Can some one help me get msg.payload to data
Can some one help me get msg.payload to data dataTemp to function(scope) many Thanks...
i am beginner for node red ui code
Code:
[{"id":"66cb4ef1.3afa9","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"72261d28.63ecb4","type":"function","z":"66cb4ef1.3afa9","name":"randomData_0..100","func":"msg.payload = Math.round(Math.random()*100);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":180,"wires":[["7e6cded5.84a1f"]]},{"id":"7e6cded5.84a1f","type":"ui_template","z":"66cb4ef1.3afa9","group":"48190cbf.587d84","name":"","order":4,"width":"14","height":"6","format":"<!DOCTYPE html>\n<html xmlns=\"http://www.w3.org/1999/xhtml\">\n<head runat=\"server\">\n<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\"/>\n<title>Medidor Temperatura, Humedad</title>\n<script src=\"https://ajax.googleapis.com/ajax/libs/jquery/2.2.0/jquery.min.js\">\n</script>\n\n<script type=\"text/javascript\"\nsrc=\"https://www.gstatic.com/charts/loader.js\"></script>\n\n<script type=\"text/javascript\">\n google.charts.load('current', {\n  packages: ['gauge']\n}).then(function () {\n  var dataHumid = google.visualization.arrayToDataTable([\n    ['Label', 'Value'],\n    ['Humid', 0]\n  ]);\n\n  var dataTemp = google.visualization.arrayToDataTable([\n    ['Label', 'Value'],\n    ['Temp', 0]\n  ]);\n\n  var optionsHumid = {\n    width: 170, height: 170,\n    redFrom: 0, redTo: 33,\n    yellowFrom: 33, yellowTo: 66,\n    greenFrom: 66, greenTo: 100,\n    majorTicks: ['0','10','20','30','40','50','60','70','80','90', '100'],\n    minorTicks: 10\n  };\n\n  var formatHumid = new google.visualization.NumberFormat({\n    suffix: '%',\n    fractionDigits: 1\n  });\n  formatHumid.format(dataHumid, 1);\n\n  var optionsTemp = {\n    width: 170, height: 170,\n    redFrom: 30, redTo: 45,\n    yellowFrom: 24, yellowTo: 30,\n    greenFrom: 12, greenTo: 24,\n    majorTicks: ['0','10','20','30','40','50','60','70','80','90', '100'],\n    minorTicks: 10\n  };\n\n  var formatTemp = new google.visualization.NumberFormat({\n    suffix: 'h',\n    fractionDigits: 1\n  });\n  formatTemp.format(dataTemp, 1);\n\n  var chartHumid = new google.visualization.Gauge(document.getElementById(\"chart_Humid\"));\n  var chartTemp = new google.visualization.Gauge(document.getElementById(\"chart_Temp\"));\n  var ddt = 0;\n    var ddt1 = 1;\n     var ddt2 = 44;\n  \n     \n  chartHumid.draw(dataHumid, optionsHumid);\n  chartTemp.draw(dataTemp, optionsTemp);\n  \n\n  \n\n  \n  \n(function() {\n    var count = 0\n    function testit(msg,scope) {\n        count = count+1;\n        console.log(\"In testit \" + msg.payload + \"  count = \" + count);\n        scope.send({payload: \"from testit \" + msg.payload + \"  count = \" + count});\n       \n    }\n    var _data;\n    (function(scope) {\n        var _this = this;\n        scope.$watch('msg.payload', function(data) {\n            _this._data = dataTemp;\n        });\n    })(scope);\n    \n    \n    \n\n});\n\n\nsetInterval(function() {\n    /*\n    var JSON=$.ajax({\n      url:\"sensores.php\",\n      dataType: 'json',\n      async: false}).responseText;\n    var Respuesta=jQuery.parseJSON(JSON);\n    dataTemp.setValue(0, 1, Respuesta[0].temperature);\n    */\n    dataTemp.setValue(0, 1, 27.5);\n    formatTemp.format(dataTemp, 1);\n    chartTemp.draw(dataTemp, optionsTemp);\n  }, 1300);\n\n\n})();\n</script>\n</head>\n<body>\n      <p>{{msg.payload}}</p>\n      <div class=\"gauge\" id=\"chart_Humid\"></div>\n      <div class=\"gauge\" id=\"chart_Temp\"></div>\n</body>\n</html>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":600,"y":180,"wires":[[]]},{"id":"1f6219.ab303de7","type":"inject","z":"66cb4ef1.3afa9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"2","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":110,"y":180,"wires":[["72261d28.63ecb4"]]},{"id":"505efa6c.0e9bd4","type":"ui_template","z":"66cb4ef1.3afa9","d":true,"group":"48190cbf.587d84","name":"","order":4,"width":"14","height":"6","format":"<!DOCTYPE html>\n<html xmlns=\"http://www.w3.org/1999/xhtml\">\n<head runat=\"server\">\n<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\"/>\n<title>Medidor Temperatura, Humedad</title>\n<script src=\"https://ajax.googleapis.com/ajax/libs/jquery/2.2.0/jquery.min.js\">\n</script>\n\n<script type=\"text/javascript\"\nsrc=\"https://www.gstatic.com/charts/loader.js\"></script>\n\n<script type=\"text/javascript\">\n google.charts.load('current', {\n  packages: ['gauge']\n}).then(function () {\n  var dataHumid = google.visualization.arrayToDataTable([\n    ['Label', 'Value'],\n    ['Humid', 0]\n  ]);\n\n  var dataTemp = google.visualization.arrayToDataTable([\n    ['Label', 'Value'],\n    ['Temp', 0]\n  ]);\n\n  var optionsHumid = {\n    width: 170, height: 170,\n    redFrom: 0, redTo: 33,\n    yellowFrom: 33, yellowTo: 66,\n    greenFrom: 66, greenTo: 100,\n    majorTicks: ['0','10','20','30','40','50','60','70','80','90', '100'],\n    minorTicks: 10\n  };\n\n  var formatHumid = new google.visualization.NumberFormat({\n    suffix: '%',\n    fractionDigits: 1\n  });\n  formatHumid.format(dataHumid, 1);\n\n  var optionsTemp = {\n    width: 170, height: 170,\n    redFrom: 30, redTo: 45,\n    yellowFrom: 24, yellowTo: 30,\n    greenFrom: 12, greenTo: 24,\n    majorTicks: ['0','10','20','30','40','50','60','70','80','90', '100'],\n    minorTicks: 10\n  };\n\n  var formatTemp = new google.visualization.NumberFormat({\n    suffix: 'h',\n    fractionDigits: 1\n  });\n  formatTemp.format(dataTemp, 1);\n\n  var chartHumid = new google.visualization.Gauge(document.getElementById(\"chart_Humid\"));\n  var chartTemp = new google.visualization.Gauge(document.getElementById(\"chart_Temp\"));\n  var ddt = 0;\n    var ddt1 = 1;\n     var ddt2 = 44;\n  \n     \n  chartHumid.draw(dataHumid, optionsHumid);\n  chartTemp.draw(dataTemp, optionsTemp);\n  \n\n  setInterval(function() {\n    /*\n    var JSON=$.ajax({\n      url:\"sensores.php\",\n      dataType: 'json',\n      async: false}).responseText;\n    var Respuesta=jQuery.parseJSON(JSON);\n    dataHumid.setValue(0, 1, Respuesta[0].humidity);\n    */\n     dataHumid.setValue(0, 1, 33);\n                formatHumid.format(dataHumid, 1);\n                chartHumid.draw(dataHumid, optionsHumid);\n \n               \n                \n  }, 1300);\n\n  setInterval(function() {\n    /*\n    var JSON=$.ajax({\n      url:\"sensores.php\",\n      dataType: 'json',\n      async: false}).responseText;\n    var Respuesta=jQuery.parseJSON(JSON);\n    dataTemp.setValue(0, 1, Respuesta[0].temperature);\n    */\n    dataTemp.setValue(0, 1, 27.5);\n    formatTemp.format(dataTemp, 1);\n    chartTemp.draw(dataTemp, optionsTemp);\n  }, 1300);\n  \n(function() {\n    var count = 0\n    function testit(msg,scope) {\n        count = count+1;\n        console.log(\"In testit \" + msg.payload + \"  count = \" + count);\n        scope.send({payload: \"from testit \" + msg.payload + \"  count = \" + count});\n       \n    }\n    \n    (function(scope) {\n        scope.send({payload: \"preload\"});   // this gets sent when the view is opened in the browser\n        scope.$watch('msg', function(msg) {\n            if (msg) {\n                testit(msg, scope);\n                \n            }\n        });\n    })(scope);  \n\n});\n\n\n})();\n</script>\n</head>\n<body>\n      <p>{{msg.payload}}</p>\n      <div class=\"gauge\" id=\"chart_Humid\"></div>\n      <div class=\"gauge\" id=\"chart_Temp\"></div>\n</body>\n</html>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":780,"y":80,"wires":[[]]},{"id":"48190cbf.587d84","type":"ui_group","name":"Default","tab":"711389cf.7d4e18","order":1,"disp":true,"width":"25","collapse":false},{"id":"711389cf.7d4e18","type":"ui_tab","name":"Home1","icon":"dashboard","disabled":false,"hidden":false}]
Way above my skill set.
But I think near the top of the code in the node you need to get the msg.payload and make it visible for use later on.
eg:
var myVale = msg.payload
Then when you want to access the incoming value use myValue in the formula.
Hope that helps.
But that code is WAY above me.
Can you explain what you are trying to achieve ?
Firstly you set a boolean in the Inject node to true - but then do not seem to do anything with it
You then generate a random number in function node - and overwrite the boolean you first set
What are you trying to achieve ?
Craig
I attemping send msg.payload to gauge data with real time also data set is try reandom send to gauge
Number of issues...
  1. scope.$watch('msg.payload', function(data) - this should be scope.$watch('msg', function(data) (see the template node built in help
  2. Where does dataTemp come from? Your function signature is set to return data!
    packages: ['gauge']
  1. You never close the bracket of the then callback - the closing } is missing
Actually, I give up. Too many bits of code out of place.
Question: Why not use the built in chart?
Question: If you want help with google charts, where did you pull that example code from (I will attempt to fix it up from a working example)
Hi Steve
Thanks for you help me
The flow you have posted is the same as last time - still lots of errors!
I will help if you answer the questions...
Question: Why not use the built in chart? The chart in dashboard is working for me, i am beginner java script in ui node. i will try with you recooment and consult you?
as link
Here, this will get you going...
DMGmVupL1v
[{"id":"600544fec28e6bf4","type":"ui_template","z":"f993f14ce98bb2ad","group":"48190cbf.587d84","name":"gauges","order":4,"width":"8","height":"11","format":"\n\n<div id=\"humid_chart\"></div>\n<div id=\"temp_chart\"></div>\n\n<script type=\"text/javascript\">\n(function(scope) {\n\n    var _scope = scope;\n\n    var humid_chart;\n    var humid_data;\n    var humid_formatter;\n    var humid_options = {\n      width: 170, height: 170,\n      redFrom: 0, redTo: 33,\n      yellowFrom: 33, yellowTo: 66,\n      greenFrom: 66, greenTo: 100,\n      majorTicks: ['0','10','20','30','40','50','60','70','80','90', '100'],\n      minorTicks: 10\n    };\n\n    var temp_chart;\n    var temp_data;\n    var temp_formatter;\n    var temp_options = {\n      width: 170, height: 170,\n      redFrom: 30, redTo: 45,\n      yellowFrom: 24, yellowTo: 30,\n      greenFrom: 12, greenTo: 24,\n      majorTicks: ['0','10','20','30','40','50','60','70','80','90', '100'],\n      minorTicks: 10\n    };\n\n    \n    _scope.$watch('msg', function(msg) {\n      if(msg && msg.topic && typeof msg.payload == \"number\") {\n        if(msg.topic == \"humid\") {\n          if(humid_chart) {\n            humid_data.setValue(0, 1, msg.payload);\n            humid_formatter.format(humid_data, 1);\n            humid_chart.draw(humid_data, humid_options);\n          }\n        }\n        if(msg.topic == \"temp\") {\n          if(temp_chart) {\n            temp_data.setValue(0, 1, msg.payload);\n            temp_formatter.format(temp_data, 1);\n            temp_chart.draw(temp_data, humid_options);\n          }\n        }\n      }\n    });\n\n\n\n    google.charts.load('current', {'packages':['gauge']});\n    google.charts.setOnLoadCallback(initCharts);\n\n    function initCharts(){\n      initHumid();\n      initTemp();\n    }\n\n    function initHumid() {\n      humid_data = google.visualization.arrayToDataTable([\n        ['Label', 'Value'],\n        ['Humid', 0],\n      ]);\n      humid_formatter = new google.visualization.NumberFormat({\n        suffix: '%',\n        fractionDigits: 1\n      });\n      humid_chart = new google.visualization.Gauge(document.getElementById('humid_chart'));\n    }\n\n    function initTemp() {\n      temp_data = google.visualization.arrayToDataTable([\n        ['Label', 'Value'],\n        ['Temp', 0],\n      ]);\n\n\n      temp_formatter = new google.visualization.NumberFormat({\n        suffix: 'H',\n        fractionDigits: 1\n      });\n      temp_chart = new google.visualization.Gauge(document.getElementById('temp_chart'));\n    }\n    \n\n})(scope);\n\n</script> ","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","className":"","x":360,"y":220,"wires":[[]]},{"id":"db2ebb0bf6ea1b1b","type":"inject","z":"f993f14ce98bb2ad","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":110,"y":180,"wires":[["217fc1249c6f5e1f"]]},{"id":"217fc1249c6f5e1f","type":"function","z":"f993f14ce98bb2ad","name":"randomData_0..100","func":"var msg1 = {};\nmsg1.topic = \"humid\";\nmsg1.payload = Math.round(Math.random()*100);\n\nvar msg2 = {};\nmsg2.topic = \"temp\";\nmsg2.payload = Math.round(Math.random()*100);\n\nreturn [[msg1, msg2]];","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":330,"y":160,"wires":[["600544fec28e6bf4"]]},{"id":"bc6084bef1b6920e","type":"ui_button","z":"f993f14ce98bb2ad","name":"","group":"48190cbf.587d84","order":1,"width":"3","height":"1","passthru":false,"label":"random values","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"true","payloadType":"bool","topic":"topic","topicType":"msg","x":120,"y":140,"wires":[["217fc1249c6f5e1f"]]},{"id":"9b505bb01ec73ec2","type":"ui_template","z":"f993f14ce98bb2ad","group":"dce9e7a2.d20c78","name":"head script","order":8,"width":0,"height":0,"format":"<script type=\"text/javascript\" src=\"https://www.gstatic.com/charts/loader.js\"></script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","className":"","x":350,"y":100,"wires":[[]]},{"id":"48190cbf.587d84","type":"ui_group","name":"Default","tab":"711389cf.7d4e18","order":1,"disp":true,"width":"25","collapse":false},{"id":"dce9e7a2.d20c78","type":"ui_group","name":"Object detection","tab":"5132060d.4cde48","order":1,"disp":true,"width":"9","collapse":false},{"id":"711389cf.7d4e18","type":"ui_tab","name":"Home1","icon":"dashboard","disabled":false,"hidden":false},{"id":"5132060d.4cde48","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Thank you so much Steve for you help me
