I would like to know if someone has implemented the COV subscriptions function on the bacnet, I currently use the "Bacnet Read" node and I am subject to polling fast enough to trigger the push of the buttons of the home automation system that I am integrating with Node-Red.
Thanks in advance.
Piero
Hi - you might be best asking @biancode directly via the node's issue pages ( https://github.com/BiancoRoyal/node-red-contrib-bacnet/issues ) as I'm not sure he follows here very often.
Hi @pm.integrator there is No Cov support also the underlying library is Not ASHRAE approved.
Also you probably need to fund Klaus to developed the node-red node to get this feature.
