I uninstalled node-red usingsudo npm uninstall -g node-red and reinstalled it using sudo npm install -g --unsafe-perm node-red. I am getting following error while installing.
node-pre-gyp ERR! Completion callback never invoked!
node-pre-gyp ERR! System Linux 4.15.0-34-generic
node-pre-gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/node-red/node_modules/bcrypt/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/bcrypt
node-pre-gyp ERR! node -v v8.10.0
node-pre-gyp ERR! node-pre-gyp -v v0.9.1
node-pre-gyp ERR! This is a bug in `node-pre-gyp`.
node-pre-gyp ERR! Try to update node-pre-gyp and file an issue if it does not help:
node-pre-gyp ERR! <https://github.com/mapbox/node-pre-gyp/issues>
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/node-red/node_modules/bcrypt):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: `node-pre-gyp install --fallback-to-build`
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 6
What is the reason for this issue?
