Array of Objects/Arrays
i would like to use an array of objects but i can only create that array manually. I dont know how to create a bigger one :frowning:
My Code:
var test
let arrayOfObjects = [{},{}]
arrayOfObjects[1]['d'] = 777;
test = arrayOfObjects[1]['d'];
msg.logs = test
So i created an Array with 2 Objects. How do i create an Array with 100 Objects ? I could manually set 100 {}, but there must be a better way :slight_smile:
I would like to go with an loop through that array.
The Payload what i want to get into that array looks that way:
aimobjekte
Greetings
Chorum
If you do search 'create array of objects javascript' world wide, there is too many examples that nobody can't even count ...
let arr = []
let obj
for(let i=0;i<100;i++){
    obj = {}
    obj.someProperty = Math.random()
    obj.someOtherProperty = "Something"
    arr.push(obj)
//node.warn(arr)
msg.payload = arr
I didnt understand the examples i found, so i tried to build it up myself.
It tooked until now for me to make that code functional for me :slight_smile:
Thank you for your help!
Chorum
