Hi.
I cant figure out the correct syntax to change the background colour of a template button node when it is disabled.
I can change its properties when it is enabled.
Attached is my CSS code for the button.
Is it possible to change CSS properties for a disabled node?
Can you clarify which button you are trying to style? Is this a button in a Node-RED Dashboard (v1 or v2?) or a button attached to a node in the editor (like the Inject/Debug nodes have)
Here is a simplified flow for enabling / disabling the node
"id": "71e7c939038b103a",
"type": "tab",
"label": "Flow 6",
"disabled": false,
"info": "",
"env": []
"id": "bc644d687248fca8",
"type": "function",
"z": "71e7c939038b103a",
"name": "Enable - Disable",
"func": "\n\n// Check if the device ping is good or bad\nif (msg.payload == true){\n msg.enabled = true\n msg.background = \"cyan\"\n}\nelse {\n msg.enabled = false\n msg.background = \"white\"\n}\n\n// Save the device button text\nmsg.topic = \"myButton\";\n \nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 380,
"y": 240,
"40e4f943f8620e25"
"id": "40e4f943f8620e25",
"type": "ui_template",
"group": "7491094c2573df91",
"name": "Centre 1",
"order": 3,
"width": "4",
"height": "1",
"format": "\n<md-button class=\"devButton\" ng-click=\"send({payload: 'on'})\"> \n {{msg.topic}}\n</md-button> \n\n",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": false,
"templateScope": "local",
"className": "",
"x": 540,
"y": 240,
"id": "13d3b57084692505",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "true",
"payloadType": "bool",
"x": 210,
"y": 200,
"bc644d687248fca8"
"id": "5b503b80df270066",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "false",
"x": 210,
"y": 280,
"bc644d687248fca8"
"id": "7491094c2573df91",
"type": "ui_group",
"name": "Home Automation",
"tab": "5aa37e9ba7e53bc9",
"order": 1,
"disp": true,
"width": 6,
"collapse": false,
"className": ""
"id": "5aa37e9ba7e53bc9",
"type": "ui_tab",
"name": "Home",
"icon": "dashboard",
"order": 5,
"disabled": false,
"hidden": true
I see this is a the old dashboard (dashboard 1) which is now deprecated.
I no longer use the old dashboard, but the docs do not suggest that msg.enabled works for a D1 template, and your flow does not seem to work for me, the button is not being disabled.
The flow does work for me.
This template specifies a button whose background colour is grey when disabled:
<md-button class="devButton" ng-click="send({payload: 'on'})">
{{msg.topic}}
</md-button>
<style>
.nr-dashboard-disabled button.md-button.devButton {
background-color: slategrey;
</style>
Thanks that is perfect
How did you manage to find that was the required syntax?
My method is very arbitrary and unsatisfactory. I have no doubt at all that there is a simpler way to do it.
I use Firefox Dev Tools - right click/inspect.
Then I highlight the button HTML in the Inspector tab. I think it has to be enabled or you can't find it with the "Pick an element from the page" button.
I would show you a screen capture but I've moved to Linux and screen captures are ****** EXPLETIVE DELETED ******
Then right click, copy, copy CSS Path.
Paste into a notepad file, delete everything to the left of the class that contains "disabled" and anything to the right which looks unnecessary.
Then it's a case of experimenting.
I always start any tweek with a colour change. If it does not manifest even with !important then the CSS declaration needs to be more specific.
Thankyou.
I was trying the same with Chrome dev tools, but never worked it out.
