thank you, I check 150 cards , the result is so long
your code is ok !
my full code !
[{"id":"ba1c10c7.906dc8","type":"http request","z":"be3c6730.befb08","name":"","method":"POST","ret":"obj","paytoqs":"ignore","url":"https://api.matooma.com/token","tls":"","persist":false,"proxy":"","authType":"basic","x":470,"y":280,"wires":[["a461bb9d.4a1a38"]]},{"id":"a461bb9d.4a1a38","type":"change","z":"be3c6730.befb08","name":"","rules":[{"t":"set","p":"token","pt":"msg","to":"payload.access_token","tot":"msg"},{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.Authorization","pt":"msg","to":"\"Bearer \" & $$.token","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":280,"wires":[["9e99d67f.a12ca8"]]},{"id":"9e99d67f.a12ca8","type":"template","z":"be3c6730.befb08","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"8931080019084145730\n8931080019084155432\n8931080019084145110\n8931080019084155416\n8931080019084155424\n8931080019084145037\n8931080019084145151\n8931080019084145136\n8931080019084156182\n8931080019084156174\n8931080019084156166\n8931080119109159656\n8931080119109159649\n8931080119109159631\n8931080119109159623\n8931080119109159615\n8931080119109159748\n8931080019084145052\n8931080019084145177\n8931080019084145243\n8931080019084145219\n8931080019084145193\n8931080019084145144\n8931080019084145029\n8931080019084145201\n8931080019084145235\n8931080019084145250\n8931080119109159664\n8931080119109159672\n8931080119109159680\n8931080119109159698\n8931080119109159706\n8931080119109159714\n8931080119109159755\n8931080119109159763\n8931080119109159771\n8931080119109159789\n8931080119109159805\n8931080119109159797\n8931089218082631086\n8931089218082631003\n8931089218082631094\n8931089218082631136\n8931089218082631102\n8931089218082630971\n8931089218082631011\n8931089218082631045\n8931089218082631052\n8931089218082631144\n8931089218082631151\n8931088717106667779\n8931088918023803840\n8931088717106667787\n8931088717106667795\n8931088717106667803\n8931088717106667811\n8931088717106667829\n8931088717106667845\n8931088717106667852\n8931088918023803816\n8931088918023803824\n8931080019084156125\n8931080019084155671\n8931080019084145185\n8931080019084155556\n8931080019084145094\n8931080019084145805\n8931080019084145797\n8931080019084145060\n8931080019084146001\n8931080019084155440\n8931080019084145839\n8931080019084155564\n8931080019084155580\n8931080019084155572\n8931080019084155598\n8931080019084155606\n8931080019084155622\n8931080019084155614\n8931080019084145821\n8931080019084145763\n8931080019084155630\n8931080019084145714\n8931080019084145706\n8931080019084155648\n8931080019084155655\n8931080019084145045\n8931080019084155952\n8931080019084156133\n8931080019084145813\n8931080019084145789\n8931080019084145847\n8931080019084155945\n8931080019084156141\n8931080019084155937\n8931080019084155911\n8931080019084156158\n8931080019084155663\n8931080019084156190\n","output":"str","x":420,"y":340,"wires":[["ecf6006f.93e248"]]},{"id":"ecf6006f.93e248","type":"split","z":"be3c6730.befb08","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":560,"y":340,"wires":[["3debe7ed.39d978"]]},{"id":"69ad6af1.a018cc","type":"http request","z":"be3c6730.befb08","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":510,"y":400,"wires":[["dddbb4a6.a57f48"]]},{"id":"dddbb4a6.a57f48","type":"change","z":"be3c6730.befb08","name":"","rules":[{"t":"set","p":"parts.type","pt":"msg","to":"array","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":520,"wires":[["fca18795.18f68"]]},{"id":"fca18795.18f68","type":"join","z":"be3c6730.befb08","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":590,"y":520,"wires":[["cd414862.210cd8"]]},{"id":"cd414862.210cd8","type":"change","z":"be3c6730.befb08","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sum($$.payload[*].consumption[0].offer.data)*0.000000001","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":520,"wires":[["138eb22f.35b12e"]]},{"id":"3debe7ed.39d978","type":"change","z":"be3c6730.befb08","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"card","tot":"msg"},{"t":"set","p":"url","pt":"msg","to":"\"https://api.matooma.com/v1/consumptions/total/\" & $$.card & \"?start=2022-06-01&end=2022-06-06\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":340,"wires":[["69ad6af1.a018cc"]]},{"id":"138eb22f.35b12e","type":"debug","z":"be3c6730.befb08","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":630,"y":660,"wires":[]},{"id":"e38b2d03.b9a36","type":"inject","z":"be3c6730.befb08","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"1","topic":"","payload":"","payloadType":"date","x":200,"y":80,"wires":[["3f3bf7df.5f27a8"]]},{"id":"98c5d646.e47e38","type":"http request","z":"be3c6730.befb08","name":"","method":"POST","ret":"obj","paytoqs":"ignore","url":"https://api.matooma.com/token","tls":"","persist":false,"proxy":"","authType":"basic","x":230,"y":160,"wires":[["48b17868.b6cbc8"]]},{"id":"48b17868.b6cbc8","type":"change","z":"be3c6730.befb08","name":"","rules":[{"t":"set","p":"token","pt":"msg","to":"payload.access_token","tot":"msg"},{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.Authorization","pt":"msg","to":"\"Bearer \" & $$.token","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":160,"wires":[["ba1c10c7.906dc8"]]},{"id":"3f3bf7df.5f27a8","type":"moment","z":"be3c6730.befb08","name":"","topic":"","input":"","inputType":"msg","inTz":"Europe/Paris","adjAmount":0,"adjType":"days","adjDir":"add","format":"","locale":"fr-FR","output":"","outputType":"msg","outTz":"Europe/Paris","x":420,"y":80,"wires":[["59be9723.f7fcf8"]]},{"id":"f72dd901.57ad08","type":"string","z":"be3c6730.befb08","name":"Month","methods":[{"name":"between","params":[{"type":"str","value":"-"},{"type":"str","value":"-"}]}],"prop":"payload","propout":"month","object":"msg","objectout":"msg","x":750,"y":100,"wires":[["98c5d646.e47e38"]]},{"id":"59be9723.f7fcf8","type":"string","z":"be3c6730.befb08","name":"Date","methods":[{"name":"delRightMost","params":[{"type":"str","value":"T"}]}],"prop":"payload","propout":"date","object":"msg","objectout":"msg","x":610,"y":80,"wires":[["f72dd901.57ad08","81bd645e.db3cd8"]]},{"id":"81bd645e.db3cd8","type":"debug","z":"be3c6730.befb08","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"date","targetType":"msg","statusVal":"","statusType":"auto","x":740,"y":60,"wires":[]}]
