I'm using v5.0.0 - FROM nodered/node-red:5.0.0 - docker
Not sure what but this is a flow for the gif:
[{"id":"ddea3dc15b732da0","type":"junction","z":"764acaa01ca567f6","x":938.8037697414181,"y":740,"wires":[[]],"info":"Output 1"},{"id":"d8fe5eb1b7494df5","type":"junction","z":"764acaa01ca567f6","x":938.8037697414181,"y":800,"wires":[[]],"info":"Output 2"},{"id":"04d990c5e7821927","type":"junction","z":"764acaa01ca567f6","x":938.8037697414181,"y":680,"wires":[[]],"info":"Output 3"},{"id":"89ccde350d365bf7","type":"junction","z":"764acaa01ca567f6","x":563.5704361537718,"y":740,"wires":[["2a3977bdbf605991"]],"info":"Input 1"},{"id":"9abb3327e375a8ce","type":"junction","z":"764acaa01ca567f6","x":563.5704361537718,"y":740,"wires":[["b10ab26246f9b8e4"]],"info":"Input 2"},{"id":"005f97b343d99604","type":"group","z":"764acaa01ca567f6","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#767676","groupflow":{"version":5,"collapsed":false,"expanded":{"w":375.23333358764637,"h":215.0188679245282},"collapsedPosition":{"x":560.7402359584593,"y":591.0754561514225},"junctions":[{"id":"ddea3dc15b732da0","side":"right","ratio":0.5916988818676443,"offset":127.22642373139001,"direction":"output","name":"Output 1"},{"id":"d8fe5eb1b7494df5","side":"right","ratio":0.8707441609129235,"offset":187.22642373139,"direction":"output","name":"Output 2"},{"id":"04d990c5e7821927","side":"right","ratio":0.3126536028223651,"offset":67.22642373139001,"direction":"output","name":"Output 3"},{"id":"89ccde350d365bf7","side":"left","ratio":0.5916988818676443,"offset":127.22642373139001,"direction":"input","name":"Input 1"},{"id":"9abb3327e375a8ce","side":"left","ratio":0.5916988818676443,"offset":127.22642373139001,"direction":"input","name":"Input 2"}]}},"nodes":["2b532a5176d170ca","b10ab26246f9b8e4","2a3977bdbf605991"],"x":563.5704361537718,"y":612.77357626861,"w":375.23333358764637,"h":215.0188679245282},{"id":"2b532a5176d170ca","type":"function","z":"764acaa01ca567f6","g":"005f97b343d99604","name":"function 34","func":"\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":706.6037689784788,"y":653.77357626861,"wires":[["ddea3dc15b732da0"]]},{"id":"b10ab26246f9b8e4","type":"function","z":"764acaa01ca567f6","g":"005f97b343d99604","name":"function 35","func":"\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":746.2264104879127,"y":724.528293249742,"wires":[["d8fe5eb1b7494df5"]]},{"id":"2a3977bdbf605991","type":"switch","z":"764acaa01ca567f6","g":"005f97b343d99604","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":806.6037689784787,"y":786.7924441931382,"wires":[["04d990c5e7821927"]]}]
(the green inputs is something I did locally)
