Problema node-red
C:\Users\Daniel>npm install -g --unsafe-perm node-red
npm WARN deprecated bcrypt@3.0.6: versions < v5.0.0 do not handle NUL in passwords properly
npm WARN deprecated request@2.88.0: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated bcrypt@3.0.8: versions < v5.0.0 do not handle NUL in passwords properly
C:\Users\Daniel\AppData\Roaming\npm\node-red -> C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\red.js
C:\Users\Daniel\AppData\Roaming\npm\node-red-pi -> C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\bin\node-red-pi
bcrypt@3.0.6 install C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\bcrypt
node-pre-gyp install --fallback-to-build
node-pre-gyp WARN Using request for node-pre-gyp https download
node-pre-gyp WARN Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v3.0.6/bcrypt_lib-v3.0.6-node-v83-win32-x64-unknown.tar.gz
node-pre-gyp WARN Pre-built binaries not found for bcrypt@3.0.6 and node@14.15.1 (node-v83 ABI, unknown) (falling back to source compile with node-gyp)
gyp ERR! find Python
gyp ERR! find Python Python is not set from command line or npm configuration
gyp ERR! find Python Python is not set from environment variable PYTHON
gyp ERR! find Python checking if "python" can be used
gyp ERR! find Python - "python" is not in PATH or produced an error
gyp ERR! find Python checking if "python2" can be used
gyp ERR! find Python - "python2" is not in PATH or produced an error
gyp ERR! find Python checking if "python3" can be used
gyp ERR! find Python - "python3" is not in PATH or produced an error
gyp ERR! find Python checking if the py launcher can be used to find Python 2
gyp ERR! find Python - "py.exe" is not in PATH or produced an error
gyp ERR! find Python checking if Python is C:\Python27\python.exe
gyp ERR! find Python - "C:\Python27\python.exe" could not be run
gyp ERR! find Python checking if Python is C:\Python37\python.exe
gyp ERR! find Python - "C:\Python37\python.exe" could not be run
gyp ERR! find Python **********************************************************
gyp ERR! find Python You need to install the latest version of Python.
gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
gyp ERR! find Python you can try one of the following options:
gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
gyp ERR! find Python (accepted by both node-gyp and npm)
gyp ERR! find Python - Set the environment variable PYTHON
gyp ERR! find Python - Set the npm configuration variable python:
gyp ERR! find Python npm config set python "C:\Path\To\python.exe"
gyp ERR! find Python For more information consult the documentation at:
gyp ERR! find Python GitHub - nodejs/node-gyp: Node.js native addon build tool
gyp ERR! configure error
gyp ERR! stack Error: Could not find any Python installation to use
gyp ERR! stack at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)
gyp ERR! stack at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)
gyp ERR! stack at PythonFinder. (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)
gyp ERR! stack at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)
gyp ERR! stack at exithandler (child_process.js:315:5)
gyp ERR! stack at ChildProcess.errorhandler (child_process.js:327:5)
gyp ERR! stack at ChildProcess.emit (events.js:315:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
gyp ERR! stack at onErrorNT (internal/child_process.js:465:16)
gyp ERR! stack at processTicksAndRejections (internal/process/task_queues.js:80:21)
gyp ERR! System Windows_NT 10.0.18363
gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "configure" "--fallback-to-build" "--module=C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\bcrypt\lib\binding\bcrypt_lib.node" "--module_name=bcrypt_lib" "--module_path=C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\bcrypt\lib\binding" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
gyp ERR! cwd C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\bcrypt
gyp ERR! node -v v14.15.1
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\bcrypt\lib\binding\bcrypt_lib.node --module_name=bcrypt_lib --module_path=C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\bcrypt\lib\binding --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
node-pre-gyp ERR! stack at ChildProcess. (C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:315:20)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1048:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
node-pre-gyp ERR! System Windows_NT 10.0.18363
node-pre-gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\bcrypt
node-pre-gyp ERR! node -v v14.15.1
node-pre-gyp ERR! node-pre-gyp -v v0.12.0
node-pre-gyp ERR! not ok
bcrypt@3.0.8 install C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\node-red-admin\node_modules\bcrypt
node-pre-gyp WARN Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v3.0.8/bcrypt_lib-v3.0.8-node-v83-win32-x64-unknown.tar.gz
node-pre-gyp WARN Pre-built binaries not found for bcrypt@3.0.8 and node@14.15.1 (node-v83 ABI, unknown) (falling back to source compile with node-gyp)
gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "configure" "--fallback-to-build" "--module=C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\node-red-admin\node_modules\bcrypt\lib\binding\bcrypt_lib.node" "--module_name=bcrypt_lib" "--module_path=C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\node-red-admin\node_modules\bcrypt\lib\binding" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
gyp ERR! cwd C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\node-red-admin\node_modules\bcrypt
gyp ERR! not ok
node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\node-red-admin\node_modules\bcrypt\lib\binding\bcrypt_lib.node --module_name=bcrypt_lib --module_path=C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\node-red-admin\node_modules\bcrypt\lib\binding --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
node-pre-gyp ERR! stack at ChildProcess. (C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\node-red-admin\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
node-pre-gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\node-red-admin\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd C:\Users\Daniel\AppData\Roaming\npm\node_modules\node-red\node_modules\node-red-admin\node_modules\bcrypt
node-pre-gyp ERR! node-pre-gyp -v v0.14.0
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@3.0.6 (node_modules\node-red\node_modules\bcrypt):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@3.0.6 install: node-pre-gyp install --fallback-to-build
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@3.0.8 (node_modules\node-red\node_modules\node-red-admin\node_modules\bcrypt):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@3.0.8 install: node-pre-gyp install --fallback-to-build
  • node-red@1.2.6
    updated 1 package in 18.25s
Do you have a question?
Ps... Please edit that post & put backticks around the log data...
log data & code should be between 3 backticks like this
