Atmospheric pressure with Trend calculator
I've been suggested to share my little project, so here it is.
I have a atmospheric pressure sensor and wanted to get a little weather prediction on my dashboard:
And here are the nodes used to get this:
        "id": "1a7965f3b14b7163",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "f4ef17549bcdd8bf",
        "type": "inject",
        "z": "1a7965f3b14b7163",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1009.54",
        "payloadType": "str",
        "x": 120,
        "y": 180,
                "48355c7d023f2b70",
                "9499014ebc5d53b3",
                "5139626cee6bf13b",
                "6ed5d7e114155f42"
        "id": "48355c7d023f2b70",
        "type": "ui-gauge",
        "name": "ATM Press",
        "group": "63cc085a2f9ed996",
        "order": 4,
        "width": "3",
        "height": 3,
        "gtype": "gauge-half",
        "gstyle": "needle",
        "title": "ATM Press",
        "units": "hPa",
        "icon": "",
        "prefix": "",
        "suffix": "",
        "segments": [
                "from": "980",
                "color": "#0032ff"
                "from": "1009",
                "color": "#00ff32"
                "from": "1026",
                "color": "#ffbb00"
        "min": "980",
        "max": "1050",
        "sizeThickness": 16,
        "sizeGap": 4,
        "sizeKeyThickness": 8,
        "styleRounded": true,
        "styleGlow": false,
        "className": "",
        "x": 330,
        "y": 100,
        "id": "9499014ebc5d53b3",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "press",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 700,
        "y": 120,
        "id": "5139626cee6bf13b",
        "type": "function",
        "name": "Trend calc",
        "func": "var oldp = global.get(\"oldp\");\nmsg.payload = ((msg.payload - oldp) * 100).toFixed(0);\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 330,
        "y": 160,
                "5a6a8e3100cf5bf5",
                "2d85289ff1258b48"
        "id": "6ed5d7e114155f42",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "pressure/old",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 330,
        "y": 200,
                "9b793199dcd5d16d"
        "id": "5a6a8e3100cf5bf5",
        "type": "ui-template",
        "page": "",
        "ui": "",
        "name": "Trend",
        "order": 9,
        "width": 3,
        "height": 0,
        "head": "",
        "format": "<template>\n    <div class=\"panning-knob\">\n        <label class=\"pan-label\">10m Trend (<span v-text=\"value\"></span>)</label>\n        <input\n            type=\"range\"\n            min=\"-30\"\n            max=\"30\"\n            v-model=\"value\"\n            @input=\"send(value)\"\n            class=\"slider\"\n        />\n        <div class=\"pan-indicator\">\n            <span :class=\"{ activeL: value < -10 }\">Rainy</span>\n            <span :class=\"{ activeM: value >= -10 && value <= 10 }\">Stable</span>\n            <span :class=\"{ activeR: value > 10 }\">Clearing</span>\n        </div>\n    </div>\n</template>\n\n<style scoped>\n    .panning-knob {\n        width: 320px;\n        padding: 20px 10px 10px 10px;\n        background: white;\n        border-radius: 12px;\n        //box-shadow: 0 2px 8px rgba(0, 0, 0, 0.2);\n        display: flex;\n        flex-direction: column;\n        align-items: center;\n    }\n\n    .pan-label {\n        color: black;\n        font-size: 14px;\n        margin-bottom: 6px;\n        letter-spacing: 1px;\n    }\n\n    .slider {\n        width: 100%;\n        margin: 0 0 8px 0;\n        -webkit-appearance: none;\n        background: linear-gradient(90deg, #2196f3 0%, #eee 50%, #f44336 100%);\n        height: 8px;\n        border-radius: 4px;\n        outline: none;\n        transition: background 0.3s;\n    }\n\n    .slider::-webkit-slider-thumb {\n        -webkit-appearance: none;\n        appearance: none;\n        width: 22px;\n        height: 22px;\n        border-radius: 50%;\n        background: green;\n        border: 1px solid #333;\n        cursor: pointer;\n        box-shadow: 0 2px 6px rgba(0, 0, 0, 0.3);\n        transition: background 0.2s;\n    }\n    /* .triangle{\n        width: 0;\n        height: 0;\n        border-top: 10px solid transparent;\n        border-bottom: 10px solid transparent;\n        border-right:10px solid blue;\n    } */\n\n    .slider::-moz-range-thumb {\n        width: 22px;\n        height: 22px;\n        border-radius: 50%;\n        background: #ffeb3b;\n        border: 2px solid #333;\n        cursor: pointer;\n        box-shadow: 0 2px 6px rgba(0, 0, 0, 0.3);\n        transition: background 0.2s;\n    }\n\n    .slider::-ms-thumb {\n        width: 22px;\n        height: 22px;\n        border-radius: 50%;\n        background: #ffeb3b;\n        border: 2px solid #333;\n        cursor: pointer;\n        box-shadow: 0 2px 6px rgba(0, 0, 0, 0.3);\n        transition: background 0.2s;\n    }\n\n    .slider:focus {\n        outline: none;\n    }\n\n    .pan-indicator {\n        display: flex;\n        justify-content: space-between;\n        width: 100%;\n        font-size: 13px;\n        color: #888;\n        margin-top: 2px;\n    }\n\n    .pan-indicator span {\n        flex: 1;\n        text-align: center;\n        font-weight: bold;\n        opacity: 0.7;\n    }\n\n    .pan-indicator .activeL {\n        color: blue;\n        opacity: 1;\n    }\n    .pan-indicator .activeM {\n        color: green;\n        opacity: 1;\n    }\n    .pan-indicator .activeR {\n        color: gold;\n        opacity: 1;\n    }\n</style>",
        "storeOutMessages": true,
        "passthru": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 510,
        "y": 100,
        "id": "2d85289ff1258b48",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "trend",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 700,
        "y": 160,
        "id": "9b793199dcd5d16d",
        "type": "delay",
        "pauseType": "delay",
        "timeout": "600",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 510,
        "y": 200,
                "df4e064331e5892a"
        "id": "df4e064331e5892a",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "oldp",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 700,
        "y": 200,
        "id": "63cc085a2f9ed996",
        "type": "ui-group",
        "name": "Aer",
        "page": "863c7875112d9869",
        "width": "12",
        "height": 1,
        "order": 5,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false",
        "groupType": "default"
        "id": "863c7875112d9869",
        "type": "ui-page",
        "name": "Home",
        "ui": "5bd117d7db0d2853",
        "path": "/page1",
        "icon": "home",
        "layout": "grid",
        "theme": "bdb038ab42cbbbb6",
        "breakpoints": [
                "name": "Default",
                "px": "0",
                "cols": "3"
                "name": "Tablet",
                "px": "576",
                "cols": "6"
                "name": "Small Desktop",
                "px": "768",
                "cols": "9"
                "name": "Desktop",
                "px": "1024",
                "cols": "12"
        "order": 1,
        "className": "",
        "visible": true,
        "disabled": false
        "id": "5bd117d7db0d2853",
        "type": "ui-base",
        "name": "My Dashboard",
        "path": "/dashboard",
        "appIcon": "",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "headerContent": "page",
        "navigationStyle": "temporary",
        "titleBarStyle": "default",
        "showReconnectNotification": true,
        "notificationDisplayTime": 1,
        "showDisconnectNotification": true,
        "allowInstall": true
        "id": "bdb038ab42cbbbb6",
        "type": "ui-theme",
        "name": "Default Theme",
        "colors": {
            "surface": "#ffffff",
            "primary": "#0094CE",
            "bgPage": "#eeeeee",
            "groupBg": "#ffffff",
            "groupOutline": "#cccccc"
        "sizes": {
            "density": "default",
            "pagePadding": "12px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "12px"
Nice. Though I think I'd drop the DP's and make the display kPa to keep things neater. :slight_smile:
Yes, the flow is set in kPa, the pic is a little older, before the transformation!
