Assign key to variable
Struggling to get the format correct for this:-
var VehTemp = "msg.payload.climate_state.outside_temp" || 99;
Have tried separators, moustache's and probably grown a beard while trying!
Thanks!
[{"id":"2f4b71c.592088e","type":"inject","z":"70721692.7614c8","name":"Error Test (O/P1)","topic":"","payload":"Error response: 408","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":578,"y":410,"wires":[["f17a33b2.55dd5"]]},{"id":"a681f5a8.6858c8","type":"inject","z":"70721692.7614c8","name":"vehicle Offline Query- \"asleep\" (O/P1)","topic":"","payload":"{\"id\":\"1234567890987654\",\"vehicle_id\":123456789,\"vin\":\"abcdefgefhijklmno\",\"display_name\":\"Tesla\",\"option_codes\":\"AD15,MDL3,PBSB,RENA,BT37,ID3W,RF3G,S3PB,DRLH,DV2W,W39B,APF0,COUS,BC3B,CH07,PC30,FC3P,FG31,GLFR,HL31,HM31,IL31,LTPB,MR31,FM3B,RS3H,SA3P,STCP,SC04,SU3C,T3CA,TW00,TM00,UT3P,WR00,AU3P,APH3,AF00,ZCST,MI00,CDM0\",\"color\":null,\"tokens\":[\"aabbccddeeff0011\",\"2233445566778899\"],\"state\":\"asleep\",\"in_service\":false,\"id_s\":\"1111111111111111\",\"calendar_enabled\":true,\"api_version\":7,\"backseat_token\":null,\"backseat_token_updated_at\":null}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":510,"y":240,"wires":[["f17a33b2.55dd5"]]},{"id":"40efa1c9.f4733","type":"inject","z":"70721692.7614c8","name":"vehData Online Query- Outside Temp \"null\", (ready to sleep) (O/P1)","topic":"","payload":"{\"id\":1234567890987654,\"user_id\":654321,\"vehicle_id\":123456789,\"vin\":\"abcdefgefhijklmno\",\"display_name\":\"Tesla\",\"option_codes\":\"AD15,MDL3,PBSB,RENA,BT37,ID3W,RF3G,S3PB,DRLH,DV2W,W39B,APF0,COUS,BC3B,CH07,PC30,FC3P,FG31,GLFR,HL31,HM31,IL31,LTPB,MR31,FM3B,RS3H,SA3P,STCP,SC04,SU3C,T3CA,TW00,TM00,UT3P,WR00,AU3P,APH3,AF00,ZCST,MI00,CDM0\",\"color\":null,\"tokens\":[\"3aabbbb333\",\"1111222289bbbbb3\"],\"state\":\"online\",\"in_service\":false,\"id_s\":\"1111111111111111\",\"calendar_enabled\":true,\"api_version\":7,\"backseat_token\":null,\"backseat_token_updated_at\":null,\"charge_state\":{\"battery_heater_on\":false,\"battery_level\":62,\"battery_range\":184.72,\"charge_current_request\":6,\"charge_current_request_max\":6,\"charge_enable_request\":false,\"charge_energy_added\":0,\"charge_limit_soc\":90,\"charge_limit_soc_max\":100,\"charge_limit_soc_min\":50,\"charge_limit_soc_std\":90,\"charge_miles_added_ideal\":0,\"charge_miles_added_rated\":0,\"charge_port_cold_weather_mode\":null,\"charge_port_door_open\":true,\"charge_port_latch\":\"Engaged\",\"charge_rate\":0,\"charge_to_max_range\":false,\"charger_actual_current\":0,\"charger_phases\":null,\"charger_pilot_current\":6,\"charger_power\":0,\"charger_voltage\":0,\"charging_state\":\"Stopped\",\"conn_charge_cable\":\"IEC\",\"est_battery_range\":142.6,\"fast_charger_brand\":\"<invalid>\",\"fast_charger_present\":false,\"fast_charger_type\":\"<invalid>\",\"ideal_battery_range\":147.77,\"managed_charging_active\":false,\"managed_charging_start_time\":null,\"managed_charging_user_canceled\":false,\"max_range_charge_counter\":0,\"minutes_to_full_charge\":1230,\"not_enough_power_to_heat\":false,\"scheduled_charging_pending\":false,\"scheduled_charging_start_time\":null,\"time_to_full_charge\":20.5,\"timestamp\":1588265747583,\"trip_charging\":false,\"usable_battery_level\":61,\"user_charge_enable_request\":false},\"climate_state\":{\"battery_heater\":false,\"battery_heater_no_power\":false,\"climate_keeper_mode\":\"off\",\"defrost_mode\":0,\"driver_temp_setting\":21,\"fan_status\":0,\"inside_temp\":null,\"is_auto_conditioning_on\":null,\"is_climate_on\":false,\"is_front_defroster_on\":false,\"is_preconditioning\":false,\"is_rear_defroster_on\":false,\"left_temp_direction\":null,\"max_avail_temp\":28,\"min_avail_temp\":15,\"outside_temp\":null,\"passenger_temp_setting\":21,\"remote_heater_control_enabled\":false,\"right_temp_direction\":null,\"seat_heater_left\":0,\"seat_heater_rear_center\":0,\"seat_heater_rear_left\":0,\"seat_heater_rear_right\":0,\"seat_heater_right\":0,\"side_mirror_heaters\":false,\"steering_wheel_heater\":false,\"timestamp\":1588265747583,\"wiper_blade_heater\":false},\"drive_state\":{\"gps_as_of\":1588265746,\"heading\":315,\"latitude\":35.127169,\"longitude\":-7.123456,\"native_latitude\":57.887909,\"native_location_supported\":1,\"native_longitude\":-3.123564,\"native_type\":\"wgs\",\"power\":0,\"shift_state\":null,\"speed\":null,\"timestamp\":1588265747583},\"gui_settings\":{\"gui_24_hour_time\":true,\"gui_charge_rate_units\":\"mi/hr\",\"gui_distance_units\":\"mi/hr\",\"gui_range_display\":\"Ideal\",\"gui_temperature_units\":\"C\",\"show_range_units\":true,\"timestamp\":1588265747583},\"vehicle_config\":{\"can_accept_navigation_requests\":true,\"can_actuate_trunks\":true,\"car_special_type\":\"base\",\"car_type\":\"models2\",\"charge_port_type\":\"EU\",\"ece_restrictions\":true,\"eu_vehicle\":true,\"exterior_color\":\"Red\",\"has_air_suspension\":true,\"has_ludicrous_mode\":true,\"motorized_charge_port\":true,\"plg\":true,\"rear_seat_heaters\":1,\"rear_seat_type\":1,\"rhd\":true,\"roof_color\":\"None\",\"seat_type\":1,\"spoiler_type\":\"Passive\",\"sun_roof_installed\":2,\"third_row_seats\":\"None\",\"timestamp\":1588265747584,\"trim_badging\":\"p90d\",\"use_range_badging\":false,\"wheel_type\":\"Base19\"},\"vehicle_state\":{\"api_version\":7,\"autopark_state_v2\":\"standby\",\"autopark_style\":\"dead_man\",\"calendar_supported\":true,\"car_version\":\"2020.12.5 e1144a6600ff\",\"center_display_state\":0,\"df\":0,\"dr\":0,\"ft\":0,\"homelink_device_count\":1,\"homelink_nearby\":true,\"is_user_present\":false,\"last_autopark_error\":\"no_error\",\"locked\":true,\"media_state\":{\"remote_control_enabled\":true},\"notifications_supported\":true,\"odometer\":18660.410966,\"parsed_calendar_supported\":true,\"pf\":0,\"pr\":0,\"remote_start\":false,\"remote_start_enabled\":true,\"remote_start_supported\":true,\"rt\":0,\"smart_summon_available\":false,\"software_update\":{\"download_perc\":0,\"expected_duration_sec\":2700,\"install_perc\":1,\"status\":\"\",\"version\":\"\"},\"speed_limit_mode\":{\"active\":false,\"current_limit_mph\":50,\"max_limit_mph\":90,\"min_limit_mph\":50,\"pin_code_set\":false},\"summon_standby_mode_enabled\":false,\"sun_roof_percent_open\":0,\"sun_roof_state\":\"unknown\",\"timestamp\":1588265747583,\"valet_mode\":false,\"valet_pin_needed\":true,\"vehicle_name\":\"Bob\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":419,"y":290,"wires":[["f17a33b2.55dd5"]]},{"id":"8cf85779.10a9d8","type":"debug","z":"70721692.7614c8","name":"Test O/P2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1140,"y":340,"wires":[]},{"id":"a4a1db0f.1c98c8","type":"debug","z":"70721692.7614c8","name":"Test O/P1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1140,"y":300,"wires":[]},{"id":"f17a33b2.55dd5","type":"function","z":"70721692.7614c8","name":"Anti-Vampire","func":"//node-red-contrib-tesla Anti-Vampire drain function block- avoids waking vehicle\n//Connect input to both Tesla Vehicle Query Output (Offline Query) and Tesla AllData Output (Online Query)\n//Connect O/P 1 to Offline Query, and O/P2 to online query\n//Ensure you add delay node of minimum 60 second on each output before input to API query nodes!\n\n//Set PrevVehState from context or \"unknown\" if not stored\nvar PrevVehState = context.get ('VehState') || 'unknown';\n//Set VehTemp to msg Value or 99 if missing\nvar VehTemp = msg.payload.climate_state.outside_temp || 99;\n//Set CurVehState from msg.state or set to \"unknown\" if missing\nvar CurVehState = msg.payload.state || 'unknown';\n\n//If Vehicle is not online, send msg to o/p1\nif (CurVehState !== 'online') {\ncontext.set(\"VehState\", CurVehState);\nnode.status({fill:\"red\", shape:\"ring\", text:CurVehState + \" line16\"});\nnode.warn (\"PreviousVehState \" + PrevVehState) ;\nnode.warn (\"VehicleOutsideTemp \" + VehTemp) ;\nnode.warn (\"CurrentVehState \" + CurVehState) ;\nreturn (msg,null);\n}\n\n//Check if VehState has changed to \"online\" since previous stored state, send msg to o/p2\nelse if ((CurVehState == \"online\") && (PrevVehState !== \"online\")) {\nnode.status({fill:\"yellow\", shape:\"ring\", text:CurVehState + \" line 25\"});\ncontext.set(\"VehState\", CurVehState);\nnode.warn (\"PreviousVehState \" + PrevVehState) ;\nnode.warn (\"VehicleOutsideTemp \" + VehTemp) ;\nnode.warn (\"CurrentVehState \" + CurVehState) ;\nreturn [null,msg];\n}\n\n//Check if VehState was and still is \"online\" and VehTemp is 99, send msg to o/p1\nelse if ((CurVehState == \"online\") && (PrevVehState == \"online\") && (VehTemp == 99)) {\nnode.status({fill:\"blue\", shape:\"ring\", text:CurVehState + \" line 35\"});\ncontext.set(\"VehState\", CurVehState);\nnode.warn (\"PreviousVehState \" + PrevVehState) ;\nnode.warn (\"VehicleOutsideTemp \" + VehTemp) ;\nnode.warn (\"CurrentVehState \" + CurVehState) ;\nreturn [msg,null];\n} \n\n//Check if VehState was and still is \"online\" and VehTemp is not 99, send msg to o/p2\nelse if ((CurVehState == \"online\") && (PrevVehState == \"online\") && (VehTemp != 99)) {\nnode.status({fill:\"green\", shape:\"ring\", text:CurVehState + \" line 45\"});\ncontext.set(\"VehState\", CurVehState);\nnode.warn (\"PreviousVehState \" + PrevVehState) ;\nnode.warn (\"VehicleOutsideTemp \" + VehTemp) ;\nnode.warn (\"CurrentVehState \" + CurVehState) ;\nreturn [null,msg];\n}\n\n//If VehicleState was unknown try offine query again\nelse if (CurVehState == \"unknown\") {\nnode.status({fill:\"yellow\", shape:\"ring\", text:CurVehState + \" line 55\"});\ncontext.set(\"VehState\", CurVehState);\nnode.warn (\"PreviousVehState \" + PrevVehState) ;\nnode.warn (\"VehicleOutsideTemp \" + VehTemp) ;\nnode.warn (\"CurrentVehState \" + CurVehState) ;\nreturn [null,msg];\n}\n//Check if anywhere in msg contains \"error\", send msg to o/p1\nelse if (msg ['payload'] == \"error\"); {\nnode.status({fill:\"grey\", shape:\"ring\", text:msg + \" line 64\"});\nnode.warn (\"PreviousVehState \" + PrevVehState) ;\nnode.warn (\"VehicleOutsideTemp \" + VehTemp) ;\nnode.warn (\"CurrentVehState \" + CurVehState) ;\nreturn [msg,null];    \n}","outputs":2,"noerr":0,"x":830,"y":320,"wires":[["a4a1db0f.1c98c8"],["8cf85779.10a9d8"]]},{"id":"1ea3c8cb.3cd437","type":"inject","z":"70721692.7614c8","name":"vehData Online Query- Outside Temp 20, full online (O/P2)","topic":"","payload":"{\"id\":1234567890987654,\"user_id\":654321,\"vehicle_id\":123456789,\"vin\":\"abcdefgefhijklmno\",\"display_name\":\"Tesla\",\"option_codes\":\"AD15,MDL3,PBSB,RENA,BT37,ID3W,RF3G,S3PB,DRLH,DV2W,W39B,APF0,COUS,BC3B,CH07,PC30,FC3P,FG31,GLFR,HL31,HM31,IL31,LTPB,MR31,FM3B,RS3H,SA3P,STCP,SC04,SU3C,T3CA,TW00,TM00,UT3P,WR00,AU3P,APH3,AF00,ZCST,MI00,CDM0\",\"color\":null,\"tokens\":[\"33b1234567890\",\"1234567890b3\"],\"state\":\"online\",\"in_service\":false,\"id_s\":\"1111111111111111\",\"calendar_enabled\":true,\"api_version\":7,\"backseat_token\":null,\"backseat_token_updated_at\":null,\"charge_state\":{\"battery_heater_on\":false,\"battery_level\":62,\"battery_range\":184.72,\"charge_current_request\":6,\"charge_current_request_max\":6,\"charge_enable_request\":false,\"charge_energy_added\":0,\"charge_limit_soc\":90,\"charge_limit_soc_max\":100,\"charge_limit_soc_min\":50,\"charge_limit_soc_std\":90,\"charge_miles_added_ideal\":0,\"charge_miles_added_rated\":0,\"charge_port_cold_weather_mode\":null,\"charge_port_door_open\":true,\"charge_port_latch\":\"Engaged\",\"charge_rate\":0,\"charge_to_max_range\":false,\"charger_actual_current\":0,\"charger_phases\":null,\"charger_pilot_current\":6,\"charger_power\":0,\"charger_voltage\":0,\"charging_state\":\"Stopped\",\"conn_charge_cable\":\"IEC\",\"est_battery_range\":142.6,\"fast_charger_brand\":\"<invalid>\",\"fast_charger_present\":false,\"fast_charger_type\":\"<invalid>\",\"ideal_battery_range\":147.77,\"managed_charging_active\":false,\"managed_charging_start_time\":null,\"managed_charging_user_canceled\":false,\"max_range_charge_counter\":0,\"minutes_to_full_charge\":1230,\"not_enough_power_to_heat\":false,\"scheduled_charging_pending\":false,\"scheduled_charging_start_time\":null,\"time_to_full_charge\":20.5,\"timestamp\":1588265747583,\"trip_charging\":false,\"usable_battery_level\":61,\"user_charge_enable_request\":false},\"climate_state\":{\"battery_heater\":false,\"battery_heater_no_power\":false,\"climate_keeper_mode\":\"off\",\"defrost_mode\":0,\"driver_temp_setting\":21,\"fan_status\":0,\"inside_temp\":null,\"is_auto_conditioning_on\":null,\"is_climate_on\":false,\"is_front_defroster_on\":false,\"is_preconditioning\":false,\"is_rear_defroster_on\":false,\"left_temp_direction\":null,\"max_avail_temp\":28,\"min_avail_temp\":15,\"outside_temp\":20,\"passenger_temp_setting\":21,\"remote_heater_control_enabled\":false,\"right_temp_direction\":null,\"seat_heater_left\":0,\"seat_heater_rear_center\":0,\"seat_heater_rear_left\":0,\"seat_heater_rear_right\":0,\"seat_heater_right\":0,\"side_mirror_heaters\":false,\"steering_wheel_heater\":false,\"timestamp\":1588265747583,\"wiper_blade_heater\":false},\"drive_state\":{\"gps_as_of\":1588265746,\"heading\":315,\"latitude\":35.127169,\"longitude\":-7.123456,\"native_latitude\":57.887909,\"native_location_supported\":1,\"native_longitude\":-3.123564,\"native_type\":\"wgs\",\"power\":0,\"shift_state\":null,\"speed\":null,\"timestamp\":1588265747583},\"gui_settings\":{\"gui_24_hour_time\":true,\"gui_charge_rate_units\":\"mi/hr\",\"gui_distance_units\":\"mi/hr\",\"gui_range_display\":\"Ideal\",\"gui_temperature_units\":\"C\",\"show_range_units\":true,\"timestamp\":1588265747583},\"vehicle_config\":{\"can_accept_navigation_requests\":true,\"can_actuate_trunks\":true,\"car_special_type\":\"base\",\"car_type\":\"models2\",\"charge_port_type\":\"EU\",\"ece_restrictions\":true,\"eu_vehicle\":true,\"exterior_color\":\"Red\",\"has_air_suspension\":true,\"has_ludicrous_mode\":true,\"motorized_charge_port\":true,\"plg\":true,\"rear_seat_heaters\":1,\"rear_seat_type\":1,\"rhd\":true,\"roof_color\":\"None\",\"seat_type\":1,\"spoiler_type\":\"Passive\",\"sun_roof_installed\":2,\"third_row_seats\":\"None\",\"timestamp\":1588265747584,\"trim_badging\":\"p90d\",\"use_range_badging\":false,\"wheel_type\":\"Base19\"},\"vehicle_state\":{\"api_version\":7,\"autopark_state_v2\":\"standby\",\"autopark_style\":\"dead_man\",\"calendar_supported\":true,\"car_version\":\"2020.12.5 e1144a6600ff\",\"center_display_state\":0,\"df\":0,\"dr\":0,\"ft\":0,\"homelink_device_count\":1,\"homelink_nearby\":true,\"is_user_present\":false,\"last_autopark_error\":\"no_error\",\"locked\":true,\"media_state\":{\"remote_control_enabled\":true},\"notifications_supported\":true,\"odometer\":18660.410966,\"parsed_calendar_supported\":true,\"pf\":0,\"pr\":0,\"remote_start\":false,\"remote_start_enabled\":true,\"remote_start_supported\":true,\"rt\":0,\"smart_summon_available\":false,\"software_update\":{\"download_perc\":0,\"expected_duration_sec\":2700,\"install_perc\":1,\"status\":\"\",\"version\":\"\"},\"speed_limit_mode\":{\"active\":false,\"current_limit_mph\":50,\"max_limit_mph\":90,\"min_limit_mph\":50,\"pin_code_set\":false},\"summon_standby_mode_enabled\":false,\"sun_roof_percent_open\":0,\"sun_roof_state\":\"unknown\",\"timestamp\":1588265747583,\"valet_mode\":false,\"valet_pin_needed\":true,\"vehicle_name\":\"Bob\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":449,"y":350,"wires":[["f17a33b2.55dd5"]]}]
Why are you putting quotes arround msg.payload.climate_state.outside_temp? That turns it into a string.
Tried with and without, added them here to make key clear.
Tried msg [payload],[climate_state],[outside_temp], commas separating, inverted commas, many other iterations.
This is the first complex-ish function node I’ve tried, I added a lot of debug which helped me understand other errors but I can’t get to the bottom of this one.
JS is very new to me...
When you use msg.payload.climate_state.outside_temp you are saying "Get me the value of 'outside_temp' which is in the object 'climate_state' which is in the object 'payload' that is inside of the msg" or think of it like this
msg
==> payload
====> climate_state
======> outside_temp
Now if you put a debug node on the output of your inject nodes, does that property exist?
If you want to see if a property exists you could use
if (msg.payload.hasOwnProperty("climate_state")){
to see if "climate_state" exists in msg.payload, then use
if (msg.payload.climate_state.hasOwnProperty("outside_temp")){
to see if outside_temp exists in msg.payload.climate_state
Thanks Paul,
The property path I copied from debug window so I know it exists- you can see it in the sample data when pressing inject button “ vehData Online Query- Outside Temp 20, full online (O/P2)”.
Thanks for the extra debug steps, I’ll try tomorrow after some sleep!
Post up a screenshot of the debug window and also your flow that you have that is not working
Does it exsist in ALL the inject nodes????
Sorry, got back up as it's bugging me, I see what's happening now. The whole function is actually working but I have "TypeError: Cannot read property 'outside_temp' of undefined" for a couple of situations:-
  • error messages don't have climate_state property (bottom inject button)
  • an "offline" query doesn't have climate_state property (top inject button)
I incorrectly assumed the "or" in "var VehTemp= .... || 99" would just set the variable to 99 in those scenarios- but this doesn't happen if the property isn't there at all. I want to set VehTemp to 99 for these conditions as well...
This OR does work on the second inject button where climate_state=null is correctly set to 99.
I think I need to add some something boolean to check the climate.state property is present first with "varTemp=..." nested within that if true?
Here's the flow again...
Look at my first post where you test ti see if the property exists in the owner object. You need to do two if' to check for both properties.
Thanks @zenofmud, sorry, never sunk in first time.
The upper level hasownproperty check works fine and should always apply.
Had to also remove semi-colons as they were escaping before msg return...need to study that a bit more and probably improve error checking- after sleep!
[{"id":"2f4b71c.592088e","type":"inject","z":"70721692.7614c8","name":"Error Test (O/P1)","topic":"","payload":"Error response: 408","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":560,"y":400,"wires":[["f17a33b2.55dd5"]]},{"id":"a681f5a8.6858c8","type":"inject","z":"70721692.7614c8","name":"vehicle Offline Query- \"asleep\" (O/P1)","topic":"","payload":"{\"id\":\"1234567890987654\",\"vehicle_id\":123456789,\"vin\":\"abcdefgefhijklmno\",\"display_name\":\"Tesla\",\"option_codes\":\"AD15,MDL3,PBSB,RENA,BT37,ID3W,RF3G,S3PB,DRLH,DV2W,W39B,APF0,COUS,BC3B,CH07,PC30,FC3P,FG31,GLFR,HL31,HM31,IL31,LTPB,MR31,FM3B,RS3H,SA3P,STCP,SC04,SU3C,T3CA,TW00,TM00,UT3P,WR00,AU3P,APH3,AF00,ZCST,MI00,CDM0\",\"color\":null,\"tokens\":[\"aabbccddeeff0011\",\"2233445566778899\"],\"state\":\"asleep\",\"in_service\":false,\"id_s\":\"1111111111111111\",\"calendar_enabled\":true,\"api_version\":7,\"backseat_token\":null,\"backseat_token_updated_at\":null}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":492,"y":230,"wires":[["f17a33b2.55dd5"]]},{"id":"40efa1c9.f4733","type":"inject","z":"70721692.7614c8","name":"vehData Online Query- Outside Temp \"null\", (ready to sleep) (O/P1)","topic":"","payload":"{\"id\":1234567890987654,\"user_id\":654321,\"vehicle_id\":123456789,\"vin\":\"abcdefgefhijklmno\",\"display_name\":\"Tesla\",\"option_codes\":\"AD15,MDL3,PBSB,RENA,BT37,ID3W,RF3G,S3PB,DRLH,DV2W,W39B,APF0,COUS,BC3B,CH07,PC30,FC3P,FG31,GLFR,HL31,HM31,IL31,LTPB,MR31,FM3B,RS3H,SA3P,STCP,SC04,SU3C,T3CA,TW00,TM00,UT3P,WR00,AU3P,APH3,AF00,ZCST,MI00,CDM0\",\"color\":null,\"tokens\":[\"3aabbbb333\",\"1111222289bbbbb3\"],\"state\":\"online\",\"in_service\":false,\"id_s\":\"1111111111111111\",\"calendar_enabled\":true,\"api_version\":7,\"backseat_token\":null,\"backseat_token_updated_at\":null,\"charge_state\":{\"battery_heater_on\":false,\"battery_level\":62,\"battery_range\":184.72,\"charge_current_request\":6,\"charge_current_request_max\":6,\"charge_enable_request\":false,\"charge_energy_added\":0,\"charge_limit_soc\":90,\"charge_limit_soc_max\":100,\"charge_limit_soc_min\":50,\"charge_limit_soc_std\":90,\"charge_miles_added_ideal\":0,\"charge_miles_added_rated\":0,\"charge_port_cold_weather_mode\":null,\"charge_port_door_open\":true,\"charge_port_latch\":\"Engaged\",\"charge_rate\":0,\"charge_to_max_range\":false,\"charger_actual_current\":0,\"charger_phases\":null,\"charger_pilot_current\":6,\"charger_power\":0,\"charger_voltage\":0,\"charging_state\":\"Stopped\",\"conn_charge_cable\":\"IEC\",\"est_battery_range\":142.6,\"fast_charger_brand\":\"<invalid>\",\"fast_charger_present\":false,\"fast_charger_type\":\"<invalid>\",\"ideal_battery_range\":147.77,\"managed_charging_active\":false,\"managed_charging_start_time\":null,\"managed_charging_user_canceled\":false,\"max_range_charge_counter\":0,\"minutes_to_full_charge\":1230,\"not_enough_power_to_heat\":false,\"scheduled_charging_pending\":false,\"scheduled_charging_start_time\":null,\"time_to_full_charge\":20.5,\"timestamp\":1588265747583,\"trip_charging\":false,\"usable_battery_level\":61,\"user_charge_enable_request\":false},\"climate_state\":{\"battery_heater\":false,\"battery_heater_no_power\":false,\"climate_keeper_mode\":\"off\",\"defrost_mode\":0,\"driver_temp_setting\":21,\"fan_status\":0,\"inside_temp\":null,\"is_auto_conditioning_on\":null,\"is_climate_on\":false,\"is_front_defroster_on\":false,\"is_preconditioning\":false,\"is_rear_defroster_on\":false,\"left_temp_direction\":null,\"max_avail_temp\":28,\"min_avail_temp\":15,\"outside_temp\":null,\"passenger_temp_setting\":21,\"remote_heater_control_enabled\":false,\"right_temp_direction\":null,\"seat_heater_left\":0,\"seat_heater_rear_center\":0,\"seat_heater_rear_left\":0,\"seat_heater_rear_right\":0,\"seat_heater_right\":0,\"side_mirror_heaters\":false,\"steering_wheel_heater\":false,\"timestamp\":1588265747583,\"wiper_blade_heater\":false},\"drive_state\":{\"gps_as_of\":1588265746,\"heading\":315,\"latitude\":35.127169,\"longitude\":-7.123456,\"native_latitude\":57.887909,\"native_location_supported\":1,\"native_longitude\":-3.123564,\"native_type\":\"wgs\",\"power\":0,\"shift_state\":null,\"speed\":null,\"timestamp\":1588265747583},\"gui_settings\":{\"gui_24_hour_time\":true,\"gui_charge_rate_units\":\"mi/hr\",\"gui_distance_units\":\"mi/hr\",\"gui_range_display\":\"Ideal\",\"gui_temperature_units\":\"C\",\"show_range_units\":true,\"timestamp\":1588265747583},\"vehicle_config\":{\"can_accept_navigation_requests\":true,\"can_actuate_trunks\":true,\"car_special_type\":\"base\",\"car_type\":\"models2\",\"charge_port_type\":\"EU\",\"ece_restrictions\":true,\"eu_vehicle\":true,\"exterior_color\":\"Red\",\"has_air_suspension\":true,\"has_ludicrous_mode\":true,\"motorized_charge_port\":true,\"plg\":true,\"rear_seat_heaters\":1,\"rear_seat_type\":1,\"rhd\":true,\"roof_color\":\"None\",\"seat_type\":1,\"spoiler_type\":\"Passive\",\"sun_roof_installed\":2,\"third_row_seats\":\"None\",\"timestamp\":1588265747584,\"trim_badging\":\"p90d\",\"use_range_badging\":false,\"wheel_type\":\"Base19\"},\"vehicle_state\":{\"api_version\":7,\"autopark_state_v2\":\"standby\",\"autopark_style\":\"dead_man\",\"calendar_supported\":true,\"car_version\":\"2020.12.5 e1144a6600ff\",\"center_display_state\":0,\"df\":0,\"dr\":0,\"ft\":0,\"homelink_device_count\":1,\"homelink_nearby\":true,\"is_user_present\":false,\"last_autopark_error\":\"no_error\",\"locked\":true,\"media_state\":{\"remote_control_enabled\":true},\"notifications_supported\":true,\"odometer\":18660.410966,\"parsed_calendar_supported\":true,\"pf\":0,\"pr\":0,\"remote_start\":false,\"remote_start_enabled\":true,\"remote_start_supported\":true,\"rt\":0,\"smart_summon_available\":false,\"software_update\":{\"download_perc\":0,\"expected_duration_sec\":2700,\"install_perc\":1,\"status\":\"\",\"version\":\"\"},\"speed_limit_mode\":{\"active\":false,\"current_limit_mph\":50,\"max_limit_mph\":90,\"min_limit_mph\":50,\"pin_code_set\":false},\"summon_standby_mode_enabled\":false,\"sun_roof_percent_open\":0,\"sun_roof_state\":\"unknown\",\"timestamp\":1588265747583,\"valet_mode\":false,\"valet_pin_needed\":true,\"vehicle_name\":\"Bob\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":401,"y":280,"wires":[["f17a33b2.55dd5"]]},{"id":"8cf85779.10a9d8","type":"debug","z":"70721692.7614c8","name":"Test O/P2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1122,"y":330,"wires":[]},{"id":"a4a1db0f.1c98c8","type":"debug","z":"70721692.7614c8","name":"Test O/P1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1122,"y":290,"wires":[]},{"id":"f17a33b2.55dd5","type":"function","z":"70721692.7614c8","name":"Anti-Vampire","func":"//node-red-contrib-tesla Anti-Vampire drain function block- avoids waking vehicle\n//Connect input to both Tesla Vehicle Query Output (Offline Query) and Tesla AllData Output (Online Query)\n//Connect O/P 1 to Offline Query, and O/P2 to online query\n//Ensure you add delay node of minimum 60 second on each output before input to API query nodes!\n\n//Set PrevVehState from context or \"unknown\" if not stored\nvar PrevVehState = context.get ('VehState') || 'unknown'\n//Set VehTemp to msg Value or 99 if missing\nif (msg.payload.hasOwnProperty(\"climate_state\")){\nvar VehTemp = msg.payload.climate_state.outside_temp || 99\n}\nelse VehTemp = 99;\n//Set CurVehState from msg.state or set to \"unknown\" if missing\nvar CurVehState = msg.payload.state || 'unknown'\n\n//Check if anywhere in msg contains \"error\", send msg to o/p1\nif (msg.payload == \"error\") {\nnode.status({fill:\"grey\", shape:\"ring\", text:msg + \" line 18\"})\nnode.warn (\"PreviousVehState \" + PrevVehState)\nnode.warn (\"VehicleOutsideTemp \" + VehTemp)\nnode.warn (\"CurrentVehState \" + CurVehState)\nreturn [msg,null]\n}\n\n//If Vehicle is not online, send msg to o/p1\nelse if (CurVehState !== 'online') {\ncontext.set(\"VehState\", CurVehState)\nnode.status({fill:\"red\", shape:\"ring\", text:CurVehState + \" line28\"})\nnode.warn (\"PreviousVehState \" + PrevVehState)\nnode.warn (\"VehicleOutsideTemp \" + VehTemp)\nnode.warn (\"CurrentVehState \" + CurVehState)\nreturn [msg,null]\n}\n\n//Check if VehState has changed to \"online\" since previous stored state, send msg to o/p2\nelse if ((CurVehState == \"online\") && (PrevVehState !== \"online\")) {\nnode.status({fill:\"yellow\", shape:\"ring\", text:CurVehState + \" line 37\"})\ncontext.set(\"VehState\", CurVehState)\nnode.warn (\"PreviousVehState \" + PrevVehState)\nnode.warn (\"VehicleOutsideTemp \" + VehTemp)\nnode.warn (\"CurrentVehState \" + CurVehState)\nreturn [null,msg]\n}\n\n//Check if VehState was and still is \"online\" and VehTemp is 99, send msg to o/p1\nelse if ((CurVehState == \"online\") && (PrevVehState == \"online\") && (VehTemp == 99)) {\nnode.status({fill:\"blue\", shape:\"ring\", text:CurVehState + \" line 47\"})\ncontext.set(\"VehState\", CurVehState)\nnode.warn (\"PreviousVehState \" + PrevVehState)\nnode.warn (\"VehicleOutsideTemp \" + VehTemp)\nnode.warn (\"CurrentVehState \" + CurVehState)\nreturn [msg,null]\n} \n\n//Check if VehState was and still is \"online\" and VehTemp is not 99, send msg to o/p2\nelse if ((CurVehState == \"online\") && (PrevVehState == \"online\") && (VehTemp != 99)) {\nnode.status({fill:\"green\", shape:\"ring\", text:CurVehState + \" line 57\"})\ncontext.set(\"VehState\", CurVehState)\nnode.warn (\"PreviousVehState \" + PrevVehState)\nnode.warn (\"VehicleOutsideTemp \" + VehTemp)\nnode.warn (\"CurrentVehState \" + CurVehState)\nreturn [null,msg];\n}\n\n//If VehicleState was unknown try offine query again\nelse if (CurVehState == \"unknown\") {\nnode.status({fill:\"yellow\", shape:\"ring\", text:CurVehState + \" line 67\"})\ncontext.set(\"VehState\", CurVehState)\nnode.warn (\"PreviousVehState \" + PrevVehState)\nnode.warn (\"VehicleOutsideTemp \" + VehTemp)\nnode.warn (\"CurrentVehState \" + CurVehState)\nreturn [null,msg]\n}\n","outputs":2,"noerr":0,"x":830,"y":300,"wires":[["a4a1db0f.1c98c8"],["8cf85779.10a9d8"]]},{"id":"1ea3c8cb.3cd437","type":"inject","z":"70721692.7614c8","name":"vehData Online Query- Outside Temp 20, full online (O/P2)","topic":"","payload":"{\"id\":1234567890987654,\"user_id\":654321,\"vehicle_id\":123456789,\"vin\":\"abcdefgefhijklmno\",\"display_name\":\"Tesla\",\"option_codes\":\"AD15,MDL3,PBSB,RENA,BT37,ID3W,RF3G,S3PB,DRLH,DV2W,W39B,APF0,COUS,BC3B,CH07,PC30,FC3P,FG31,GLFR,HL31,HM31,IL31,LTPB,MR31,FM3B,RS3H,SA3P,STCP,SC04,SU3C,T3CA,TW00,TM00,UT3P,WR00,AU3P,APH3,AF00,ZCST,MI00,CDM0\",\"color\":null,\"tokens\":[\"33b1234567890\",\"1234567890b3\"],\"state\":\"online\",\"in_service\":false,\"id_s\":\"1111111111111111\",\"calendar_enabled\":true,\"api_version\":7,\"backseat_token\":null,\"backseat_token_updated_at\":null,\"charge_state\":{\"battery_heater_on\":false,\"battery_level\":62,\"battery_range\":184.72,\"charge_current_request\":6,\"charge_current_request_max\":6,\"charge_enable_request\":false,\"charge_energy_added\":0,\"charge_limit_soc\":90,\"charge_limit_soc_max\":100,\"charge_limit_soc_min\":50,\"charge_limit_soc_std\":90,\"charge_miles_added_ideal\":0,\"charge_miles_added_rated\":0,\"charge_port_cold_weather_mode\":null,\"charge_port_door_open\":true,\"charge_port_latch\":\"Engaged\",\"charge_rate\":0,\"charge_to_max_range\":false,\"charger_actual_current\":0,\"charger_phases\":null,\"charger_pilot_current\":6,\"charger_power\":0,\"charger_voltage\":0,\"charging_state\":\"Stopped\",\"conn_charge_cable\":\"IEC\",\"est_battery_range\":142.6,\"fast_charger_brand\":\"<invalid>\",\"fast_charger_present\":false,\"fast_charger_type\":\"<invalid>\",\"ideal_battery_range\":147.77,\"managed_charging_active\":false,\"managed_charging_start_time\":null,\"managed_charging_user_canceled\":false,\"max_range_charge_counter\":0,\"minutes_to_full_charge\":1230,\"not_enough_power_to_heat\":false,\"scheduled_charging_pending\":false,\"scheduled_charging_start_time\":null,\"time_to_full_charge\":20.5,\"timestamp\":1588265747583,\"trip_charging\":false,\"usable_battery_level\":61,\"user_charge_enable_request\":false},\"climate_state\":{\"battery_heater\":false,\"battery_heater_no_power\":false,\"climate_keeper_mode\":\"off\",\"defrost_mode\":0,\"driver_temp_setting\":21,\"fan_status\":0,\"inside_temp\":null,\"is_auto_conditioning_on\":null,\"is_climate_on\":false,\"is_front_defroster_on\":false,\"is_preconditioning\":false,\"is_rear_defroster_on\":false,\"left_temp_direction\":null,\"max_avail_temp\":28,\"min_avail_temp\":15,\"outside_temp\":20,\"passenger_temp_setting\":21,\"remote_heater_control_enabled\":false,\"right_temp_direction\":null,\"seat_heater_left\":0,\"seat_heater_rear_center\":0,\"seat_heater_rear_left\":0,\"seat_heater_rear_right\":0,\"seat_heater_right\":0,\"side_mirror_heaters\":false,\"steering_wheel_heater\":false,\"timestamp\":1588265747583,\"wiper_blade_heater\":false},\"drive_state\":{\"gps_as_of\":1588265746,\"heading\":315,\"latitude\":35.127169,\"longitude\":-7.123456,\"native_latitude\":57.887909,\"native_location_supported\":1,\"native_longitude\":-3.123564,\"native_type\":\"wgs\",\"power\":0,\"shift_state\":null,\"speed\":null,\"timestamp\":1588265747583},\"gui_settings\":{\"gui_24_hour_time\":true,\"gui_charge_rate_units\":\"mi/hr\",\"gui_distance_units\":\"mi/hr\",\"gui_range_display\":\"Ideal\",\"gui_temperature_units\":\"C\",\"show_range_units\":true,\"timestamp\":1588265747583},\"vehicle_config\":{\"can_accept_navigation_requests\":true,\"can_actuate_trunks\":true,\"car_special_type\":\"base\",\"car_type\":\"models2\",\"charge_port_type\":\"EU\",\"ece_restrictions\":true,\"eu_vehicle\":true,\"exterior_color\":\"Red\",\"has_air_suspension\":true,\"has_ludicrous_mode\":true,\"motorized_charge_port\":true,\"plg\":true,\"rear_seat_heaters\":1,\"rear_seat_type\":1,\"rhd\":true,\"roof_color\":\"None\",\"seat_type\":1,\"spoiler_type\":\"Passive\",\"sun_roof_installed\":2,\"third_row_seats\":\"None\",\"timestamp\":1588265747584,\"trim_badging\":\"p90d\",\"use_range_badging\":false,\"wheel_type\":\"Base19\"},\"vehicle_state\":{\"api_version\":7,\"autopark_state_v2\":\"standby\",\"autopark_style\":\"dead_man\",\"calendar_supported\":true,\"car_version\":\"2020.12.5 e1144a6600ff\",\"center_display_state\":0,\"df\":0,\"dr\":0,\"ft\":0,\"homelink_device_count\":1,\"homelink_nearby\":true,\"is_user_present\":false,\"last_autopark_error\":\"no_error\",\"locked\":true,\"media_state\":{\"remote_control_enabled\":true},\"notifications_supported\":true,\"odometer\":18660.410966,\"parsed_calendar_supported\":true,\"pf\":0,\"pr\":0,\"remote_start\":false,\"remote_start_enabled\":true,\"remote_start_supported\":true,\"rt\":0,\"smart_summon_available\":false,\"software_update\":{\"download_perc\":0,\"expected_duration_sec\":2700,\"install_perc\":1,\"status\":\"\",\"version\":\"\"},\"speed_limit_mode\":{\"active\":false,\"current_limit_mph\":50,\"max_limit_mph\":90,\"min_limit_mph\":50,\"pin_code_set\":false},\"summon_standby_mode_enabled\":false,\"sun_roof_percent_open\":0,\"sun_roof_state\":\"unknown\",\"timestamp\":1588265747583,\"valet_mode\":false,\"valet_pin_needed\":true,\"vehicle_name\":\"Bob\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":431,"y":340,"wires":[["f17a33b2.55dd5"]]}]
