Hi everyone,
I have this css and I want to change this button node to black with white letters. I have tried several ways and nothing, not even from the node itself.
<style>
/*Main background*/
body {
background: -webkit-linear-gradient(
55deg,
#009785 0%,
#245aa5 50%,
#b800e9 100%
/*Top bar*/
body.nr-dashboard-theme md-toolbar,
body.nr-dashboard-theme md-content md-card {
background-color: transparent !important;
color: #FFFFFF !important;
/*Left menu*/
/*Sidebar*/
body.nr-dashboard-theme md-sidenav {
color: white !important;
background-color: rgba(0,0,0,0) !important;
/*Hover selection*/
a.md-no-style, button.md-no-style {
border-radius: 10px !important;
/*Selected*/
.nr-menu-item-active div button {
border-right: 4px solid rgb(41 98 255) !important;
/*List*/
body.nr-dashboard-theme md-sidenav div.md-list-item-inner {
background-color: rgba(40,85,165,1) !important;
/*Groups*/
ui-card-panel {
background-color: rgba(255,255,255,0.1) !important;
.nr-dashboard-theme ui-card-panel {
border: none !important;
/*Name groups*/
.nr-dashboard-theme ui-card-panel p.nr-dashboard-cardtitle {
color: rgba(255, 255, 255, 0.5) !important;
/*Bouttons*/
.nr-dashboard-theme .nr-dashboard-button .md-button {
background-color: rgba(255,255,255,.1) !important;
.md-button {
/*Dropdown menu*/
.nr-dashboard-theme md-select-menu{
.nr-dashboard-theme md-select-menu, .nr-dashboard-theme md-select-menu md-option {
.nr-dashboard-theme .md-select-menu-container {
.nr-dashboard-theme md-select-menu md-option[selected] {
background-color: #1a3566 !important;
/*Template*/
md-card>img, md-card>md-card-header img, md-card md-card-title-media img {
/* Color picker text BG */
.nr-dashboard-theme .color-picker-input-wrapper > input {
/* Agrega esta regla después del bloque existente */
body.nr-dashboard-theme p {
/*nose si funciona */
ui-card-panel:has(.invisible-group){
opacity:0 !important;
body.nr-dashboard-theme .mi-elemento {
font-weight: bold !important;
/* Otros estilos personalizados */
body.nr-dashboard-theme .mi-elemento-2 {
font-size: 20px;
/* background grafica */
body.nr-dashboard-theme .mi-elemento-3 {
background-color: black !important;
</style>
Thank you very much!
Best regards
If one and only button should be different from others, give it a unique class name and for your dashboard CSS add
.your-unique-class-name button {
Yesterday I did something similar and it didn't work, and now I've put your code and it doesn't work either. It's as if I were stepping on a code from above.
Thank you very much!!
button is not unique enough.
If you choose some class name ("my-unique-button" on that next image)
you'll need to adjust the CSS rule accordingly
.my-unique-button button {
In CSS class name, I have put:
button
Then I changed your-unique-class-name to my-button, also button to another name and nothing
OK. That is because you already use the !important flag for all of your buttons.
It takes over what ever you choose do afterwards. Powerful but same time restrictive rule.
Still there are some tricks...
Change your CSS rule
/*Bouttons*/
background-color: rgba(255, 255, 255, .1) !important;
To not affect buttons where you need to have different look.
/*Bouttons*/
.nr-dashboard-theme .nr-dashboard-button:not(.my-unique-button) .md-button {
See the :not() selectror.
You are using the !important flag on every rule. That is not recommended way to do things. Use it only for last resort if you can't make your rules to apply due the CSS specificity.
You know!, yesterday I saw that it could come from there...thank you very much.
I have changed that and now the buttons are like this, instead of transparent for example state is invisible, why change?
Doesn't happen for me. Paste again your CSS
Thank you very much for helping me!!
<style>
/*Main background*/
body {
55deg,
#009785 0%,
#245aa5 50%,
#b800e9 100%
/*Top bar*/
/*Left menu*/
/*Sidebar*/
/*Hover selection*/
/*Selected*/
/*List*/
/*Groups*/
ui-card-panel {
/*Name groups*/
//*Bouttons*/
.md-button {
/*Dropdown menu*/
/*Template*/
font-size: 20px;
</style>
Change the "Bouttons" rule again
/*Bouttons*/
.nr-dashboard-button button {
And keep in mind that rule for unique button must be after that rule. The order matters.
Now, if it works!!
I am learning a lot, pure gold you!
