Attempt to run node-red admin init failed
I've installed NR 2.01 successfully in Docker on a QNAP NAS.
If I SSH into the container and issue the command :
node-red admin init
All I get is a :
node-red: not found
So, I assumed that although not mentioned anywhere I could find, node-red admin is something that needs to be installed, right? So I tried :
sudo npm install -g node-red-admin
That too failed because the container image I pulled from Docker HUB doesn't understand sudo. So, I tried without, and I got this:
npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules
npm ERR! code EACCES
npm ERR! syscall access
npm ERR! path /usr/local/lib/node_modules
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules'
npm ERR!  [Error: EACCES: permission denied, access '/usr/local/lib/node_modules'] {
npm ERR!   errno: -13,
npm ERR!   code: 'EACCES',
npm ERR!   syscall: 'access',
npm ERR!   path: '/usr/local/lib/node_modules'
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR!     /usr/src/node-red/.npm/_logs/2021-07-21T20_22_04_066Z-debug.log
I am amazed about the wast distance between the simplicity and ease-of-use described in the "Getting Started" section, and the real world whenever I actually try to do what it says - always! (Why is it that whenever I try anything in the Linux world, nothing ever works as described?)
Oh, it always works as described. It's just that what was described actually came through a multi-dimensional wormhole and you, as a mere non-linux specialist, don't have the 10-dimensional brain that the author has.
At least that's what I've always believed about authors of Linux documentation! :rofl:
What other reasonable explanation could there be?
Maybe a little harsh when you consider the multitude of different operating systems, and user environments where node-RED is expected to faultlessly perform, especially when the issue relates to an update made just a few days earlier...
I’m always amazed at the vast number of hardware and os variations that people try to run things on.
The error shown says that it is the actual node-red command is not found in the path. So you just need to locate that in your system.
Thank you. That was at least a hint in a direction.
Obviously, building the image so that the admin tool became available on the path (or extending the path to include this tool - wherever it is located), never crossed the mind of any of the developers, and the author of the docs never bothered to mention where to find it.
Isn't that great?
So, I did this:
find -name node-red.*
and this is what I got:
find: ./proc/tty/driver: Permission denied
find: ./root: Permission denied
./usr/src/node-red/node_modules/@node-red/editor-client/public/red/images/node-red.svg
So, I'm still stuck in the Linux mud.
Well I’m sure if someone donated one set of every possible piece of hardware to the developers they would be delighted to check it for you.
Maybe try just find . -name node-red
./usr/src/node-red
./usr/src/node-red/node_modules/@node-red/editor-client/public/types/node-red
./usr/src/node-red/node_modules/.bin/node-red
./usr/src/node-red/node_modules/node-red
Is the one to try first
No idea why npm on your system doesn’t add that .bin directory to your path for you.
"my system" ?
I just copied "latest" image from Docker HUB. How can that be "my system" ?
Ah right it’s in docker
Yes, it's in docker.
And I find it strange that the main executable (node-red) isn't on the path!
How come the container managed to run this executable at all, when it's not even on the path?
the container calls it explicitily - but it should be at node_modules/.bin/node-red admin init
Yes, I found it now - thanks to you :slight_smile:
and yes - will think about adding to path properly. thanks
Many thanks for your help.
latest version (2.0.2) now has path fixed...
Uhuu... that was fast!
So my "grumpy" remarks did end up as a contribution! Maybe Linux isn't that bad after all :+1::hugs:
The stars aligned well. It was a simple fix, I was near WiFi (on vacation), and there was a new release today.
