30, 60, D, W, M\n*/\n\nfunction daysBack(d) {\n    const tmp = new Date()\n    tmp.setDate(tmp.getDate() - d)\n    return Math.floor(Date.parse(tmp) / 1000);\n}\n\n\nconst ta = \"SMA\"\nconst symbol = \"BINANCE:BTCUSDT\"\nconst resolution = \"D\"\nconst fromDate = daysBack(5)\nconst today = Math.floor(new Date().getTime() / 1000) \n\nmsg.url = `https://finnhub.io/api/v1/crypto/candle?symbol=${symbol}&resolution=${resolution}&from=${fromDate}&to=${today}&indicator=${ta}`\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1020,
        "y": 400,
                "3a04bdcd5c40c5a3"
