AWS EBS settings.js missing
Following the instructions to get started with an EBS on AWS, per this page: https://nodered.org/docs/platforms/aws
And I found a bad link, for the example settings.js -
https://github.com/node-red/node-red/blob/master/settings.js - this is a bad link. Can someone provide this example settings.js?
@mlabman, you're right; the link in the documentation seems to be wrong. You probably should raise an issue against the the documentation on GitHub -- or better yet, submit a PR.
Thanks - no worries - have updated the docs in line with the new 0.20 packaging. (which is why the file moved).
Thanks for spotting it.
