Displaying specific text from the array { TEMP, HUMI and EXTPWR}
hi am new to node red and not conversant with Js. please i just need to display the following value on the debug node and dashboard.
TEMP
HUMI
EXTPWR
the below is the msg.payload i receive
[{"flag":"DI0","switcher":0},
{"flag":"DI1","switcher":0},
{"flag":"DO0","switcher":0},
{"flag":"DO1","switcher":0},
{"flag":"TEMP","value":30.30},
{"flag":"HUMI","value":94.10},
{"flag":"EXTPWR","value":12.22}],
"time":"946952295"}
Welcome to the forum @AYo
You showed in the message first the fact that you are getting an array in msg.payload (or possibly a json string representing an array), but in the debug output you show there seems to be some extra text before the {"sensorDatas": [...
Can you clarify exactly what you are receiving?
If you do only have the string with the array int it then you should be able to first feed that into a JSON node to convert it to a javascript object, after that it is easy to do what you want.
Thanks Greatly for your reactivity ! @Colin
I connect to an Mqtt server and I use the debug Node to view all the data instead of serial monitor.
The debug Node display all the data i previously share. And I looking for away to only show just the TEMP, HUMI and EXTPWR only using function to put all other to nothing. Is that possible ?
Thanks again
Do you mean the one in the screenshot? Instead of posting a screenshot please copy the contents and paste it here. Use the Copy Value button (not Copy Path) as describe in this canned reply I am pasting below to get the value and then paste it here using the </> button at the top of the forum entry window when pasting it in. Canned reply follows:
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
https://nodered.org/docs/user-guide/messages
[Edit] Where is the MQTT data coming from, it seems odd with that strange text at the start?
The incoming string is a malformed json everything before and including the "#" needs to be removed.
It would be best if the device creating the string was corrected to send a properly formed json.
If that is not possible you will need to remove everything before the #, then pass it through a json node.
e.g.
[{"id":"4b63b34b.5458bc","type":"inject","z":"b779de97.b1b46","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":20,"wires":[["4e5d636a.3a3dcc"]]},{"id":"4e5d636a.3a3dcc","type":"template","z":"b779de97.b1b46","name":"simulate payload","field":"payload","fieldType":"msg","format":"handlebars","syntax":"plain","template":"gprs tx 255: 2$koolboks#{\"sensorDatas\":[{\"flag\":\"DI0\",\"switcher\":0},\n{\"flag\":\"DI1\",\"switcher\":0},\n{\"flag\":\"DO0\",\"switcher\":0},\n{\"flag\":\"DO1\",\"switcher\":0},\n{\"flag\":\"TEMP\",\"value\":30.30},\n{\"flag\":\"HUMI\",\"value\":94.10},\n{\"flag\":\"EXTPWR\",\"value\":12.22}],\n\"time\":\"946952295\"}\n","output":"str","x":320,"y":20,"wires":[["751b92e2.76b93c"]]},{"id":"751b92e2.76b93c","type":"change","z":"b779de97.b1b46","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$substringAfter($$.payload, \"#\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":60,"wires":[["54ed2cb4.5bdb54"]]},{"id":"54ed2cb4.5bdb54","type":"json","z":"b779de97.b1b46","name":"","property":"payload","action":"","pretty":false,"x":570,"y":60,"wires":[["17147e63.c7b362"]]},{"id":"17147e63.c7b362","type":"change","z":"b779de97.b1b46","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload.sensorDatas.${$.flag:$.value }","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":120,"wires":[["f068a596.996288"]]},{"id":"f068a596.996288","type":"debug","z":"b779de97.b1b46","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":750,"y":160,"wires":[]}]
You may well be correct, but I am not absolutely certain about that, it may be some unusual chars confusing the debug display. That is why I have asked the OP to use the Copy Value and paste it here.
gprs connectting: mqtt.dtuip.com:1883...
gprs rx 4:
MQTT send report...
gprs tx 263: 2�
gprs tx 263: 2�
i use Serial node to Debug the datas, because the broker i use on the node -red automatically reconnect and connect so i am currently using Serial node debuger prior to purchasing a broker server. just want to be sure i will be able view th TEMP, HUMI, and the EXTPWR value.
beside, the copy vale does not show the values in gprs tx 262:2
but i have pasted it below
2BK4F717WM3UF1ABU{"sensorDatas":[{"flag":"DI0","switcher":0},{"flag":"DI1","switcher":0},{"flag":"DO0","switcher":0},{"flag":"DO1","switcher":0},{"flag":"TEMP","value":32.60},{"flag":"HUMI","value":87.60},{"flag":"EXTPWR","value":12.22}],"time":"946965544"}↵"
thanks greatly ! @E1cid
ATM it is impossible to change from the device itself.
how do you think i can remove everything before #
Is it always #? as the data you posted does not have one.
If it is not then you can use the first "{"
Fix that first, it usually means that two clients are using the same client id. In node red it is usually best to leave the client id blank so node-red will create a unique id for you.
{"TEMP":30.3,"HUMI":94.1,"EXTPWR":12.22}
woow ! @E1cid i did import your code and it works.
let me play around it a bit i will revert !!!!
thanks again
although i will need to feed these in three dashboard for the TEMP, HUMI and EXTPWR
@E1cid
please can you help me complete this function for TEMP, HUMI and EXTERNAL PWR
        "id": "07a299801b1eb818",
        "type": "tab",
        "label": "Flow 4",
        "disabled": false,
        "info": "",
        "env": []
        "id": "7b0fc5cf2105c5e4",
        "type": "template",
        "z": "07a299801b1eb818",
        "name": "simulate payload",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "plain",
        "template": "gprs tx 255: 2$koolboks#{\"sensorDatas\":[{\"flag\":\"DI0\",\"switcher\":0},\n{\"flag\":\"DI1\",\"switcher\":0},\n{\"flag\":\"DO0\",\"switcher\":0},\n{\"flag\":\"DO1\",\"switcher\":0},\n{\"flag\":\"TEMP\",\"value\":30.30},\n{\"flag\":\"HUMI\",\"value\":94.10},\n{\"flag\":\"EXTPWR\",\"value\":12.22}],\n\"time\":\"946952295\"}\n",
        "output": "str",
        "x": 190,
        "y": 80,
                "becd8a7546e97aa9"
        "id": "becd8a7546e97aa9",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "$substringAfter($$.payload, \"#\")",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 240,
        "y": 140,
                "f9886b40b0f6934f"
        "id": "f9886b40b0f6934f",
        "type": "json",
        "property": "payload",
        "action": "",
        "pretty": false,
        "x": 250,
        "y": 200,
                "db5a9775a1f3f72a"
        "id": "db5a9775a1f3f72a",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "$$.payload.sensorDatas.${$.flag:$.value }",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 240,
        "y": 280,
                "69d373c68f2dee3c",
                "02b75c075070443a",
                "acbb20d805f4c80f",
                "e61f6dbb1542372c"
        "id": "69d373c68f2dee3c",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 250,
        "y": 360,
        "id": "6e7e35f567e854da",
        "type": "serial in",
        "name": "s270",
        "serial": "3f3490110108b9e5",
        "x": 70,
        "y": 180,
                "7b0fc5cf2105c5e4"
        "id": "b372356b8a29fc40",
        "type": "ui_gauge",
        "group": "d5da3e9b.46abf",
        "order": 5,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "TEMP",
        "label": " C",
        "format": "{{value}}",
        "min": 0,
        "max": 10,
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 670,
        "y": 60,
        "id": "48248f4c374787b8",
        "type": "ui_gauge",
        "order": 4,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "EXTERNAL PWR",
        "label": "V",
        "min": 0,
        "max": "14",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 730,
        "y": 300,
        "id": "4b9bec53a4b8694c",
        "type": "ui_gauge",
        "order": 6,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "HUMI",
        "label": "RH %",
        "min": 0,
        "max": "100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 670,
        "y": 180,
        "id": "02b75c075070443a",
        "type": "function",
        "name": "Incomplete [TEMP]",
        "func": "\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 490,
        "y": 60,
                "b372356b8a29fc40"
        "id": "acbb20d805f4c80f",
        "type": "function",
        "name": "incomplete [HUMI]",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 510,
        "y": 160,
                "4b9bec53a4b8694c"
        "id": "e61f6dbb1542372c",
        "type": "function",
        "name": "Incomplete [EXTPWR]",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 500,
        "y": 260,
                "48248f4c374787b8"
        "id": "3f3490110108b9e5",
        "type": "serial-port",
        "serialport": "COM4",
        "serialbaud": "115200",
        "databits": "8",
        "parity": "none",
        "stopbits": "1",
        "waitfor": "",
        "dtr": "none",
        "rts": "none",
        "cts": "none",
        "dsr": "none",
        "newline": "\\n",
        "bin": "false",
        "out": "char",
        "addchar": "",
        "responsetimeout": "10000"
        "id": "d5da3e9b.46abf",
        "type": "ui_group",
        "name": "DHT11",
        "tab": "784aac14.5c2404",
        "order": 2,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "784aac14.5c2404",
        "type": "ui_tab",
        "name": "S270",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
Thanks greatly !!!!!! :smile:
Thanks again for this !
oh i see thanks greatly !
please do you have any free port example?
i have use HiveMQ Cloud credentials but it seems the port is secure and the hardware could connect, i asked the OEM and they told me the device does not support secure, and the free port i found connects successfully but when i tried again, no connection.
please you can suggest any unencrypted open port for test.
thanks greatly
hi @Colin
i can receive data now from the MQTT broker. see the below.
        "type": "tab",
        "label": "Flow 4",
        "disabled": false,
        "info": "",
        "env": []
        "type": "template",
        "field": "payload",
        "fieldType": "msg",
        "syntax": "plain",
        "output": "str",
        "x": 310,
        "y": 100,
                "becd8a7546e97aa9"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 360,
        "y": 160,
                "f9886b40b0f6934f"
        "type": "json",
        "action": "",
        "pretty": false,
        "x": 370,
        "y": 220,
                "db5a9775a1f3f72a"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 360,
        "y": 300,
                "02b75c075070443a",
                "acbb20d805f4c80f",
                "e61f6dbb1542372c",
                "04f2a781f97bb5ef"
        "type": "ui_gauge",
        "order": 5,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "TEMP",
        "label": " C",
        "min": 0,
        "max": 10,
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 790,
        "y": 80,
        "type": "ui_gauge",
        "order": 4,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "label": "V",
        "min": 0,
        "max": "14",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 850,
        "y": 320,
        "type": "ui_gauge",
        "order": 6,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "HUMI",
        "label": "RH %",
        "min": 0,
        "max": "100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 790,
        "y": 200,
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 610,
        "y": 80,
                "b372356b8a29fc40"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 630,
        "y": 180,
                "4b9bec53a4b8694c"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 620,
        "y": 280,
                "48248f4c374787b8"
        "id": "55e81b83941a07da",
        "type": "mqtt in",
        "topic": "2BK4F717WM3UF1AB",
        "qos": "0",
        "datatype": "auto",
        "broker": "22c8989a884d7202",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 120,
        "y": 200,
                "7b0fc5cf2105c5e4"
        "id": "04f2a781f97bb5ef",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 580,
        "y": 400,
        "type": "ui_group",
        "name": "DHT11",
        "order": 2,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "22c8989a884d7202",
        "type": "mqtt-broker",
        "name": "S-270",
        "broker": "mqtt.dtuip.com",
        "port": "1883",
        "tls": "",
        "clientid": "2BK4F717WM3UF1AB",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
        "type": "ui_tab",
        "name": "S270",
        "order": 1,
        "disabled": false,
        "hidden": false
but i will need to push it to the dashboard, please help add the complete function code to display in each of the container, TEMP HUMI and EXTPWR, i ave tried all my best but not work
Thank you very much !
how to show on gauge example
[{"id":"4b63b34b.5458bc","type":"inject","z":"b779de97.b1b46","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":20,"wires":[["4e5d636a.3a3dcc"]]},{"id":"4e5d636a.3a3dcc","type":"template","z":"b779de97.b1b46","name":"simulate payload","field":"payload","fieldType":"msg","format":"handlebars","syntax":"plain","template":"gprs tx 255: 2$koolboks#{\"sensorDatas\":[{\"flag\":\"DI0\",\"switcher\":0},\n{\"flag\":\"DI1\",\"switcher\":0},\n{\"flag\":\"DO0\",\"switcher\":0},\n{\"flag\":\"DO1\",\"switcher\":0},\n{\"flag\":\"TEMP\",\"value\":30.30},\n{\"flag\":\"HUMI\",\"value\":94.10},\n{\"flag\":\"EXTPWR\",\"value\":12.22}],\n\"time\":\"946952295\"}\n","output":"str","x":320,"y":20,"wires":[["751b92e2.76b93c"]]},{"id":"751b92e2.76b93c","type":"change","z":"b779de97.b1b46","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"\"{\" & $substringAfter($$.payload, \"{\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":60,"wires":[["54ed2cb4.5bdb54"]]},{"id":"54ed2cb4.5bdb54","type":"json","z":"b779de97.b1b46","name":"","property":"payload","action":"","pretty":false,"x":570,"y":60,"wires":[["17147e63.c7b362"]]},{"id":"17147e63.c7b362","type":"change","z":"b779de97.b1b46","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload.sensorDatas.${$.flag:$.value }","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":120,"wires":[["f068a596.996288","5d6bc7f1.8c5dc","a36da4b2.5d85d8"]]},{"id":"f068a596.996288","type":"debug","z":"b779de97.b1b46","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":750,"y":160,"wires":[]},{"id":"5d6bc7f1.8c5dc","type":"ui_gauge","z":"b779de97.b1b46","name":"","group":"8b5cde76.edd58","order":9,"width":0,"height":0,"gtype":"gage","title":"gauge","label":"units","format":"{{msg.payload.TEMP}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":350,"y":160,"wires":[]},{"id":"a36da4b2.5d85d8","type":"ui_gauge","z":"b779de97.b1b46","name":"","group":"8b5cde76.edd58","order":10,"width":0,"height":0,"gtype":"gage","title":"gauge","label":"units","format":"{{msg.payload.HUMI}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":350,"y":200,"wires":[]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"8f03e639.85956","order":1,"disp":true,"width":"12","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
wow !!! :raised_hands::raised_hands::raised_hands::raised_hands::raised_hands::raised_hands::raised_hands:
