Node-red-admin wont install
Hi, long time lurker, first time poster.
I tinker with many rpi 0 w's running raspbian, a while ago on I set up node-red-admin on Jessie, the install went smoothly, now I just get this every time:
root@squid:/home/pi/.node-red# sudo npm install -g node-red-admin
npm WARN deprecated bcrypt@0.8.7: bcrypt < v2.0.0 is susceptible to bcrypt wrap-around bug. Upgrade to bcrypt >= v2.0.0 for improved support for newer bcrypt hashes
npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
npm WARN deprecated hoek@2.16.3: The major version is no longer supported. Please update to 4.x or newer
/usr/bin/node-red-admin -> /usr/lib/node_modules/node-red-admin/node-red-admin.js
> bcrypt@0.8.7 install /usr/lib/node_modules/node-red-admin/node_modules/bcrypt
> node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.11.1"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/lib/node_modules/node-red-admin/node_modules/bcrypt/.node-gyp"
gyp WARN install got an error, rolling back install
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir '/usr/lib/node_modules/node-red-admin/node_modules/bcrypt/.node-gyp'
gyp ERR! System Linux 4.14.52+
gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /usr/lib/node_modules/node-red-admin/node_modules/bcrypt
gyp ERR! node -v v8.11.1
gyp ERR! node-gyp -v v3.7.0
gyp ERR! not ok
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@0.8.7 (node_modules/node-red-admin/node_modules/bcrypt):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@0.8.7 install: node-gyp rebuild
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
Any recommendations?
Recomndations...here you go
  1. don’t run as root! Run as pi
  2. are you meaning to use ā€˜node-red-contrib-admin’?
  3. if you are trying to install node-RED! Use the script descripbe in the documentation
This is the sequence I use to install Node-Red .. using the raspbian image
$ sudo apt -y update
$ sudo apt -y upgrade
$ sudo raspi-config
-- config hostname
-- config timezone
-- enable ssh
$ sudo shutdown -r now
==>login via ssh
==>install npm &amp; n
$ sudo apt -y install npm
$ sudo npm install -g n
$ sudo n stable
$ sudo apt-get install git
==> install node-red
$ bash &lt;(curl -sL https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/update-nodejs-and-nodered)
$ cd ~/.node-red
$ npm rebuild
==> Autostart on boot
$ sudo wget https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/nodered.service -O /lib/systemd/system/nodered.service
$ sudo systemctl daemon-reload
$ sudo systemctl enable nodered.service
==> install samba
$ sudo apt install samba samba-common-bin winbind
$ sudo mkdir -m 1777 /share
$ sudo nano /etc/samba/smb.conf
==> check workgroup = WORKGROUP
[home]
Comment = Pi shared folder
Path = /home/pi
browseable = yes
writeable = Yes
only guest = no
create mask = 0777
directory mask = 0777
Public = yes
Guest ok = yes
[nodes]
Path = /home/pi/.node-red
Browseable = yes
Writeable = Yes
only guest = no
create mask = 0777
Public = yes
Guest ok = yes
$ sudo smbpasswd -a pi
$ sudo /etc/init.d/samba restart
==> install webmin
$ sudo apt-get install perl libnet-ssleay-perl openssl libauthen-pam-perl libpam-runtime libio-pty-perl apt-show-versions python
$ wget http://prdownloads.sourceforge.net/webadmin/webmin_1.890_all.deb
$ sudo dpkg --install webmin_1.890_all.deb
Wow speedy response, thanks
  1. documentation recommend run as root,
2.No I haven't tried node-red-contrib-admin, is that the way people in the know do it? will check it out after I try xx_nexus_xx method
  1. Yes I always use that script
Thanks, will have to try that when I get home, having internet issues here at work
They are WARN not errors so not a problem. Carry on.
(Though we haven't really used node-red-admin for ages - most of what it did can now be done via the UI so you may not need it - unless you have a specific need for it)
Tried to ignore, wont give me a hashed passwd without it (node-red-admin hash-pw)
ah yes - :slight_smile: but you can still ignore he warnings - it should still work
Holy crap, you are right, it works!! I was sure i tested it before and it failed, I have been stuck on this for an embarrassing long time!! Thanks to all of you, I should have asked much earlier
Didn't follow all your steps because want to keep it as minimal as possible, turns out it works despite errors, but I checked out webmin, looks great. Thanks for that and sharing your sequence
