Async getting list for node config
I'm pretty new with the developpement of nodes, but I didnt found my answer .
In fact, I'm searching a way to fill a config list, with dynamics items, coming from my node .
So, I'm searching a way to contact my node ? I saw we can use /inject/<id> to send an input, but not sure if it's the correct way to do this (because I want a return, and not send a message in the flow), and I didn't find where this is documented to check if I can get another endpoints ...
Did you have any idea ?
THe correct way to do this is to create an API endpoint in your node and call that from the Editor panel for the node.
Check out the serial-in node or uibuilder for examples.
serial in ? this one node-red-node-serialport ?
Yes, as in this is the endpoint (Julian was talking about) : node-red-nodes/25-serial.js at 5c333db0ddb445442a998452e7c55e89b81e08da · node-red/node-red-nodes · GitHub
that is called from the client side like this: node-red-nodes/25-serial.html at 5c333db0ddb445442a998452e7c55e89b81e08da · node-red/node-red-nodes · GitHub
yes, ok ... I will test it :slight_smile: . Thank you
