Filter Payload Data for Dashboard
Noob question.
I have a node extracting data from a BME 280 sensor. The payload comes out as follow
{“temperature_C”:21.77,“humidity”:52.70266127999612,“pressure_hPa”:1005.302539660442,“model”:“BME280”,“heatIndex”:24.842263805971022,“dewPoint_C”:11.683990939913583,“altitude_M”:66.34021220673784,“temperature_F”:71.186,“pressure_Hg”:29.68657143994413}
What is the best way to filter out just the “temperature_F” data so I can put it in a gauge in a dashboard?
Thanks.
Pedro
Try to put on the gauge {{msg.payload.temperature_Fº}} or {{msg.temperature_Fº}} I’m not sure
If the payload is a string rather than a javascript object then first feed it through a JSON node, then it will be an object and you can access the value by msg.payload.temperature_F.
@davidcgu Either {{msg.payload.temperature_F}} or {{payload.temperature_F}} should work. - You can drop the msg.
That worked. Thanks Guys!
