Append or Discard Data Series on Stop Button Press
That is the path i used in testing on my machine, you would edit it to the path of the folder where your files are, i presume /csv_files/. Maybe you could look at links provided to get some answers.
Everything works thanks for your help
The file name of the downloaded file is the entire path and I would like it to be only payload.file.
Have you attempted to change the msg.filename after the file read node?
Try googling split file name from path using javascript. you may learn something.
I don't know how I tried this way and got undefined.
msg.filename = msg.payload.file;
Let me google that for you
Remember you are using msg.filename , not msg.payload.file.
var path = msg.filename;
var parts = path.split('/');
var filename = parts[parts.length - 1];
msg.filename = filename;
I did it this way and it works so far.
