Are Subflows the right way to tidy up complex flows?
GUys,
I have a fair few nodes and would like to take a "chunk" of them and say all good and done and happy with what they are doing and essentially "put them to bed". This would have the effect of tidying my workspace as well as knowing that these work as is.
Is a subflow the best way to do this or is there another method ?
If i turn something into a subflow - can i get them back into a normal flow at a later date if i wish ?
Craig
Yes, subflows are a good way to do this. You can always copy paste from a subflow to the parent flow if you want to revert.
thanks for the quick response - will give it a go !
regards
Craig
Remember that a subflow needs to be used in an actual flow in order for it to do anything.
Subflows do have some limitations so this might not always work. I am more and more using link nodes to tidy my flows. This lets you move chunks of flow to somewhere more convenient. Possible away from the top-left or even to another tab altogether.
OK i will try subflows first and then if i run into problems will check out links (i have used neither at this point)
Craig
Colin,
I assume you mean i have ot take the sublfow node and drop it on my flow still for something to happen - rather than just leaving it in the palette ? or is there some other hidden secret ?
Craig
Yes, a subflow is just the same as a normal node from that point of view. If you don't put it on a flow then it won't do anything.
