Await delay(1000) - error in array
I try to use await delay(1000) into this function
const delay = ms => new Promise(res => context.set("timer", setTimeout(res, ms)));
//x is an array
const x = msg.payload;
x.forEach(element => {
    const valore = (element.value)
    const id = (element.id)
    msg.topic = "UPDATE Variables SET Valore = '" + valore + "' WHERE Id = " + id
    msg.pass = 2
    node.status(valore + " " + id)
    node.send(msg)
    await delay(1000);
but I have this error:
How can I fix it?
Have you tried the "quick fix" (hint, the arrow function must be async - just like the tip says)
That said...
This is NOT the node-red / low-code way. Get rid of the async await & simply send all your messages out of the function without delay then pass the msg through a delay node set to rate limit 1 msg per sec.
And better still, create a more efficient SQL update statement that does it all in 1 statement.
Yes,
I tried the "quick fix" and the function works but without delay ......
It's what I did until today, then I thought this method was better (have a break before instead after) .....
You're right, but this is the better that I can do ....
Ah ok, yes. You cannot delay an array forEach. You would need to use a regular for loop
What @TotallyInformation says is a single statement.
Instead of looping one by one, create a single string with all the update statements and then execute it. This is extremely fast.
eg.
const input = msg.payload;
const output = ""
input.forEach(el => {
    output += `UPDATE Variables SET Valore = '${el.value}' WHERE Id = ${el.id};`
msg.topic = output
return msg
Thank you so much!
Note that if your SQL DB supports them, prepared statements are typically FAR more efficient, especially for repeated updates and inserts.
