I was looking to creating some API Integration Tests and generally a good idea would be to use JSON Schema for the Requests/Requests responses? One can use these schema files to check conformity.
Did you search flows library?
https://flows.nodered.org/search?term=schema
Also, in case you were not aware - the built in JSON node accepts a schema...
RTM...
Not for flows, but I meant the HTTP Admin APIs Authentication : Node-RED I was trying to work out some simple HTTP API integration tests when creating a custom Node-RED docker container. The Schema for the response of the HTTP Admin APIs was what I can use to validate if the container is running accordingly.
Would be nice if you include that info up front!
Then just import a JSON validation library and do what is necessary.
a duck type test is more "simple"
Apologies for the unclear description, As you mentioned a validator was the way to go.
I have been able to create some JSON Schemas created for the API as reference for the community
/auth/login Response Schema
"$schema": "https://json-schema.org/draft/2020-12/schema",
"type": "object",
"properties": {
"type": {
"type": "string"
"prompts": {
"type": "array",
"items": {
"$ref": "#/$defs/prompt"
"$defs": {
"prompt": {
"type": "object",
"required": ["id", "type", "label"],
"properties": {
"id": {
"type": "string"
"type": {
"type": "string"
"label": {
"type": "string"
/nodes Response Schema
"type": "array",
"items": {
"$ref": "#/$defs/node"
"$defs": {
"node": {
"type": "object",
"required": ["id", "name", "types", "enabled", "module", "version"],
"properties": {
"id": {
"type": "string"
"name": {
"type": "string"
"types": {
"type": "array",
"items": {
"type": "string"
"enabled": {
"type": "boolean"
"module": {
"type": "string"
"version": {
"type": "string"
I am still working on /flows API and I am not sure which fields should be marked required but I will update the schema here.
