Node-Red-Admin install failed
I would like to install node-red-admin and secure my installation, but unfortunately the installation fails with several errors that I do not understand:
pi@raspberrypi:~ $ sudo npm install -g node-red-admin
/usr/local/bin/node-red-admin -> /usr/local/lib/node_modules/node-red-admin/node-red-admin.js
> bcrypt@3.0.7 install /usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt
> node-pre-gyp install --fallback-to-build
node-pre-gyp WARN Using request for node-pre-gyp https download
node-pre-gyp WARN Pre-built binaries not installable for bcrypt@3.0.7 and node@12.14.0 (node-v72 ABI, glibc) (falling back to s                                                  ource compile with node-gyp)
node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt/li                                                  b'
gyp WARN EACCES current user ("nobody") does not have permission to access the dev dir "/root/.cache/node-gyp/12.14.0"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt                                                  /.node-gyp"
gyp WARN install got an error, rolling back install
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt/.node-gy                                                  p'
gyp ERR! System Linux 4.19.75-v7l+
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--f                                                  allback-to-build" "--module=/usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt/lib/binding/bcrypt_lib.node" "--modu                                                  le_name=bcrypt_lib" "--module_path=/usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt/lib/binding" "--napi_version=                                                  5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
gyp ERR! cwd /usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt
gyp ERR! node -v v12.14.0
gyp ERR! node-gyp -v v5.0.5
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin                                                  /node-gyp.js configure --fallback-to-build --module=/usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt/lib/binding/                                                  bcrypt_lib.node --module_name=bcrypt_lib --module_path=/usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt/lib/bindi                                                  ng --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/node-red-admin/node_modules/node-pre-gyp/l                                                  ib/util/compile.js:83:29)
node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:210:5)
node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
node-pre-gyp ERR! System Linux 4.19.75-v7l+
node-pre-gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/node-red-admin/node_modules/.bin/node-pre-gyp" "in                                                  stall" "--fallback-to-build"
node-pre-gyp ERR! cwd /usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt
node-pre-gyp ERR! node -v v12.14.0
node-pre-gyp ERR! node-pre-gyp -v v0.13.0
node-pre-gyp ERR! not ok
Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallba                                                  ck-to-build --module=/usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt/lib/binding/bcrypt_lib.node --module_name=b                                                  crypt_lib --module_path=/usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt/lib/binding --napi_version=5 --node_abi_                                                  napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@3.0.7 (node_modules/node-red-admin/node_modules/bcrypt):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@3.0.7 install: `node-pre-gyp install --fallback-to-build`
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
+ node-red-admin@0.1.5
added 57 packages from 74 contributors in 12.707s
pi@raspberrypi:~ $ node -v
v12.14.0
pi@raspberrypi:~ $ npm -v
6.13.4
pi@raspberrypi:~ $
Does anyone understand this ?
Hi @Golonder
there appears to be a permissions error when it has tried to build the bcrypt optional dependency.
Despite all of the error messages, you can see it reported it was skipping the optional dependency and it did actually install successfully.
You should find you have the node-red-admin command available to you now.
Or try with
sudo npm install -g --unsafe-perm node-red-admin
Though you can also just use the node command to generate the password hash as documented here
https://nodered.org/docs/user-guide/runtime/securing-node-red#generating-the-password-hash
