Is there a way to run this script on the client?
[{"id":"d6507d5.db6618","type":"tab","label":"Flow 5","disabled":false,"info":""},{"id":"89139738.8efc68","type":"ui_button","z":"d6507d5.db6618","name":"","group":"41df6da4.9283d4","order":1,"width":0,"height":0,"passthru":false,"label":"button","tooltip":"","color":"","bgcolor":"","icon":"","payload":"May Test","payloadType":"str","topic":"","x":205.5,"y":159,"wires":[["1e370710.fbb1d9","83557aa3.88c3c8"]]},{"id":"1e370710.fbb1d9","type":"function","z":"d6507d5.db6618","name":"","func":"window.addEventListener('touchstart', function() {\n\n\t// create new buffer source for playback with an already\n\t// loaded and decoded empty sound file\n\tvar source = myContext.createBufferSource();\n\tsource.buffer = myDecodedBuffer;\n\n\t// connect to output (your speakers)\n\tsource.connect(myContext.destination);\n\n\t// play the file\n\tsource.noteOn(0);\n\n}, false);","outputs":1,"noerr":0,"x":393,"y":110,"wires":[["21b1450a.258cfa"]]},{"id":"21b1450a.258cfa","type":"debug","z":"d6507d5.db6618","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":579,"y":111,"wires":[]},{"id":"83557aa3.88c3c8","type":"delay","z":"d6507d5.db6618","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":362,"y":182,"wires":[["e4ac0db1.160d6"]]},{"id":"e4ac0db1.160d6","type":"ui_audio","z":"d6507d5.db6618","name":"","group":"c41bfe3d.aa17c","voice":"pt-BR","always":true,"x":513.5,"y":187,"wires":[]},{"id":"41df6da4.9283d4","type":"ui_group","z":"","name":"Default","tab":"42562d98.3bd3e4","disp":true,"width":"6","collapse":false},{"id":"c41bfe3d.aa17c","type":"ui_group","z":"","name":"Default","tab":"42562d98.3bd3e4","disp":true,"width":"6","collapse":false},{"id":"42562d98.3bd3e4","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Or is there any other way to make the audio work in the browsers of the mobile?
